Not receive any data
GRAYLOG CONFIGURATION FILE
This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
Characters that cannot be directly represented in this encoding can be written using Unicode escapes
as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
For example, \u002c.
* Entries are generally expected to be a single line of the form, one of the following:
propertyName=propertyValue
propertyName:propertyValue
* White space that appears between the property name and property value is ignored,
so the following are equivalent:
name=Stephen
name = Stephen
* White space at the beginning of the line is also ignored.
* Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
* The property value is generally terminated by the end of the line. White space following the
property value is not ignored, and is treated as part of the property value.
* A property value can span several lines if each line is terminated by a backslash (‘\’) character.
For example:
targetCities=\
Detroit,\
Chicago,\
Los Angeles
This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
* The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
* The backslash character must be escaped as a double backslash. For example:
path=c:\docs\doc1
If you are running more than one instances of Graylog server you have to select one of these
instances as master. The master will perform some periodical tasks that non-masters won’t perform.
is_master = true
The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
to use an absolute file path here if you are starting Graylog server from init scripts or similar.
You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
Generate one by using for example: pwgen -N 1 -s 96
password_secret = MV6O4kfeky1K7uzTkprxm0zxLaKgDCoe6Jf6gFUzvVB6PVcEV8Creh3mhRG2lg1qHyrsN0E0VaSPEtBNRBnxLKssMZIjmc2F
The default root user is named ‘admin’
#root_username = admin
You MUST specify a hash password for the root user (which you only need to initially set up the
system and in case you lose connectivity to your authentication backend)
This password cannot be changed using the API or via the web interface. If you need to change it,
modify it in this file.
Create one by using for example: echo -n yourpassword | shasum -a 256
and put the resulting hash value into the following line
root_password_sha2 = dd69d1335e0cafd0630850cbc5da3d7261167b370ff95b0a77989bd056f6e686
The email address of the root user.
Default is empty
#root_email = “”
The time zone setting of the root user. See http://www.joda.org/joda-time/timezones.html for a list of valid time zones.
Default is UTC
root_timezone = Asia/Colombo
Set plugin directory here (relative or absolute)
REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://10.0.100.130:12900/api/
REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
the scheme, host name or URI.
This must not contain a wildcard address (0.0.0.0).
#rest_transport_uri = http://192.168.1.1:9000/api/
Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
If these are disabled, modern browsers will not be able to retrieve resources from the server.
This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
overall round trip times. This is enabled by default. Uncomment the next line to disable it.
#rest_enable_gzip = false
Enable HTTPS support for the REST API. This secures the communication with the REST API with
TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
next line to enable it.
#rest_enable_tls = true
The X.509 certificate chain file in PEM format to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog.crt
The PKCS#8 private key file in PEM format to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog.key
The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
The maximum size of the HTTP request headers in bytes.
#rest_max_header_size = 8192
The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
Comma separated list of trusted proxies that are allowed to set the client address with X-Forwarded-For
header. May be subnets, or hosts.
Enable the embedded Graylog web interface.
Default: true
#web_enable = false
Web interface listen URI.
Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://10.0.100.130:9000/
Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
Default: $rest_transport_uri
#web_endpoint_uri =
Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = false
Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
using TLS to prevent request forgery and eavesdropping.
This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
#web_enable_tls = true
The X.509 certificate chain file in PEM format to use for securing the web interface.
#web_tls_cert_file = /path/to/graylog-web.crt
The PKCS#8 private key file in PEM format to use for securing the web interface.
#web_tls_key_file = /path/to/graylog-web.key
The password to unlock the private key used for securing the web interface.
#web_tls_key_password = secret
#web_max_header_size = 8192
The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
List of Elasticsearch hosts Graylog should connect to.
Need to be specified as a comma-separated list of valid URIs for the http ports of your elasticsearch nodes.
If one or more of your elasticsearch hosts require authentication, include the credentials in each node URI that
requires authentication.
Default: http://127.0.0.1:9200
Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
Default: 10 Seconds
Maximum amount of time to wait for reading back a response from an Elasticsearch server.
Default: 60 seconds
Maximum idle time for an Elasticsearch connection. If this is exceeded, this connection will
be tore down.
Default: inf
Maximum number of total connections to Elasticsearch.
Default: 20
#elasticsearch_max_total_connections = 20
Maximum number of total connections per Elasticsearch route (normally this means per
elasticsearch server).
Default: 2
#elasticsearch_max_total_connections_per_route = 2
Maximum number of times Graylog will retry failed requests to Elasticsearch.
Default: 2
#elasticsearch_max_retries = 2
Enable automatic Elasticsearch node discovery through Nodes Info,
see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
Default: false
#elasticsearch_discovery_enabled = true
Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
Default: empty
#elasticsearch_discovery_filter = rack:42
Frequency of the Elasticsearch node discovery.
Default: 30s
elasticsearch_discovery_frequency = 30s
Enable payload compression for Elasticsearch requests.
Default: false
Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
when to rotate the currently active write index.
It supports multiple rotation strategies:
- “count” of messages per index, use elasticsearch_max_docs_per_index below to configure
- “size” per index, use elasticsearch_max_size_per_index below to configure
valid values are “count”, “size” and “time”, default is “count”
ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these
to your previous 1.x settings so they will be migrated to the database!
rotation_strategy = count
(Approximate) maximum number of documents in an Elasticsearch index before a new index
is being created, also see no_retention and elasticsearch_max_number_of_indices.
Configure this if you used ‘rotation_strategy = count’ above.
(Approximate) maximum size in bytes per Elasticsearch index on disk before a new index is being created, also see
no_retention and elasticsearch_max_number_of_indices. Default is 1GB.
Configure this if you used ‘rotation_strategy = size’ above.
(Approximate) maximum time before a new Elasticsearch index is being created, also see
no_retention and elasticsearch_max_number_of_indices. Default is 1 day.
Configure this if you used ‘rotation_strategy = time’ above.
Please note that this rotation period does not look at the time specified in the received messages, but is
using the real clock value to decide when to rotate the index!
Specify the time using a duration and a suffix indicating which unit you want:
1w = 1 week
1d = 1 day
12h = 12 hours
Permitted suffixes are: d for day, h for hour, m for minute, s for second.
Disable checking the version of Elasticsearch for being compatible with this Graylog release.
WARNING: Using Graylog with unsupported and untested versions of Elasticsearch may lead to data loss!
Disable message retention on this node, i. e. disable Elasticsearch index rotation.
#no_retention = false
How many indices do you want to keep?
Decide what happens with the oldest indices when the maximum number of indices is reached.
The following strategies are availble:
- delete # Deletes the index completely (Default)
- close # Closes the index and hides it from the system. Can be re-opened later.
retention_strategy = delete
How many Elasticsearch shards and replicas should be used per index? Note that this only applies to newly created indices.
ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these
to your previous settings so they will be migrated to the database!
elasticsearch_shards = 4
elasticsearch_replicas = 0
Prefix for all Elasticsearch indices and index aliases managed by Graylog.
Name of the Elasticsearch index template used by Graylog to apply the mandatory index mapping.
Default: graylog-internal
Do you want to allow searches with leading wildcards? This can be extremely resource hungry and should only
be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
Do you want to allow searches to be highlighted? Depending on the size of your messages this can be memory hungry and
should only be enabled after making sure your Elasticsearch cluster has enough memory.
allow_highlighting = false
Analyzer (tokenizer) to use for message and full_message field. The “standard” filter usually is a good idea.
All supported analyzers are: standard, simple, whitespace, stop, keyword, pattern, language, snowball, custom
Elasticsearch documentation: https://www.elastic.co/guide/en/elasticsearch/reference/2.3/analysis.html
Note that this setting only takes effect on newly created indices.
Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
Default: 1m
#elasticsearch_request_timeout = 1m
Global timeout for index optimization (force merge) requests.
Default: 1h
Maximum number of concurrently running index optimization (force merge) jobs.
If you are using lots of different index sets, you might want to increase that number.
Default: 20
Time interval for index range information cleanups. This setting defines how often stale index range information
is being purged from the database.
Default: 1h
Batch size for the Elasticsearch output. This is the maximum (!) number of messages the Elasticsearch output
module will get at once and write to Elasticsearch in a batch call. If the configured batch size has not been
reached within output_flush_interval seconds, everything that is available will be flushed at once. Remember
that every outputbuffer processor manages its own batch and performs its own batch write calls.
(“outputbuffer_processors” variable)
output_batch_size = 500
Flush interval (in seconds) for the Elasticsearch output. This is the maximum amount of time between two
batches of messages written to Elasticsearch. It is only effective at all if your minimum number of messages
for this time period is less than output_batch_size * outputbuffer_processors.
output_flush_interval = 1
As stream outputs are loaded only on demand, an output which is failing to initialize will be tried over and
over again. To prevent this, the following configuration options define after how many faults an output will
not be tried again for an also configurable amount of seconds.
The number of parallel running processors.
Raise this number if your buffers are filling up.
processbuffer_processors = 5
outputbuffer_processors = 3
The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
Default: 5000
The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
Default: 3
The maximum number of threads to allow in the pool
Default: 30
UDP receive buffer size for all message inputs (e. g. SyslogUDPInput).
Wait strategy describing how buffer processors wait on a cursor sequence. (default: sleeping)
Possible types:
- yielding
Compromise between performance and CPU usage.
- sleeping
Compromise between performance and CPU usage. Latency spikes can occur after quiet periods.
- blocking
High throughput, low latency, higher CPU usage.
- busy_spinning
Avoids syscalls which could introduce latency jitter. Best when threads can be bound to specific CPU cores.
Size of internal ring buffers. Raise this if raising outputbuffer_processors does not help anymore.
For optimum performance your LogMessage objects in the ring buffer should fit in your CPU L3 cache.
Must be a power of 2. (512, 1024, 2048, …)
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Enable the disk based message journal.
The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
must not contain any other files than the ones created by Graylog itself.
ATTENTION:
If you create a seperate partition for the journal files and use a file system creating directories like ‘lost+found’
in the root directory, you need to create a sub directory for your journal.
Otherwise Graylog will log an error message that the journal is corrupt and Graylog will not start.
Journal hold messages before they could be written to Elasticsearch.
For a maximum of 12 hours or 5 GB whichever happens first.
During normal operation the journal will be smaller.
Number of threads used exclusively for dispatching internal events. Default is 2.
How many seconds to wait between marking node as DEAD for possible load balancers and starting the actual
shutdown process. Set to 0 if you have no status checking load balancers in front.
Journal usage percentage that triggers requesting throttling for this server node from load balancers. The feature is
disabled if not set.
Every message is matched against the configured streams and it can happen that a stream contains rules which
take an unusual amount of time to run, for example if its using regular expressions that perform excessive backtracking.
This will impact the processing of the entire server. To keep such misbehaving stream rules from impacting other
streams, Graylog limits the execution time for each stream.
The default values are noted below, the timeout is in milliseconds.
If the stream matching for one stream took longer than the timeout value, and this happened more than “max_faults” times
that stream is disabled and a notification is shown in the web interface.
Length of the interval in seconds in which the alert conditions for all streams should be checked
and alarms are being sent.
#alert_check_interval = 60
Since 0.21 the Graylog server supports pluggable output modules. This means a single message can be written to multiple
outputs. The next setting defines the timeout for a single output module, including the default output module where all
messages end up.
Time in milliseconds to wait for all message outputs to finish writing a single message.
Time in milliseconds after which a detected stale master node is being rechecked on startup.
#stale_master_timeout = 2000
Time in milliseconds which Graylog is waiting for all threads to stop on shutdown.
#shutdown_timeout = 30000
MongoDB connection string
See https://docs.mongodb.com/manual/reference/connection-string/ for details
Authenticate against the MongoDB server
Use a replica set instead of a single host
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
Increase this value according to the maximum connections your MongoDB server can handle from a single client
if you encounter MongoDB connection problems.
Number of threads allowed to be blocked by MongoDB connections multiplier. Default: 5
If mongodb_max_connections is 100, and mongodb_threads_allowed_to_block_multiplier is 5,
then 500 threads can block. More than that and an exception will be thrown.
http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
Drools Rule File (Use to rewrite incoming log messages)
See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
Specify and uncomment this if you want to include links to the stream in your stream alert mails.
This should define the fully qualified base url to your web interface exactly the same way as it is accessed by your users.
The default connect timeout for outgoing HTTP connections.
Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds).
Default: 5s
#http_connect_timeout = 5s
The default read timeout for outgoing HTTP connections.
Default: 10s
#http_read_timeout = 10s
The default write timeout for outgoing HTTP connections.
Default: 10s
#http_write_timeout = 10s
HTTP proxy for outgoing HTTP connections
ATTENTION: If you configure a proxy, make sure to also configure the “http_non_proxy_hosts” option so internal
HTTP connections with other nodes does not go through the proxy.
Examples:
- http://proxy.example.com:8123
- http://username:password@proxy.example.com:8123
#http_proxy_uri =
A list of hosts that should be reached directly, bypassing the configured proxy server.
This is a list of patterns separated by “,”. The patterns may start or end with a “*” for wildcards.
Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
Examples:
- localhost,127.0.0.1
- 10.0.,.example.com
#http_non_proxy_hosts =
Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
cycled indices.
#disable_index_optimization = true
Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
Disable the use of SIGAR for collecting system stats
#disable_sigar = false
The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
Automatically load content packs in “content_packs_dir” on the first start of Graylog.
#content_packs_loader_enabled = true
The directory which contains content packs which should be loaded on the first start of Graylog.
A comma-separated list of content packs (files in “content_packs_dir”) which should be applied on
Default: empty
For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
of threads available for this. Increase it, if ‘/cluster/*’ requests take long to complete.
Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
BTW Here is my log
2018-11-28T05:27:44.729Z INFO [CloudTrailTransport] Stopping cloud trail subscriber
2018-11-28T05:27:44.729Z INFO [InputStateListener] Input [AWS CloudTrail Input/5bfe2236be81f708d48bca8f] is now STOPPING
2018-11-28T05:27:44.730Z INFO [InputStateListener] Input [AWS CloudTrail Input/5bfe2236be81f708d48bca8f] is now TERMINATED
2018-11-28T05:27:44.730Z INFO [InputStateListener] Input [AWS CloudTrail Input/5bfe2236be81f708d48bca8f] is now STOPPED
2018-11-28T05:27:47.730Z INFO [InputStateListener] Input [CEF UDP Input/5bfe25d8be81f708d48bce82] is now STOPPING
2018-11-28T05:27:47.730Z INFO [InputStateListener] Input [CEF UDP Input/5bfe25d8be81f708d48bce82] is now STOPPED
2018-11-28T05:27:47.730Z INFO [InputStateListener] Input [CEF UDP Input/5bfe25d8be81f708d48bce82] is now TERMINATED
2018-11-28T05:29:53.732Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now STARTING
2018-11-28T05:29:53.732Z WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=UTMS APP Staging, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=205069a5-d713-42e0-afdb-bcb44a0c8d7c} should be 262144 but is 212992.
2018-11-28T05:29:53.733Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now RUNNING
2018-11-28T05:47:50.424Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now STOPPING
2018-11-28T05:47:50.427Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now STOPPED
2018-11-28T05:47:50.427Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now TERMINATED
2018-11-28T05:47:57.352Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now STARTING
2018-11-28T05:47:57.353Z WARN [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=UTMS APP Staging, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=205069a5-d713-42e0-afdb-bcb44a0c8d7c} should be 262144 but is 212992.
2018-11-28T05:47:57.353Z INFO [InputStateListener] Input [Syslog UDP/5bfe27d1be81f708d48bd0b2] is now RUNNING
Data not get updated.
please use proper formatting in your posting than it is very much more likely that someone is able to help you.
https://community.graylog.org/faq
That would include that you place configuration files an log messages in code blocks like
TEXT HERE
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
# Default is empty
#root_email = ""
# Default is UTC
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
# The X.509 certificate chain file in PEM format to use for securing the REST API.
# The PKCS#8 private key file in PEM format to use for securing the REST API.
# The password to unlock the private key used for securing the REST API.
# The size of the thread pool used exclusively for serving the REST API.
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
# The X.509 certificate chain file in PEM format to use for securing the web interface.
# The PKCS#8 private key file in PEM format to use for securing the web interface.
# The password to unlock the private key used for securing the web interface.
# The size of the thread pool used exclusively for serving the web interface.
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
# elasticsearch server).
# Default: 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
# Default: 1h
# Default: 20
# Default: 1h
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
# messages end up.
# MongoDB connection string
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
# Email transport
# Default: 5s
# Default: 10s
# Default: 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
I have followed these instructions
http://docs.graylog.org/en/2.4/pages/installation/os/ubuntu.html
PFA picture also
root@ip-10-0-100-130:/var/log/elasticsearch# echo ‘sourcehost message text’ | nc -v -u -w 0 10.0.100.206 5424
Connection to 10.0.100.206 5424 port [udp/*] succeeded!
ubuntu@ip-10-0-100-206:/etc$ echo ‘sourcehost message text’ | nc -v -u -w 0 10.0.100.130 5424
Connection to 10.0.100.130 5424 port [udp/*] succeeded!
10-0-100-130 ----> Graylog server
10-0-100-206 -----> Destination server
First off, it seems that you’re all over the place; please provide your problem in a structured manner. This will also help you get your head around the problem yourself. Right now it is very hard to make out what your actual problem is.
For example, you say:
  • You are not receiving any data.
  • That Graylog runs on .130.
  • That the destination server is .206. The desination for what?!
  • That you have a Syslog UDP receiver running on Graylog, port 5418.
  • That you can send data to port 5424 on various hosts through Netcat. Why port 5424?? Why send to port 5424 on .206??
Please draw yourself a diagram:
  • Which hosts are involved in this situation?
  • Which processes run on which hosts?
  • Which processes are communicating with which processes?
  • What ports and protocols are being used?
  • What inputs are you providing into the situation and what outputs or behaviour are you expecting to see?
  • Why do you think the behaviour you see is incorrect?
Treat the situation like a blackbox and try to figure out the details of how the blackbox works. Troubleshooting-101.
