davama
(Dave)
February 11, 2020, 2:42pm
1
I’ve been testing 3.2.1 now that extractors work again
Noticed that under /streams if i select my <stream name> stream, I get the Page Not Found gorilla.
I thought maybe it had to do because I imported my content pack from 3.1.X, but I created a New stream and still get Page Not Found message.
At least in 3.1.X behavior, after I select the stream, it would take me to the /search page, with that stream as the query.
I have no issues while under /search selecting my stream from the drop down menu. (works as expected)
Is this normal?
Hope it’s clear.
Thank you,
Dave
jan
(Jan Doberstein)
February 11, 2020, 2:57pm
2
he @davama
what is the error you see in the Graylog server.log when that happens?
Was that a fresh installation or was that an upgrade at all? What MongoDB Version did you run with? Is that the only not working part?
davama
(Dave)
February 11, 2020, 4:14pm
3
@jan Thank you for the reply. Apologies, I should have provided that…
mongodb-org-tools-4.0.16-1.el7.x86_64
mongodb-org-server-4.0.16-1.el7.x86_64
mongodb-org-shell-4.0.16-1.el7.x86_64
mongodb-org-4.0.16-1.el7.x86_64
mongodb-org-mongos-4.0.16-1.el7.x86_64
elasticsearch-6.8.6-1.noarch
graylog-3.2-repository-1-1.noarch
graylog-integrations-plugins-3.2.1-1.noarch
graylog-server-3.2.1-1.noarch
graylog-plugin-auth-sso-3.2.1-1.noarch
CentOS Linux release 7.7.1908 (Core) 3.10.0-1062.12.1.el7.x86_64
It was an upgrade from 3.1.X.
I had deleted my mongodb db and started fresh on that end. Removed my content pack and reinstalled. But not beans
Like i mentioned before, I tried craeting a new stream but still get the Page Not Found.
Logs dont show anything when that Gorilla comes up, just normal stuff:
/var/log/graylog-server/server.log
2020-02-11T16:02:24.157Z INFO [InputStateListener] Input [Syslog UDP/5e42d00f09ecee03259f9f58] is now RUNNING
2020-02-11T16:02:24.159Z INFO [InputStateListener] Input [Syslog UDP/5e42d00f09ecee03259f9f74] is now RUNNING
Please let me know if you need more info from me
-Dave
davama
(Dave)
February 11, 2020, 4:15pm
4
Yes, only not working park that i have discovered as I continue fiddling/testing
jan
(Jan Doberstein)
February 12, 2020, 10:38am
5
he @davama
I can’t imagine a reason for that. What browser did you use? Have you tried a different one?
davama
(Dave)
February 12, 2020, 1:53pm
6
@jan thank you for the feedback
I have tried Google Chrome, Internet Explorer (though it looks ugly here but Gorilla still shows), Edge
I have clear history on all of them and nothing…
Cant test with firefox at this time…
Here is my nginx if it is relavant:
location /graylog/ {
#set $upstream_target http://127.0.0.1:9000;
#proxy_pass $upstream_target;
#include authelia_config/auth.conf;
#include authelia_config/proxy.conf;
proxy_set_header X-Graylog-Server-URL https://$server_name/graylog/;
rewrite ^/graylog/(.*)$ /$1 break;
proxy_pass http://127.0.0.1:9000;
davama
(Dave)
February 12, 2020, 3:32pm
7
Created a gif to show; not sure if it’ll work…
Link: https://i.imgur.com/Y75u1r5.gif
davama
(Dave)
February 13, 2020, 3:51pm
8
@jan
Update:
I believe I found the issue!!
So I created a new graylog instance on a new vm and can confirm that the Gorilla still lives!!
I cannot select a stream.
So on this new instance I moved from a subdirectory in nginx to root / and streams work fine…
Perhaps a bug with using subdirectory?
Thanks,
Dave
jan
(Jan Doberstein)
February 13, 2020, 7:20pm
9
he @davama
it could be, you m ight check github if someone already found/reported that issue and if not, createa bug report
davama
(Dave)
February 13, 2020, 7:52pm
10
davama
(Dave)
February 18, 2020, 9:12pm
11
Update:
You can follow this PR which should hopefully solve this issue:
Graylog2:master ← Graylog2:issue-7447
opened 12:14PM - 17 Feb 20 UTC
davama
(Dave)
February 21, 2020, 5:00pm
12
Update:
Issue resolved with 3.2.2.
Tested and works
system
(system)
Closed
March 6, 2020, 5:00pm
13
