Reconfiguring Indices in production
How to close active write index and reconfigure with new retention strategy.
Also, Can I get some reference documents on how to open close indices and make them available in Elastic search?
Graylog Version - Graylog v4.2.9+f0d8298
Configured on docker container
Hello @Raynu
Below each index set are these
Navigate to System/Indices, Click on "Edit " Button. Adjust the retention strategy. You may want to manually rotate the index.
Perhaps here
Thanks @gsmith
Just tested on Dev box.
Once the index is rotated and closed. you get an option to reopen that index.
Never thought it will be that easy.
:+1: Just an FYI, Graylog controls Elasticsearch/OpenSearch.
What does that mean? Sorry I am not an expert in this area.
Oh,
Meaning to can make adjustments with indices through Graylog Web UI. ELK stack you normally have to do curl commands to modify you indices.
Aah right, I find those commands tricky when I search on google because we have docker container and the configuration is slightly different. I am still struggling to find out how I can see actual indexes and data via command line. I my Indices directory in Elasticsearch there are no actual names of the indices as I see on UI.
Every day there is a new learning,
For Docker, depending on how you setup you Docker-compose.
I use the Docker container IP address, to find that IP Address, I use this command.
root # docker ps
root # docker inspect 5c3b42ba17d6 <--- Elasticsearch_container_id
Then use that ip address like so
curl -XGET http://172.17.0.3:9200/_cat/indices
Results
root@ansible:/usr/local/bin# curl -X GET http://172.17.0.3:9200/_cluster/health?pretty
  "cluster_name" : "docker-cluster",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 114,
  "active_shards" : 114,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
OR
root@ansible:/usr/local/bin# curl -X GET http://172.17.0.3:9200/_cat/indices?pretty
green open gl-failures_70     0-SMsbiWT6m6Q2grl9TIHQ 2 0       0 0    416b    416b
green open gl-failures_75     j5Y5f5erQ0iGX-h7dicIBg 2 0       0 0    416b    416b
green open gl-failures_73     wh6246BFQ4yux-chCC9Ymw 2 0       0 0    416b    416b
green open gl-failures_74     VhB-jShSTXC8dv4p7LMvGw 2 0       0 0    416b    416b
green open gl-failures_71     5EKaiLQXRLyvmy6O76Wz4Q 2 0       0 0    416b    416b
green open gl-failures_72     WxKsOTrKSWKGGoBtvWrGTw 2 0       0 0    416b    416b
green open graylog_36         CK1_UbhzReOX0dghZlV_7A 2 0  185797 0  41.3mb  41.3mb
green open graylog_35         cllJF1T3SwqW98yMqVk9WQ 2 0   48446 0  10.8mb  10.8mb
green open graylog_38         -JGlAUEwS9-A1aoOb0sh7w 2 0   68243 0    15mb    15mb
green open graylog_37         Rn18l_FnSn6FfceXrbOyOA 2 0   31678 0   7.4mb   7.4mb
green open graylog_39         KkZ9VZCCRbumKVCqppGznQ 2 0   25717 0   6.2mb   6.2mb
green open gl-failures_48     UghG8pQvRx6H-dw-Wm4rcg 2 0       0 0    416b    416b
green open gl-failures_49     q34y6mSxQECOvgnIorHWGA 2 0       0 0    416b    416b
green open gl-failures_46     BhgAbE2zSJqijClizpkiwA 2 0       0 0    416b    416b
green open gl-failures_47     BbA1C3OdRTWv23bTaI4kuQ 2 0       0 0    416b    416b
green open graylog_41         ozcGKVcXQee3GjNbWMgwiA 2 0   26166 0   6.2mb   6.2mb
green open graylog_40         mmypHdvLTQOk0M2HvJ5rqA 2 0   25717 0   6.1mb   6.1mb
green open graylog_43         KdJ_a7XQRcajre-Cc2We7w 2 0   26110 0   6.2mb   6.2mb
green open graylog_42         tABeMuBiQJCjgF2Txdq3EA 2 0   26550 0   6.4mb   6.4mb
green open graylog_45         AhwS4kmsSHSREgxONiWNKg 2 0   36629 0   8.6mb   8.6mb
green open graylog_44         APRfXxe7R5uPv-6_QvTHWw 2 0   26820 0   6.4mb   6.4mb
green open graylog_47         0Pid3PlaRlqhoPqbE9y7WQ 2 0   25629 0   6.1mb   6.1mb
green open graylog_46         Rua1xuHHSMyOQCKnpO6h3Q 2 0   25852 0   6.2mb   6.2mb
green open graylog_49         lec3ySJRS2-uYprQ4F1s8Q 2 0    4183 0   2.3mb   2.3mb
green open graylog_48         6fJCSHQxSSeIIs-6Ec5PZA 2 0   25607 0   6.1mb   6.1mb
green open gl-failures_55     icjSVuhaQUeeP5ElnR6Ttg 2 0       0 0    416b    416b
green open gl-failures_56     er1KZddsTmyhbbnNJkJ8nA 2 0       0 0    416b    416b
green open gl-failures_53     qKOL72pOSo6zTK_6dy-G7Q 2 0       0 0    416b    416b
green open gl-failures_54     ferZIwrhStGayYCUH7_R6w 2 0       0 0    416b    416b
green open gl-failures_51     KPEIeAVgQAiKu0MTo2HX4w 2 0       0 0    416b    416b
green open gl-failures_52     ju4Dh6apRJiFny-xfwX1Uw 2 0       0 0    416b    416b
green open gl-failures_50     A7mJlKcZSdCc7hZ7YJ0WEA 2 0       0 0    416b    416b
green open gl-failures_59     C6U_6QttRU6iHoYiDun5jw 2 0       0 0    416b    416b
green open gl-failures_57     eauYJr__RvKRHMeR18ok7Q 2 0       0 0    416b    416b
green open gl-failures_58     rB193zrQRACereNRZaV6JQ 2 0       0 0    416b    416b
green open gl-system-events_2 Gcj8pHI9SFOJ6gg5HBhZOg 4 0       0 0    832b    832b
green open gl-system-events_0 0VJyfJH-TiuB6HRVtekKIQ 4 0       0 0    832b    832b
green open gl-system-events_1 4SnH4ipSQqKUEhrbzkm4Sg 4 0       0 0    832b    832b
green open gl-failures_66     MBGd-MV2T7WCzmWy_J6MGA 2 0       0 0    416b    416b
green open gl-events_1        6_fhAYxfRw6Q7bgXGEnQww 4 0 7142329 0   1.1gb   1.1gb
green open gl-events_0        5I8vbJacT22BLtDtTyhlNA 4 0  869062 0 150.7mb 150.7mb
green open gl-failures_67     ryEXm_zfTMKg5XgQTmbt6A 2 0       0 0    416b    416b
green open gl-failures_64     NLPR-X2BSOOcjzVD4japjw 2 0       0 0    416b    416b
Wow, that’s great. You made my day. Thanks heaps for simple explanation and examples…
