Server is receiving Syslog packets but Graylog is not using them
I am trying to get gray log to receive syslogs from a cisco switch, I have it working and receiving data from other sources, but I can’t get the switch to work. I have checked via tshark that the packets are getting to the graylog server, but no messages show up in the web interface.
The server was setup on Centos 7 using the documentation here: http://docs.graylog.org/en/3.1/pages/installation/os/centos.html
cat /etc/os-release shows that its CentOS Linux release 7.7.1908 (Core)
$ yum info graylog-server
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: mirrors.tripadvisor.com
 * epel: mirror.colorado.edu
 * extras: centos.s.uw.edu
 * updates: centos.den.host-engine.com
Installed Packages
Arch        : noarch
Version     : 3.1.4
Release     : 1
Repo        : installed
From repo   : graylog
Summary     : Graylog server
URL         : https://www.graylog.org/
License     : GPLv3
Description : Graylog server
$ cat /etc/graylog/server/server.conf
is_master = true
password_secret = *A big long super secret string*
root_username = admin
root_password_sha2 = *Another big long super secret string*
http_bind_address = 192.168.10.26:9000
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
(Commented lines filtered out for brevity)
My input setup:
I have also tried with a Raw/Plaintext UDP input with the same results.
TShark:
$ tshark -i ens160 -f "dst port 15150" -w capture-output.pcap
Capturing on 'ens160'
5
I bounce a port on the switch to generate log entries
$ tshark -r capture-output.pcap
1 0.000000000 *Switch IP* -> *Graylog IP*  UDP 154 Source port: 63486  Destination port: 15150
2 1.004095516 *Switch IP* -> *Graylog IP*  UDP 157 Source port: 63486  Destination port: 15150
3 3.600196975 *Switch IP* -> *Graylog IP*  UDP 136 Source port: 63486  Destination port: 15150
4 4.628186956 *Switch IP* -> *Graylog IP*  UDP 139 Source port: 63486  Destination port: 15150
5 7.880187322 *Switch IP* -> *Graylog IP*  UDP 144 Source port: 63486  Destination port: 15150
Firewall and selinux are disabled
$ sestatus
SELinux status: disabled
$ systemctl status firewalld
● firewalld.service - firewalld - dynamic firewall daemon
Loaded: loaded (/usr/lib/systemd/system/firewalld.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:firewalld(1)
$ tail -n 100 /var/log/graylog-server/server.log
2020-01-21T09:19:44.596-07:00 INFO  [HttpServer] [HttpServer] Started.
2020-01-21T09:19:44.596-07:00 INFO  [JerseyService] Started REST API at <192.168.10.26:9000>
2020-01-21T09:19:44.597-07:00 INFO  [ServiceManagerListener] Services are healthy
2020-01-21T09:19:44.598-07:00 INFO  [ServerBootstrap] Services started, startup times in ms: {OutputSetupService [RUNNING]=47, GracefulShutdownService [RUNNING]=53, BufferSynchronizerService [RUNNING]=70, InputSetupService [RUNNING]=130, KafkaJournal [RUNNING]=167, JobSchedulerService [RUNNING]=180, ConfigurationEtagService [RUNNING]=180, EtagService [RUNNING]=180, UrlWhitelistService [RUNNING]=184, JournalReader [RUNNING]=186, StreamCacheService [RUNNING]=261, LookupTableService [RUNNING]=262, MongoDBProcessingStatusRecorderService [RUNNING]=267, PeriodicalsService [RUNNING]=452, JerseyService [RUNNING]=28303}
2020-01-21T09:19:44.603-07:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2020-01-21T09:19:44.631-07:00 INFO  [ServerBootstrap] Graylog server up and running.
2020-01-21T09:19:44.632-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:19:44.653-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25e9cbd9f024274dac03e9] is now STARTING
2020-01-21T09:19:44.673-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25f4bcd9f024274dac0ff1] is now STARTING
2020-01-21T09:19:44.680-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STARTING
2020-01-21T09:19:44.682-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25eecdd9f024274dac0965] is now STARTING
2020-01-21T09:19:44.780-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=CISCO_IOS_SYSLOG, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0x67d6ccbf, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.782-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0x55021083, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.782-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=cisco test, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} (channel [id: 0x205bf7ee, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.783-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=test input, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} (channel [id: 0x52ed780a, L:/0:0:0:0:0:0:0:0%0:12201]) should be 262144 but is 425984.
2020-01-21T09:19:44.789-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=CISCO_IOS_SYSLOG, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0xc910e9c4, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.795-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0x7c8e7d80, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.796-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=cisco test, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} (channel [id: 0xef7bf911, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:19:44.799-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=test input, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} (channel [id: 0x1638788b, L:/0:0:0:0:0:0:0:0%0:12201]) should be 262144 but is 425984.
2020-01-21T09:19:44.801-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25e9cbd9f024274dac03e9] is now RUNNING
2020-01-21T09:19:44.803-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25f4bcd9f024274dac0ff1] is now RUNNING
2020-01-21T09:19:44.806-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25eecdd9f024274dac0965] is now RUNNING
2020-01-21T09:19:44.808-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now RUNNING
2020-01-21T09:23:46.102-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:29:15.564-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:29:16.390-07:00 INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:8}] to localhost:27017
2020-01-21T09:29:16.391-07:00 INFO  [connection] Opened connection [connectionId{localValue:13, serverValue:13}] to localhost:27017
2020-01-21T09:29:16.391-07:00 INFO  [connection] Opened connection [connectionId{localValue:10, serverValue:10}] to localhost:27017
2020-01-21T09:29:16.397-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPING
2020-01-21T09:29:16.397-07:00 INFO  [connection] Opened connection [connectionId{localValue:11, serverValue:11}] to localhost:27017
2020-01-21T09:29:16.400-07:00 INFO  [connection] Opened connection [connectionId{localValue:14, serverValue:14}] to localhost:27017
2020-01-21T09:29:16.404-07:00 INFO  [connection] Opened connection [connectionId{localValue:12, serverValue:12}] to localhost:27017
2020-01-21T09:29:16.405-07:00 INFO  [connection] Opened connection [connectionId{localValue:9, serverValue:9}] to localhost:27017
2020-01-21T09:29:16.412-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPED
2020-01-21T09:29:16.413-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STARTING
2020-01-21T09:29:16.414-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now TERMINATED
2020-01-21T09:29:16.411-07:00 WARN  [UdpTransport] Failed to start channel for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null}
io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Permission denied
2020-01-21T09:29:16.426-07:00 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5e25f775d9f024274dac12ea> misfired. Reason: bind(..) failed: Permission denied.
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Permission denied
        at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
        at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
        at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Caused by: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Permission denied
        at org.graylog2.inputs.transports.UdpTransport.launch(UdpTransport.java:135) ~[graylog.jar:?]
        at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
        ... 7 more
Caused by: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Permission denied
2020-01-21T09:29:16.436-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:29:16.436-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now FAILED
2020-01-21T09:29:57.554-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:29:57.560-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:29:57.561-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPING
2020-01-21T09:29:57.563-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPED
2020-01-21T09:29:57.564-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STARTING
2020-01-21T09:29:57.565-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now TERMINATED
2020-01-21T09:29:57.568-07:00 WARN  [UdpTransport] Failed to start channel for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null}
2020-01-21T09:29:57.569-07:00 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5e25f775d9f024274dac12ea> misfired. Reason: bind(..) failed: Permission denied.
        ... 7 more
2020-01-21T09:29:57.572-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now FAILED
2020-01-21T09:30:09.546-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:10.364-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPING
2020-01-21T09:30:10.365-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now TERMINATED
2020-01-21T09:30:10.367-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STOPPED
2020-01-21T09:30:28.796-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:28.804-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now STARTING
2020-01-21T09:30:28.805-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:28.809-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0xd35e1112, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:30:28.812-07:00 WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog test, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} (channel [id: 0x852f5492, L:/0:0:0:0:0:0:0:0%0:15150]) should be 262144 but is 425984.
2020-01-21T09:30:28.814-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25f775d9f024274dac12ea] is now RUNNING
2020-01-21T09:30:56.885-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:56.890-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25e9cbd9f024274dac03e9] is now STOPPING
2020-01-21T09:30:56.890-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25e9cbd9f024274dac03e9] is now TERMINATED
2020-01-21T09:30:56.891-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:56.891-07:00 INFO  [InputStateListener] Input [Syslog UDP/5e25e9cbd9f024274dac03e9] is now STOPPED
2020-01-21T09:30:57.540-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:57.541-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25f4bcd9f024274dac0ff1] is now STOPPING
2020-01-21T09:30:57.543-07:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-21T09:30:57.544-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25f4bcd9f024274dac0ff1] is now STOPPED
2020-01-21T09:30:57.545-07:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5e25f4bcd9f024274dac0ff1] is now TERMINATED
2020-01-21T10:19:16.685-07:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
I see some errors and warnings in the log file but I don’t know how to fix them or if they are even related.
What am I missing here?
did you configured the switches to send to the input port you have configured?
If yes, you might want to create a RAW input and point that switch to the port you have used at that input to see if it receives the messages on that port.
I have configured the switch and as you can see from Tshark the packets are coming in on the right port.
I did try a raw input and I don’t receive anything from the switch. I used a linux box to ncat a message to that same input/port and it did show up in graylog. so I am not sure if its an issue with it being syslog or from a cisco.
I had similar problem from one device, that had setup bad time. Graylog received message and saved it to elastic, but it didn’t show it. Timestamp for these messages were in future, so graylog couldn’t show them.
Try to open Search and change to Absolute in time frame selector (top left corner):
Try to choose starting date to today: 2020-01-23 00:00:00 and ending date in future (tomorow): 2020-01-24 00:00:00
Is you see some messages, you probably have problem with timestamps. Anyway check timezone in cisco switches and setup correct also in /etc/graylog/server/server.conf, parameter root_timezone
Tried the tests again, and expanding the date range. Still nothing from the switch.
  1 0.000000000  *Linux Server IP* -> *Graylog IP*  UDP 113 Source port: 46995  Destination port: 15150
  2 48.809722784 *Switch IP*-> *Graylog IP*   UDP 144 Source port: 63486  Destination port: 15150
  3 60.477759608 *Switch IP*-> *Graylog IP*   UDP 144 Source port: 63486  Destination port: 15150
  4 87.138187213  *Linux Server IP* -> *Graylog IP*  UDP 112 Source port: 55099  Destination port: 15150
Times and dates for the Graylog Server, Linux Server, and Cisco Switch are synced up to the second.
Update, I setup the Linux server to send its syslogs to graylog it see if it’s just the rsyslog protocol thats having issues, and it works fine.
The switch is on a different subnet, but everything is routing fine as shown by tshark. Could this have something to do with it?
I exported the pcap file and did a compare on the two packets. the only difference is the one from the Linux server has the “Don’t Fragment” flag while the Cisco has none.
he @samwarez
look at the dates that are used by cisco … that is the problem here.
I have written one article in the past about that:
The date format looks the same to me, unless you are talking about the extra number in front.
also from the article
All of the above is needed with Graylog 2.4 - as of the new features in Graylog 3, this above would just be a content pack that includes everything.
I am running graylog 3 and I have already tried a few content packs for Cisco IOS devices (it was the first thing I tried actually), can you recommend one that should work? I am somewhat shocked that graylog would not support Cisco out of the box given how common they are.
I’m thinking you have conflicting inputs as both the raw and the syslog input are trying to bind to 15150. assuming this is not a production environment or the following wouldn’t be service impacting, I would recommend you delete both inputs, create the Syslog UDP, and then test again. if that doesn’t work, delete the Syslog UDP and create a RAW and try again.
Are there any other inputs using 15150?
I have a Cisco content pack setup as well,I have tried with just a single input (others were disabled) and having multiple enabled did not affect the Linux syslogs. However I will try completely deleting the others and just leave the RAW input.
I deleted all the inputs and just had one (tried Raw first, deleted it, then tried syslog UDP), I also changed the port number just to be safe. Still not getting anything.
have you tried a different port?
yes, I tries 15150 and 15151
Is this a dedicated server or are you running anything else on it?
run
lsof -i UDP:15150 to see what is bound to 15150. might need to sudo
same for 15151.
Not sure what else it could be
dedicated server, setup almost to the letter of the documentation.image
to be honest - Graylog does support Cisco devices, but Cisco is changing their logs with every version on every device and they give a shit of following any available standards. It is Cisco that does not follow the RFC and force you to look into that and not Graylog not understand Cisco Logs.
The Content Packs are created by users for users - I do not know the quality of them and for what devices they work or not. We (Graylog) do not have a zoo of devices that we could create content packs for specific vendors.
I apologize if I came off as attacking you or graylog. I was supposed to have a log server up and running last week and its primary objective is to monitor this one switch with the rest of our infrastructure added later. I would try some other solution but Graylog seems to be the only one I can find that is hosted locally and can do network equipment (everything else seems to pretend anything that’s not a web app or in the cloud does not exist).
I have tried different content packs, some of which include GROK patterns for Cisco devices. Can you tell me how the timestamp is different in the packets shown? They look the same to me.
on the cisco device captured you have some kind of ID before the timestamp. This is not following the RFC.
I have linked the article how to set the timestamp on cisco devices, should that not be possible, use RAW and start parsing the basic out. Like in the linked article for example.
Should all of this not be possible - the only solution is to invest work in this or invest money and buy the cisco logging solution.
Ill try working through the article. However you say to use RAW and parse it out, This is not possible as RAW does not show any messages from any time. There is nothing to parse.
