Slack Plugin not working
Hi All,
Need a bit of help here, have installed the latest version Graylog 3.2.2+
Am trying to get the Slack_Plugin to work but no luck
total 93044
s -ls /usr/share/graylog-server/plugin/*.jar
21464 -rw-r–r-- 1 root root 21975953 Feb 20 18:57 /usr/share/graylog-server/plugin/graylog-plugin-aws-3.2.2.jar
4408 -rw-r–r-- 1 root root 4511556 Feb 20 18:57 /usr/share/graylog-server/plugin/graylog-plugin-collector-3.2.2.jar
25268 -rw-r–r-- 1 root root 25873874 Feb 20 18:58 /usr/share/graylog-server/plugin/graylog-plugin-enterprise-3.2.2.jar
6816 -rw-r–r-- 1 root root 6977317 Feb 20 18:58 /usr/share/graylog-server/plugin/graylog-plugin-enterprise-integrations-3.2.2.jar
28776 -rw-r–r-- 1 root root 29465603 Feb 20 18:58 /usr/share/graylog-server/plugin/graylog-plugin-integrations-3.2.2.jar
32 -rw-r–r-- 1 root root 29456 Mar 28 2018 /usr/share/graylog-server/plugin/graylog-plugin-slack-3.1.0.jar
296 -rw-r–r-- 1 root root 302637 Nov 29 00:43 /usr/share/graylog-server/plugin/graylog-plugin-slack-notification-1.0.5.jar
5884 -rw-r–r-- 1 root root 6025173 Feb 20 18:57 /usr/share/graylog-server/plugin/graylog-plugin-threatintel-3.2.2.jar
4 -rw-r–r-- 1 root root 627 Mar 10 12:47 /usr/share/graylog-server/plugin/metrics-reporter-prometheus-1.5.0.jar
92 -rw-r–r-- 1 root root 93329 Mar 10 15:21 /usr/share/graylog-server/plugin/metrics-reporter-prometheus-3.0.1-SNAPSHOT.jar
I have restarted the server after copying the file to the plugin folder, but cannot see it appear on the web UI, under the notifications or configuration.
Anything I am doing wrong here?
The plugin probably hasn’t been updated to work with Version 3.2.x yet,
This plugin is not working yet in version 3.2.2 .
I hope they fix it soon in version 3.3 .
may be i did not issue the following command.
i upgraded to the latest version, seems to be working now
sudo apt-get install graylog-server graylog-enterprise-plugins graylog-integrations-plugins graylog-enterprise-integrations-plugins
