New field using Pipeline
Guys, good morning!
I am having difficulty creating a field or message by joining two fields I created using extractors. From what I’ve studied, the best way to create this would be with Pipeline.
Below, I set the example I created, but it did not work, can anyone help me?
rule “Request Response”
has_field("$message.answer_0110") || has_field("$message.request_0100")
let msg = create_message();
let transacao=$message.request_0100;
let resposta=$message.response_0110;
set_field(“transacao”,msg.request_0100);
set_field(“resposta”,msg.response_0110);
route_to_stream(“test”);
I created this extractors from messages : request_0100 and response_0110
I created the stream “test” that will receive messages with field finished.
On pipeline connections, would I to set stream test or request_0100 and response_0110?.
Stage default 1.
Am I wrong in anything?
Thanks all!
so what is your target to go?
  1. create a new message with only the to fields
  2. create a field in the existing message that contains both?
Hi Jan, thanks for reply!
So, I think the best option is “Create a new message with only the two fields”.
Someone can help me?
If you are looking for any kind of SLA / answer in time, please considure to buy professional support. This is the community board where users try to help users - and in spare time Graylog developers try that too…
https://www.graylog.org/contact-sales
You might want to read the docs on the used function: http://docs.graylog.org/en/2.4/pages/pipelines/functions.html#create-message
Hi Jan, sorry, but im not looking for any kind of SLA/answer, how you said, this is the community board where various users try to help.
I did not press you on an answer.
Sorry for the misunderstanding.
Be great!
