Graylog on centos7
hello everyone, I installed Graylog 2.5 in Centos 7…I want to have the logs of a switch and firewll palo-alto … Can anyone help me please and thanks
you should read the getting started guide!
http://docs.graylog.org/en/3.0/pages/getting_started.html
Hi, Thanks jan , well , Graylog version 2.5 is installed in my centos 7…the problem is how i get firewall and Switch Logs. I put the firewall and Sw in System input in the interface web but i don’t have logs …I checked the network flow between the grylog and the firewall and the switch is allowed!
Is the sidecar running and do you see the sidecar on the webinterface?
Sory Lyro, i I did not understand you. sidecar ? what is the configuration that I need to put
in may graylog-server.conf to have Logs…I checked the port and the firewall protocol
In short, you need a service which ships the logfiles to your graylog. Did you read the documentation? I really recommend it.
http://docs.graylog.org/en/2.5/pages/getting_started.html
and
http://docs.graylog.org/en/2.5/pages/collector_sidecar.html
should help you :slight_smile:
Lyro , on Centos7
$ sudo rpm -i collector-sidecar-0.0.9-1.x86_64.rpm
why you use this ancient version of the collector? The most recent version compatible with your Graylog is 0.1.8
Use that
hi Jan i use Graylog 2.5
please Jan how i insall the version 0.1.8 on centos7
please read the docs:
http://docs.graylog.org/en/2.5/pages/collector_sidecar.html#installation
how i install it centos c
Please how can i dowload this https://github.com/Graylog2/collector-sidecar/releases/tag/0.1.8 on centos7
did you checked the link in your browser? Thinking is allowed!
yes is allowed but on centos7 server it is not :pensive::tired_face:
why is it not allowed to think when you use centOS7?
When you follow the link you will get the following picture:
Make a right click on the RPM you like to have, choose copy link location or whatever that is named in your OS language and use that URL in your wget. Alternative you can just type in
rpm -i SELECTED_URL
oh thanks Jan but i think i have connexion
problem with proxy
