Quick Fix - bypass expired Cert to view lidices on Opensearch
Sorry wasn’t sure what to tag here.
Currently I cannot view any of my logs once they have been passed to Opensearch. Ican open greylog UI and have not problem there.
‘ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Hostname <hostnamehere.redacted.com> not verified:’
We are running Greylog v4 with Opensearch v1.3
Yes it’s very old. We in the process of evaluating what is needed to upgrade everything. I don’t know much about how this is setup or configured.
All ever had to do is restart services to make sure it’s still gathering logs.
Everything still seems to be working I’ve just added a new Input and Stream this week via greylog.
I’ve been searching all over to a fix but i cannot find one.
I’ve tried setting
plugins.security.ssl.http.enabled to false in Opensearch but then my cluster will not start as it’s gets a cert error.
But I’m really lost and hoping there is an easy fix for this.
What i need to be able to do is bypass the Certificate I’m assuming so that greylog can view all the logs that have hit the Opensearch cluster?
Is there a way to put a insecure flag in the greylog .conf for the opensearch cluster?
e.g. put a --insecure in the host list to allow it to ignore the expired certificate
Hey @Jeffrey
To help you further can you show you configuration file? ensure you hide your personal information before posting.
Here is my server.conf
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = <redacted>
root_username = <redacted>
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = <redacted>
# Default is empty
root_email = <redacted>
# Default is UTC
root_timezone = Australia/Sydney
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# For AD Object dashboard
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 10.80.110.18:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://10.80.110.18:9000/
#### External Graylog URI
# Default: $http_publish_uri
http_external_uri = http://logger.<redacted>.com:9000/
# rest_listen_uri =
# web_listen_uri = http://192.168.0.3:9000
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# 2-node:
elasticsearch_hosts = https://admin:<redacted>@achilles.<redacted>.com:9200,https://admin:<redacted>@hector.<redacted>.com:9200
elasticsearch_discovery_default_scheme = https
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = close
elasticsearch_shards = 4
elasticsearch_replicas = 2
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
# allow_leading_wildcard_searches = false
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 8
outputbuffer_processors = 6
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# Journal size in bytes (default is 20MB)
journal_size = 209715200
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
message_journal_max_size = 14gb
message_journal_max_age = 196h
# disabled if not set.
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# mongodb_uri = mongodb://localhost/graylog
# '+'-signs in the username or password need to be replaced by '%2B'
mongodb_uri = mongodb://grayloguser:<redacted>@localhost:27017,log-mongodb1.<redacted>.com:27017,log-mongodb2.<redacted>.com:27017/graylog?replicaSet=rs0
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
transport_email_hostname = smtp
transport_email_port = 25
#transport_email_subject_prefix = [graylog]
transport_email_from_email = logging@<redacted>.com
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
Hey @Jeffrey,
It would be worth looking through the documentation on securing Opensearch. Generate some new certs, replace the old with these in server.conf and add those to the trust store of your Graylog nodes.
