Pipeline route_to_stream not working
Hi Community,
I tried to use a pipeline to route/duplicate messages from one stream to a second stream.
But nothing is routed. I see that the pipeline is processing messages but the target stream keeps empty.
This is my pipeline:
This is the pipeline rule:
This is a simulation:
It would be nice if someone has an idea or a hint for me.
Sebastian
Does no one has an idea?
:thinking:
Use the debug() function in your pipeline rule to make sure it is doing what you expect. You can watch the results of debug() in your Graylog logs:
$ tail -f /var/log/graylog-server/server.log
In the route_to_stream() documentation, you don’t need to clone the message beforehand, and I believe that unless you specifically use remove_from_stream() against message in the original stream, the message will be a member of both streams.
On a side note, rather than screen shots, posting code using the </> tool makes things easier to read.
Hi @smolit,
i’ll have a guess. :slight_smile: Are you using stream rules to route messages to stream? Then you should check the order of your message processors in graylog. See this thread, migh tbe the same problem?
@localhost gave the important hint.
Thany you.
