I am new to Graylog, I am installing graylog 2 on centos 7, and I can access graylog by web but when click in search tab it showing for
me loading for ever and i dont knew reason why . attachment picture.please i need your help
First, you should install the latest stable version of Graylog. Graylog 2.0.3 was released almost 2 years ago.
The latest stable version is Graylog 2.4.3.
Second, please check the logs of your Graylog and Elasticsearch nodes and post the complete configuration of Graylog and Elasticsearch.
ok
i will upgrade to 2.4.3 and i will inform you if any thing new
hell dir
i upgraded to 2.4.3 and work fine thank you alot
i want to knew exactly steps how to collect logs for cisco switch.
thank you alot
regards
please iam waiting your replay
i need this
You can configure your Cisco appliances to send their logs via Syslog to Graylog.
fine
what is the configuration steps?
I won’t give you a step-by-step guide for this when it’s clear you didn’t even try to get it running yourself.
If you need individual support with fixed SLA, consider booking Graylog Enterprise Support at https://www.graylog.org/pricing.
