Trouble getting data into Graylog
Hey guys, I am implementing Graylog for the first time and I am stuck. I am trying to get data in, but my UDP input is not showing any messages being received. The input is “running”, but no messages… A little information about my setup, I have two VM’s running Centos 7. Server A is for Graylog and Mongodb, server B is for Elasticsearch. On our network, we also have a server that collects all of our syslog data from all devices on our network, we call it our “logging server”. From that logging server, I am trying to forward all the logs to Graylog. The logging server acts like a middle man between the device and Graylog. I am running Graylog version 2.4.6 and Elasticsearch version 5.6.12. I have verified that Elasticsearch and Graylog are up and running.
Logging Server IP - 10.0.38.34
Graylog Server IP - 10.0.38.51
Elasticsearch Server IP - 10.0.38.52
For my UDP input, I set the bind address to 10.0.38.51 and port 5140
In the logging server, I have created a new .conf file under /etc/rsyslog.d called “graylog.conf” to forward UDP logs to Graylog.
*.* @10.0.38.51:5140;RSYSLOG_SyslogProtocol23Format
Graylog Configuration File
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = bQvTiJWqQtnwBeOaUH1G43C0Lcpu9ZUmit63Q96AWGXRPjZhTU3O7pb5FAjFiRV6NXHbaTYkN8uYy1veZBGds7mPfnExyhqf
#root_username = admin
"server.conf" 588L, 28139C
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
Elasticsearch Configuration File
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 10.0.38.52
# Set a custom port for HTTP:
http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
discovery.zen.ping.unicast.hosts: 10.0.38.52:9300
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
Graylog logs
2018-11-27T13:39:21.757-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:39:52.758-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:39:52.758-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:40:11.696-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:40:21.756-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:40:21.756-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:40:52.758-05:00 INFO  [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2018-11-27T13:40:57.769-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:40:57.769-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:41:11.696-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:41:21.757-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:41:21.757-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:41:57.769-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:41:57.769-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:42:11.697-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:42:24.763-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:42:24.763-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:42:55.774-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:42:55.775-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:43:11.697-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:43:23.780-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:43:23.780-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:43:54.762-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:43:54.762-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:44:11.697-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:44:25.764-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:44:25.764-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:44:53.760-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:44:53.760-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2018-11-27T13:45:11.697-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2018-11-27T13:45:23.760-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
2018-11-27T13:45:23.760-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
Any help would be appreciated. Been battling this for about a week now. Thank you in advance.
Zac
may I ask if you had followed any guide to install the system?
Your Graylog server.conf is not complete but you need to have your Elasticsearch host set their. The discovery.zen setting is not needed for elasticsearch …
You might want to read the step-by-step guide to check if you have done all installation the right way: http://docs.graylog.org/en/2.4/pages/installation/os/centos.html
In addition the multi host node guide: http://docs.graylog.org/en/2.4/pages/configuration/multinode_setup.html for details and configuration settings that might need to be changed. Please READ those pages and not just blindly apply configuration settings you spot.
Yeah those are the guides I followed. I will go over these again more carefully.
In order to understand if your issue is on the Gralyog or the logging server side, I’d suggest trying to manually send logs to your UDP input with netcat:
nc -u graylog-ip graylog-input port
Then type a few lines, and press CTRL+D to exit. If you see what you typed in Graylog, it means your Graylog input is properly set up and you have an issue on your logging server. Otherwise, the problem is likely on Graylog itself.
If the issue seems to be on the logging server side:
  • Check for any rsyslog error logs (e.g. with journalctl -u rsyslog)
  • Make sure rsyslog is able to read the files you want it to ship to Graylog
  • Make sure you have network connectivity to the Graylog input from the machine (you can test it with netcat as well)
  • Try to run rsyslog in debug mode to see if you get any errors
    sudo systemctl stop rsyslogd
    sudo systemctl disable rsyslog # Might be needed
    sudo rsyslogd -d
  • If nothing interesting comes out, you can try to strace rsyslog to see if it’s really attempting to perform network connections to graylog, and if yes, if it has any error:
    sudo strace -f -e trace=network rsyslogd -d 2>&1 | grep 10.0.38.51
If rsyslog is attempting to connect to the Graylog input you’ll see something like:
[pid 29315] sendto(2, "<46>1 2018-12-23T10:37:53.952146"..., 109, 0, {sa_family=AF_INET, sin_port=htons(5140), sin_addr=inet_addr("10.0.38.51")}, 16) = 109
[pid 29315] sendto(2, "<46>1 2018-12-23T10:37:53.952421"..., 108, 0, {sa_family=AF_INET, sin_port=htons(5140), sin_addr=inet_addr("10.0.38.51")}, 16) = 108
[pid 29315] sendto(2, "<46>1 2018-12-23T10:37:53.952594"..., 176, 0, {sa_family=AF_INET, sin_port=htons(5140), sin_addr=inet_addr("10.0.38.51")}, 16) = 176
(unfortunately you won’t be able to tell if the “connection” succeeds, since UDP is stateless)
Hope that helps!
christophetd, thank you for your reply. My inputs did not show up in Graylog.
My input is supposedly running, but there are no messages coming in.
My Graylog logs are still showing the following:
  `2019-01-03T10:21:49.459-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
            2019-01-03T10:21:49.459-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
            2019-01-03T10:22:16.857-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (No route to host (Host unreachable))
            2019-01-03T10:22:16.857-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
            2019-01-03T10:22:47.047-05:00 WARN  [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out waiting for Elasticsearch cluster, checking again.
            2019-01-03T10:22:53.959-05:00 ERROR [Cluster] Couldn't read cluster health for indices [graylog_*] (Connect to 10.0.38.52:9200 [/10.0.38.52] failed: connect timed out)
            2019-01-03T10:22:53.960-05:00 INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
Here is the full config of my server.conf file
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
is_master = true
password_secret =F7Qt9YJbuZDGT67oXjmj1MiHunX1NUXVvsistC8MkjljSXS56JmQWFzpgLTZmbvumvxXbKSzdkcm7TC6m2vv5LmGD7cAN2xi
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 =7074f34123ed04206cf6f6652e9c289d7bcce788600e69930717fbe15b4a8c91
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = EST
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://10.0.38.51:9000/api/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
#rest_transport_uri = http://192.168.1.1:9000/api/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog.crt
# The PKCS#8 private key file in PEM format to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
#rest_max_header_size = 8192
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://10.0.38.51:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
#web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
#web_tls_cert_file = /path/to/graylog-web.crt
# The PKCS#8 private key file in PEM format to use for securing the web interface.
#web_tls_key_file = /path/to/graylog-web.key
# The password to unlock the private key used for securing the web interface.
#web_tls_key_password = secret
#web_max_header_size = 8192
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# requires authentication.
elasticsearch_hosts = http://root:$ectv9100@10.0.38.52:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# Examples:
#http_proxy_uri =
# Examples:
# cycled indices.
# Default: empty
Well, for starters it looks like you’re having issues talking to ElasticSearch. So even if log messages got to your Graylog, you wouldn’t see them.
Time to troubleshoot your basic setup of the services. For example, have you opened the required ports on the local firewall?
