Graylog does not show slack even I install plugins
It only shows email, http and legacy notification. I checked below:
:/usr/share/graylog-server/plugin$ ls -al
total 121692
drwxr-xr-x 2 root root     4096 Jul  5 09:26 .
drwxr-xr-x 4 root root     4096 Jul  5 09:25 ..
-rw-r--r-- 1 root root 22858574 Jun 15 13:36 graylog-plugin-aws-4.2.10.jar
-rw-r--r-- 1 root root  7075812 Jun 15 13:36 graylog-plugin-collector-4.2.10.jar
-rw-r--r-- 1 root root 32919438 Jun 15 13:37 graylog-plugin-integrations-4.2.10.jar
-rw-r--r-- 1 root root  8616855 Jun 15 13:36 graylog-plugin-threatintel-4.2.10.jar
-rw-r--r-- 1 root root 23280631 Jun 15 13:36 graylog-storage-elasticsearch6-4.2.10.jar
-rw-r--r-- 1 root root 29844354 Jun 15 13:36 graylog-storage-elasticsearch7-4.2.10.jar
$ tail -f /var/log/graylog-server/server.log
2022-07-05T09:48:35.783Z INFO  [ServiceManagerListener] Services are now stopped.
2022-07-05T09:48:37.230Z INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-07-05T09:48:37.796Z INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.2.10 [org.graylog.aws.AWSPlugin]
2022-07-05T09:48:37.797Z INFO  [CmdLineTool] Loaded plugin: Integrations 4.2.10 [org.graylog.integrations.IntegrationsPlugin]
2022-07-05T09:48:37.798Z INFO  [CmdLineTool] Loaded plugin: Collector 4.2.10 [org.graylog.plugins.collector.CollectorPlugin]
2022-07-05T09:48:37.799Z INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.2.10 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-07-05T09:48:37.799Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.2.10+37fbc90 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-07-05T09:48:37.799Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.2.10+37fbc90 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
Hello && Welcome @mpl
The information shown above is not enough to troubleshoot this issue.
I do not have any idea how you installed or configure this setup. Perhaps giving us more details on what you did and configured would help. Any visuals would also be helpful.
Just a guess, either you did not put the plugin in the right directory or the installation that was made was incorrect.
I just use
apt install graylog-integrations-plugins
to install
sorry, I did not do anything but today suddenly works, may be I need to logout and login…
Oh awesome, glad you solved it :+1:
