[REQ] Need help to set dashnoard layout
HI,
Good morning everyone.
I need help changing the layout of my dashboard.
I don’t know if this option is possible
Is it possible to remove the bar highlighted in the red circle from my dashboards?
In version 4 of Graylog this did not exist, in version 5 it appeared
I would like to remove it because its presence takes away useful space
Thanks in any case
I’m partially to blame for this :slight_smile: Show Title of dashboard on page · Issue #13116 · Graylog2/graylog2-server · GitHub
Can you clarify what you are trying to accomplish? I just tested scrolling the dashboard page and am able to “hide” it that way.
scrolling down…
