Here is a stream with name A. And a pipeline named ActionExtractor
ActionExtractor will compose up new messages using a rule in the below. New messages are routed to a new stream B. I want to Output this stream to logstash-gelf-input(UDP), but nothing sent to it
rule "alert"
has_field("action") AND contains("monitor check finish",to_string($message.action))
let new_msg = create_message(to_string($message.action), "", to_date(to_string($message.apptime), "Asia/Shanghai"));
set_field("action", $message.action,"","",new_msg);
set_field("apptime", $message.apptime,"","",new_msg);
set_field("arguments", $message.arguments,"","",new_msg);
route_to_stream("B","",new_msg);
contains(“monitor check finish”,to_string($message.action)) has the same effect with
to_string($message.action) == “monitor” OR to_string($message.action) == “check” OR to_string($message.action) == “finish”
