Fresh Graylog 5.0 Install w/ OpenSearch; OpenSearch invariably fails after a few hours
I have a (relatively) fresh install of Graylog 5.0 w/ Opensearch in a Everything seems to be going quite well except that, invariably, my OpenSearch will fail. Sometimes its hours, sometimes its a day, but it will fail. The problem is, I am not familiar enough with OpenSearch to triage this (so bear with me) but I’ll do my best and apologize in advance for any omitted or extraneous information.
  • OS Information: LXC (Ubuntu 22.04), on a Debian Bookworm Host.
  • Package Version: Graylog 5.0.3+a82acb2
    /graylog/opensearch/config/opensearch.yml
# ======================== OpenSearch Configuration =========================
# NOTE: OpenSearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.opensearch.org
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: graylog
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: graylogopen
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /graylog/opensearch/data
# Path to log files:
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# OpenSearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 127.0.0.1
# Set a custom port for HTTP:
http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
discovery.type: single-node
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.seed_hosts: ["SERVERNAME01", "SERVERNAME02", "SERVERNAME03"]
# Bootstrap the cluster using an initial set of cluster-manager-eligible nodes:
#cluster.initial_cluster_manager_nodes: ["SERVERNAME01", "SERVERNAME02", "SERVERNAME03"]
# For more information, consult the discovery and cluster formation module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
/graylog/opensearch/config/jvm.options
## JVM configuration
## IMPORTANT: JVM heap size
## You should always set the min and max JVM heap
## size to the same value. For example, to set
## the heap to 4 GB, set:
## -Xms4g
## -Xmx4g
## See https://opensearch.org/docs/opensearch/install/important-settings/
## for more information
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms24g
-Xmx24g
## Expert settings
## All settings below this section are considered
## expert settings. Don't tamper with them unless
## you understand what you are doing
## GC configuration
8-10:-XX:+UseConcMarkSweepGC
8-10:-XX:CMSInitiatingOccupancyFraction=75
8-10:-XX:+UseCMSInitiatingOccupancyOnly
## G1GC Configuration
# NOTE: G1 GC is only supported on JDK version 10 or later
# to use G1GC, uncomment the next two lines and update the version on the
# following three lines to your version of the JDK
# 10:-XX:-UseConcMarkSweepGC
# 10:-XX:-UseCMSInitiatingOccupancyOnly
11-:-XX:+UseG1GC
11-:-XX:G1ReservePercent=25
11-:-XX:InitiatingHeapOccupancyPercent=30
## JVM temporary directory
-Djava.io.tmpdir=${OPENSEARCH_TMPDIR}
## heap dumps
# generate a heap dump when an allocation from the Java heap fails
# heap dumps are created in the working directory of the JVM
-XX:+HeapDumpOnOutOfMemoryError
# specify an alternative path for heap dumps; ensure the directory exists and
# has sufficient space
-XX:HeapDumpPath=data
# specify an alternative path for JVM fatal error logs
-XX:ErrorFile=logs/hs_err_pid%p.log
## JDK 8 GC logging
8:-XX:+PrintGCDetails
8:-XX:+PrintGCDateStamps
8:-XX:+PrintTenuringDistribution
8:-XX:+PrintGCApplicationStoppedTime
8:-Xloggc:logs/gc.log
8:-XX:+UseGCLogFileRotation
8:-XX:NumberOfGCLogFiles=32
8:-XX:GCLogFileSize=64m
# JDK 9+ GC logging
9-:-Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m
# Explicitly allow security manager (https://bugs.openjdk.java.net/browse/JDK-8270380)
18-:-Djava.security.manager=allow
/etc/default/graylog-server
  GNU nano 6.2        /etc/default/graylog-server        # Path to a custom java executable. By default the java executable of the
# bundled JVM is used.
#JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms24g -Xmx24g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow"
# Avoid endless loop with some TLSv1.3 implementations.
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true"
# Fix for log4j CVE-2021-44228
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true"
# Pass some extra args to graylog-server. (i.e. "-d" to enable debug mode)
GRAYLOG_SERVER_ARGS=""
# Program that will be used to wrap the graylog-server command. Useful to
# support programs like authbind.
GRAYLOG_COMMAND_WRAPPER=""
/etc/graylog/server/server.conf
# GRAYLOG CONFIGURATION FILE
# If you are running more than one instances of Graylog server you have to select one of these
# instances as leader. The leader will perform some periodical tasks that non-leaders won't perform.
is_leader = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# Default is UTC
root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 127.0.0.1:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
http_publish_uri = http://192.168.128.253
#### External Graylog URI
# Default: $http_publish_uri
http_external_uri = http://sub.domain.help/
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 64
# HTTPS settings
# If set to "true", Graylog will periodically investigate indices to figure out which fields are used in which streams.
# It will make field list in Graylog interface show only fields used in selected streams, but can decrease system performance,
# especially on systems with great number of streams and fields.
trusted_proxies = 127.0.0.1/32, 192.168.128.0/24
# requires authentication.
elasticsearch_hosts = http://192.168.128.253:9200
# Maximum number of attempts to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog will use multiple indices to store documents in. You can configure the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies, the default being "count":
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
#   - "time" interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time
# Provides a hard upper limit for the retention period of any index set at configuration time.
# This setting is used to validate the value a user chooses for the maximum number of retained indexes, when configuring
# an index set. However, it is only in effect, when a time-based rotation strategy is chosen.
# If a rotation strategy other than time-based is selected and/or no value is provided for this setting, no upper limit
# for index retention will be enforced. This is also the default.
# max_index_retention_period = P90d
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see https://docs.graylog.org/docs/index-model#index-set-configuration
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Optional upper bound on elasticsearch_max_time_per_index
# elasticsearch_max_write_index_age = 1d
elasticsearch_disable_version_check = true
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
allow_highlighting = false
# Default: 1h
# This value should be set lower than elasticsearch_max_total_connections_per_route, otherwise index optimization
# could deplete all the client connections to the search server and block new messages ingestion for prolonged
# periods of time.
# Default: 10
#elasticsearch_index_optimization_jobs = 10
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Time interval to trigger a full refresh of the index field types for all indexes. This will query ES for all indexes
# and populate any missing field type information to the database.
# Default: 5m
#index_field_type_periodical_full_refresh_interval = 5m
output_batch_size = 500
output_flush_interval = 2
processbuffer_processors = 5
outputbuffer_processors = 3
# The size of the thread pool in the output buffer processor.
# Default: 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Manually stopped inputs are no longer auto-restarted. To re-enable the previous behavior, set auto_restart_inputs to true.
#auto_restart_inputs = true
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# messages end up.
# Time in milliseconds after which a detected stale leader node is being rechecked on startup.
#stale_leader_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# Maximum number of attempts to connect to MongoDB on boot for the version probe.
# Default: 0, retry indefinitely until a connection can be established
#mongodb_version_probe_attempts = 5
# Email transport
redacted
server.conf continued
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of a native system stats collector (currently OSHI)
#disable_native_system_stats_collector = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
#proxied_requests_thread_pool_size = 64
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Configures the prefix used for graylog event indices
# Default: gl-events
#default_events_index_prefix = gl-events
# Configures the prefix used for graylog system event indices
# Default: gl-system-events
#default_system_events_index_prefix = gl-system-events
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = false
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
#content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols = TLSv1.2,TLSv1.3
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
# Do not perform any preflight checks when starting Graylog
# Default: false
#skip_preflight_checks = false
# Ignore any exceptions encountered when running migrations
# Use with caution - skipping failing migrations may result in an inconsistent DB state.
# Default: false
#ignore_migration_failures = false
Finally, logs:
examples of /var/log/graylog-server/server/log entries around the time of the failures:
2023-02-16T22:14:51.518Z ERROR [MessagesAdapterOS2] Failed to index [2] messages. Please check the index error log in your web interface for the reason. Error: failure in bulk execution:
[160]: index [graylog_0], id [52a17f21-ae47-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '52a17f21-ae47-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'GenericList']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "GenericList"]];]
[170]: index [graylog_0], id [52b79f30-ae47-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '52b79f30-ae47-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'GenericList']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "GenericList"]];]
2023-02-16T22:29:43.362Z WARN  [MaxmindDataAdapter] Unable to look up city data for IP address /70.241.37.1, returning empty result.
 Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #22).
2023-02-16T22:29:50.664Z ERROR [MessagesAdapterOS2] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: failure in bulk execution:
[253]: index [graylog_0], id [6a946871-ae49-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '6a946871-ae49-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'DocumentLibrary']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "DocumentLibrary"]];]
2023-02-16T22:29:52.126Z ERROR [MessagesAdapterOS2] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: failure in bulk execution:
[5]: index [graylog_0], id [6b0a82d0-ae49-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '6b0a82d0-ae49-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'DocumentLibrary']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "DocumentLibrary"]];]
2023-02-16T22:29:54.981Z ERROR [MessagesAdapterOS2] Failed to index [3] messages. Please check the index error log in your web interface for the reason. Error: failure in bulk execution:
[101]: index [graylog_0], id [69a01d60-ae49-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '69a01d60-ae49-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'DocumentLibrary']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "DocumentLibrary"]];]
[168]: index [graylog_0], id [6a1e4e10-ae49-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '6a1e4e10-ae49-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'DocumentLibrary']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "DocumentLibrary"]];]
[169]: index [graylog_0], id [6a215b51-ae49-11ed-aacf-00163ef2bcdd], message [OpenSearchException[OpenSearch exception [type=mapper_parsing_exception, reason=failed to parse field [ListBaseType] of type [long] in document with id '6a215b51-ae49-11ed-aacf-00163ef2bcdd'. Preview of field's value: 'DocumentLibrary']]; nested: OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=For input string: "DocumentLibrary"]];]
2023-02-16T22:44:46.660Z WARN  [MaxmindDataAdapter] Unable to look up city data for IP address /99.69.21.79, returning empty result.
java.lang.UnsupportedOperationException: Invalid attempt to open a GeoLite2-ASN database using the city method
2023-02-17T15:34:09.295Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #1).
2023-02-17T15:34:09.317Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #10).
2023-02-17T15:34:09.320Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #2).
2023-02-17T15:34:09.322Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #1).
2023-02-17T15:34:09.336Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #2).
2023-02-17T15:34:09.345Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #3).
2023-02-17T15:34:09.352Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #3).
2023-02-17T15:34:09.373Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #4).
2023-02-17T15:34:09.374Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #4).
2023-02-17T15:34:09.402Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #5).
2023-02-17T15:34:09.403Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #10).
2023-02-17T15:34:09.413Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #5).
2023-02-17T15:34:09.447Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #6).
2023-02-17T15:34:09.474Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #6).
2023-02-17T15:34:09.523Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #7).
2023-02-17T15:34:09.559Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #7).
2023-02-17T15:34:09.664Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #8).
2023-02-17T15:34:09.707Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #8).
at java.lang.Thread.run(Unknown Source) [?:?]
2023-02-17T15:34:09.932Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #9).
2023-02-17T15:34:09.985Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #9).
2023-02-17T15:34:10.343Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #11).
2023-02-17T15:34:10.450Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #11).
2023-02-17T15:34:10.451Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #10).
2023-02-17T15:34:10.508Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #10).
2023-02-17T15:34:11.490Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #11).
2023-02-17T15:34:11.553Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #11).
2023-02-17T15:34:12.394Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #12).
2023-02-17T15:34:12.532Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #12).
2023-02-17T15:34:13.550Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #12).
2023-02-17T15:34:13.621Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #12).
2023-02-17T15:34:16.492Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #13).
2023-02-17T15:34:16.659Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #13).
2023-02-17T15:34:17.666Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #13).
2023-02-17T15:34:17.751Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #13).
2023-02-17T15:34:21.627Z ERROR [ClusterAdapterOS2] An error occurred:  (Connection refused)
2023-02-17T15:34:21.627Z INFO  [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2023-02-17T15:34:21.644Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-02-17T15:34:21.644Z INFO  [VersionProbe] Elasticsearch is not available. Retry #1
2023-02-17T15:34:24.690Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #14).
2023-02-17T15:34:24.865Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #14).
2023-02-17T15:34:25.873Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #14).
2023-02-17T15:34:25.972Z ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=OpenSearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=[]}, retrying (attempt #14).
2023-02-17T15:34:26.645Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-02-17T15:34:26.646Z INFO  [VersionProbe] Elasticsearch is not available. Retry #2
2023-02-17T15:34:31.647Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-02-17T15:34:31.647Z INFO  [VersionProbe] Elasticsearch is not available. Retry #3
2023-02-17T15:34:36.648Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-02-19T03:00:43.613Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /172.0.0.1:9200. - Connection refused.
2023-02-19T03:00:43.613Z INFO  [VersionProbe] Elasticsearch is not available. Retry #178
/var/log/opensearch/graylog.log
[2023-02-19T00:03:52,047][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:08:55,034][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:13:55,037][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:18:55,040][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:23:55,042][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:28:55,044][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:33:55,047][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:38:55,050][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:43:55,052][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:48:55,056][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:53:55,058][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T00:58:50,331][INFO ][o.o.a.t.CronTransportAction] [graylogopen] Start running AD hourly cron.
[2023-02-19T00:58:50,337][INFO ][o.o.a.t.ADTaskManager    ] [graylogopen] Start to maintain running historical tasks
[2023-02-19T00:58:50,338][INFO ][o.o.a.c.HourlyCron       ] [graylogopen] Hourly maintenance succeeds
[2023-02-19T00:58:50,544][INFO ][o.o.i.i.IndexStateManagementHistory] [graylogopen] No Old History Indices to delete
[2023-02-19T00:58:55,063][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:03:55,064][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:08:55,067][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:13:55,069][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:18:55,073][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:23:55,075][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:28:55,078][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:33:55,080][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:38:55,083][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:43:55,094][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:48:55,100][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:53:55,107][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T01:58:50,332][INFO ][o.o.a.t.CronTransportAction] [graylogopen] Start running AD hourly cron.
[2023-02-19T01:58:50,336][INFO ][o.o.a.t.ADTaskManager    ] [graylogopen] Start to maintain running historical tasks
[2023-02-19T01:58:50,340][INFO ][o.o.a.c.HourlyCron       ] [graylogopen] Hourly maintenance succeeds
[2023-02-19T01:58:55,115][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:03:55,116][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:08:55,119][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:13:55,122][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:18:55,125][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:23:55,133][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:28:55,138][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:33:55,148][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:38:55,154][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T02:43:55,162][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T04:17:38,520][INFO ][o.o.n.Node               ] [graylogopen] version[2.0.1], pid[206], build[tar/6462a546240f6d7a158519499729bce12dc1058b/2022-06-15T08:47:42.243126494Z], OS[Linux/5.19.0-1-amd64/amd64], JVM[Eclipse Adoptium/OpenJDK 64-Bit Server VM/17.0.3/17.0.3+7]
[2023-02-19T04:17:38,523][INFO ][o.o.n.Node               ] [graylogopen] JVM home [/graylog/opensearch/jdk], using bundled JDK [true]
[2023-02-19T04:17:38,524][INFO ][o.o.n.Node               ] [graylogopen] JVM arguments [-Xshare:auto, -Dopensearch.networkaddress.cache.ttl=60, -Dopensearch.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.locale.providers=SPI,COMPAT, -Xms24g, -Xmx24g, -XX:+UseG1GC, -XX:G1ReservePercent=25, -XX:InitiatingHeapOccupancyPercent=30, -Djava.io.tmpdir=/tmp/opensearch-16420459775048320987, -XX:+HeapDumpOnOutOfMemoryError, -XX:HeapDumpPath=data, -XX:ErrorFile=logs/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -XX:MaxDirectMemorySize=12884901888, -Dopensearch.path.home=/graylog/opensearch, -Dopensearch.path.conf=/graylog/opensearch/config, -Dopensearch.distribution.type=tar, -Dopensearch.bundled_jdk=true]
[2023-02-19T04:17:40,709][WARN ][stderr                   ] [graylogopen] SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
[2023-02-19T04:17:40,710][WARN ][stderr                   ] [graylogopen] SLF4J: Defaulting to no-operation (NOP) logger implementation
[2023-02-19T04:17:40,710][WARN ][stderr                   ] [graylogopen] SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
[2023-02-19T04:17:40,721][INFO ][o.o.s.s.t.SSLConfig      ] [graylogopen] SSL dual mode is disabled
[2023-02-19T04:17:40,722][WARN ][o.o.s.OpenSearchSecurityPlugin] [graylogopen] OpenSearch Security plugin installed but disabled. This can expose your configuration (including passwords) to the public.
[2023-02-19T04:17:42,827][INFO ][o.o.p.c.PluginSettings   ] [graylogopen] Trying to create directory /dev/shm/performanceanalyzer/.
[2023-02-19T04:17:42,828][INFO ][o.o.p.c.PluginSettings   ] [graylogopen] Config: metricsLocation: /dev/shm/performanceanalyzer/, metricsDeletionInterval: 1, httpsEnabled: false, cleanup-metrics-db-files: true, batch-metrics-retention-period-minutes: 7, rpc-port: 9650, webservice-port 9600
[2023-02-19T04:17:43,762][INFO ][o.o.i.r.ReindexPlugin    ] [graylogopen] ReindexPlugin reloadSPI called
[2023-02-19T04:17:43,764][INFO ][o.o.i.r.ReindexPlugin    ] [graylogopen] Unable to find any implementation for RemoteReindexExtension
[2023-02-19T04:17:43,872][INFO ][o.o.j.JobSchedulerPlugin ] [graylogopen] Loaded scheduler extension: reports-scheduler, index: .opendistro-reports-definitions
[2023-02-19T04:17:43,877][INFO ][o.o.j.JobSchedulerPlugin ] [graylogopen] Loaded scheduler extension: opendistro_anomaly_detector, index: .opendistro-anomaly-detector-jobs
[2023-02-19T04:17:43,878][INFO ][o.o.j.JobSchedulerPlugin ] [graylogopen] Loaded scheduler extension: opendistro-index-management, index: .opendistro-ism-config
[2023-02-19T04:17:43,906][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [aggs-matrix-stats]
[2023-02-19T04:17:43,907][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [analysis-common]
[2023-02-19T04:17:43,907][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [geo]
[2023-02-19T04:17:43,907][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [ingest-common]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [ingest-geoip]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [ingest-user-agent]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [lang-expression]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [lang-mustache]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [lang-painless]
[2023-02-19T04:17:43,908][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [mapper-extras]
[2023-02-19T04:17:43,909][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [opensearch-dashboards]
[2023-02-19T04:17:43,909][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [parent-join]
[2023-02-19T04:17:43,909][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [percolator]
[2023-02-19T04:17:43,909][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [rank-eval]
[2023-02-19T04:17:43,909][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [reindex]
[2023-02-19T04:17:43,910][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [repository-url]
[2023-02-19T04:17:43,910][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded module [transport-netty4]
[2023-02-19T04:17:43,910][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-alerting]
[2023-02-19T04:17:43,911][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-anomaly-detection]
[2023-02-19T04:17:43,911][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-asynchronous-search]
[2023-02-19T04:17:43,911][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-cross-cluster-replication]
[2023-02-19T04:17:43,911][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-index-management]
[2023-02-19T04:17:43,911][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-job-scheduler]
[2023-02-19T04:17:43,912][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-knn]
[2023-02-19T04:17:43,912][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-ml]
[2023-02-19T04:17:43,912][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-notifications]
[2023-02-19T04:17:43,912][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-notifications-core]
[2023-02-19T04:17:43,912][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-observability]
[2023-02-19T04:17:43,913][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-performance-analyzer]
[2023-02-19T04:17:43,913][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-reports-scheduler]
[2023-02-19T04:17:43,913][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-security]
[2023-02-19T04:17:43,913][INFO ][o.o.p.PluginsService     ] [graylogopen] loaded plugin [opensearch-sql]
[2023-02-19T04:17:43,946][INFO ][o.o.e.NodeEnvironment    ] [graylogopen] using [1] data paths, mounts [[/ (Dauntless_zfs/containers/Graylog-Open)]], net usable_space [831.2gb], net total_space [852.4gb], types [zfs]
[2023-02-19T04:17:43,946][INFO ][o.o.e.NodeEnvironment    ] [graylogopen] heap size [24gb], compressed ordinary object pointers [true]
[2023-02-19T04:17:44,150][INFO ][o.o.n.Node               ] [graylogopen] node name [graylogopen], node ID [LtIiAaGeRY6dy9Q3bzhZrA], cluster name [graylog], roles [cluster_manager, remote_cluster_client, data, ingest]
[2023-02-19T04:17:47,396][INFO ][o.o.a.b.ADCircuitBreakerService] [graylogopen] Registered memory breaker.
[2023-02-19T04:17:47,713][INFO ][o.o.m.c.b.MLCircuitBreakerService] [graylogopen] Registered ML memory breaker.
[2023-02-19T04:17:48,125][INFO ][o.o.t.NettyAllocator     ] [graylogopen] creating NettyAllocator with the following configs: [name=opensearch_configured, chunk_size=1mb, suggested_max_allocation_size=1mb, factors={opensearch.unsafe.use_netty_default_chunk_and_page_size=false, g1gc_enabled=true, g1gc_region_size=16mb}]
[2023-02-19T04:17:48,176][INFO ][o.o.d.DiscoveryModule    ] [graylogopen] using discovery type [single-node] and seed hosts providers [settings]
[2023-02-19T04:17:48,478][WARN ][o.o.g.DanglingIndicesState] [graylogopen] gateway.auto_import_dangling_indices is disabled, dangling indices will not be automatically detected or imported and must be managed manually
[2023-02-19T04:17:48,773][INFO ][o.o.p.h.c.PerformanceAnalyzerConfigAction] [graylogopen] PerformanceAnalyzer Enabled: false
[2023-02-19T04:17:48,836][INFO ][o.o.n.Node               ] [graylogopen] initialized
[2023-02-19T04:17:48,836][INFO ][o.o.n.Node               ] [graylogopen] starting ...
[2023-02-19T04:17:48,961][INFO ][o.o.t.TransportService   ] [graylogopen] publish_address {192.168.128.253:9300}, bound_addresses {192.168.128.253:9300}
[2023-02-19T04:17:49,290][INFO ][o.o.c.c.Coordinator      ] [graylogopen] cluster UUID [ao2IvgcKTlOMX516DzIbfw]
[2023-02-19T04:17:49,444][INFO ][o.o.c.s.MasterService    ] [graylogopen] elected-as-cluster-manager ([1] nodes joined)[{graylogopen}{LtIiAaGeRY6dy9Q3bzhZrA}{bgWUisw6TE6cT05IB5sByQ}{192.168.128.253}{192.168.128.253:9300}{dimr}{shard_indexing_pressure_enabled=true} elect leader, _BECOME_MASTER_TASK_, _FINISH_ELECTION_], term: 27, version: 608, delta: cluster-manager node changed {previous [], current [{graylogopen}{LtIiAaGeRY6dy9Q3bzhZrA}{bgWUisw6TE6cT05IB5sByQ}{192.168.128.253}{192.168.128.253:9300}{dimr}{shard_indexing_pressure_enabled=true}]}
[2023-02-19T04:17:49,827][INFO ][o.o.c.s.ClusterApplierService] [graylogopen] cluster-manager node changed {previous [], current [{graylogopen}{LtIiAaGeRY6dy9Q3bzhZrA}{bgWUisw6TE6cT05IB5sByQ}{192.168.128.253}{192.168.128.253:9300}{dimr}{shard_indexing_pressure_enabled=true}]}, term: 27, version: 608, reason: Publication{term=27, version=608}
[2023-02-19T04:17:49,840][INFO ][o.o.a.c.ADClusterEventListener] [graylogopen] Cluster is not recovered yet.
[2023-02-19T04:17:49,849][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:17:49,889][INFO ][o.o.i.i.ManagedIndexCoordinator] [graylogopen] Cache cluster manager node onClusterManager time: 1676780269889
[2023-02-19T04:17:49,897][WARN ][o.o.p.c.s.h.ConfigOverridesClusterSettingHandler] [graylogopen] Config override setting update called with empty string. Ignoring.
[2023-02-19T04:17:49,936][INFO ][o.o.h.AbstractHttpServerTransport] [graylogopen] publish_address {192.168.128.253:9200}, bound_addresses {192.168.128.253:9200}
[2023-02-19T04:17:49,937][INFO ][o.o.n.Node               ] [graylogopen] started
[2023-02-19T04:17:49,937][INFO ][o.o.s.OpenSearchSecurityPlugin] [graylogopen] Node started
[2023-02-19T04:17:49,939][INFO ][o.o.s.OpenSearchSecurityPlugin] [graylogopen] 0 OpenSearch Security modules loaded so far: []
[2023-02-19T04:17:51,539][INFO ][o.o.c.s.ClusterSettings  ] [graylogopen] updating [plugins.index_state_management.template_migration.control] from [0] to [-1]
[2023-02-19T04:17:51,542][INFO ][o.o.a.c.HashRing         ] [graylogopen] Node added: [LtIiAaGeRY6dy9Q3bzhZrA]
[2023-02-19T04:17:51,545][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:17:51,547][INFO ][o.o.a.c.HashRing         ] [graylogopen] Add data node to AD version hash ring: LtIiAaGeRY6dy9Q3bzhZrA
[2023-02-19T04:17:51,552][INFO ][o.o.a.c.HashRing         ] [graylogopen] All nodes with known AD version: {LtIiAaGeRY6dy9Q3bzhZrA=ADNodeInfo{version=2.0.1, isEligibleDataNode=true}}
[2023-02-19T04:17:51,553][INFO ][o.o.a.c.HashRing         ] [graylogopen] Rebuild AD hash ring for realtime AD with cooldown, nodeChangeEvents size 0
[2023-02-19T04:17:51,553][INFO ][o.o.a.c.HashRing         ] [graylogopen] Build AD version hash ring successfully
[2023-02-19T04:17:51,555][INFO ][o.o.a.c.ADDataMigrator   ] [graylogopen] Start migrating AD data
[2023-02-19T04:17:51,556][INFO ][o.o.a.c.ADDataMigrator   ] [graylogopen] AD job index doesn't exist, no need to migrate
[2023-02-19T04:17:51,557][INFO ][o.o.a.c.ADClusterEventListener] [graylogopen] Init AD version hash ring successfully
[2023-02-19T04:17:51,569][INFO ][o.o.g.GatewayService     ] [graylogopen] recovered [5] indices into cluster_state
[2023-02-19T04:17:53,022][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:00,158][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:00,375][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:00,542][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:01,437][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:12,030][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:15,215][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:19,984][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:21,897][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:24,187][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:26,364][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:28,049][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:31,110][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:34,167][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:38,021][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:40,388][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:43,821][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:46,135][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:47,591][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:49,892][INFO ][o.o.i.i.ManagedIndexCoordinator] [graylogopen] Performing move cluster state metadata.
[2023-02-19T04:18:49,893][INFO ][o.o.i.i.MetadataService  ] [graylogopen] ISM config index not exist, so we cancel the metadata migration job.
[2023-02-19T04:18:50,247][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:18:54,576][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:19:02,663][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:19:03,818][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:19:49,892][INFO ][o.o.i.i.ManagedIndexCoordinator] [graylogopen] Cancel background move metadata process.
[2023-02-19T04:19:49,893][INFO ][o.o.i.i.ManagedIndexCoordinator] [graylogopen] Performing move cluster state metadata.
[2023-02-19T04:19:49,894][INFO ][o.o.i.i.MetadataService  ] [graylogopen] Move metadata has finished.
[2023-02-19T04:20:36,910][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:20:41,125][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:22:49,293][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T04:22:59,452][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:23:07,442][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:23:17,016][INFO ][o.o.c.r.a.AllocationService] [graylogopen] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_0][0]]]).
[2023-02-19T04:23:20,264][INFO ][o.o.a.u.d.DestinationMigrationCoordinator] [graylogopen] Detected cluster change event for destination migration
[2023-02-19T04:24:09,774][WARN ][o.o.c.InternalClusterInfoService] [graylogopen] Failed to update node information for ClusterInfoUpdateJob within 15s timeout
[2023-02-19T04:24:11,970][WARN ][o.o.t.TransportService   ] [graylogopen] Received response for a request that has timed out, sent [17207ms] ago, timed out [2201ms] ago, action [cluster:monitor/nodes/stats[n]], node [{graylogopen}{LtIiAaGeRY6dy9Q3bzhZrA}{bgWUisw6TE6cT05IB5sByQ}{192.168.128.253}{192.168.128.253:9300}{dimr}{shard_indexing_pressure_enabled=true}], id [3195]
[2023-02-19T04:27:49,295][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T04:32:49,296][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
[2023-02-19T04:37:49,297][INFO ][o.o.j.s.JobSweeper       ] [graylogopen] Running full sweep
Note: reference to 192.168.128.253 is the local private IP of the graylog server. I get the same results if I have it noted as 127.0.0.1 or 192.168.128.253
Several days of google-foo. Making changes to configs, increases index limits, etc.
Hopefully a solution?
Thank you for everything!
Woke up to this (only one widget failure, aggregate count)
However:
The data for these widgets is obtained via this community plugin:
I’m ripping my hair out
UPDATE
Its been about 24 hours since my last major change. I had set my /etc/default/graylog-server at half my available memory per the site instructions. Having avoided the issues I had been experiencing recently on an ElasticSearch-backed Graylog instance, before, with much less memory defined in the /etc/default/graylog-server, I backed it down to -Xms16g -Xmx16g on my current build. So far so good.
Hey @accidentaladmin
Only thing I see is strange from your configuration is this.
Your opensearch.yml
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 127.0.0.1
Graylog config
elasticsearch_hosts = http://192.168.128.253:9200
Then you have…
# Default: 127.0.0.1:9000
http_bind_address = 127.0.0.1:9000
With
http_publish_uri = http://192.168.128.253
Suggestions, If you want to user you local IP Address then this should work.
OpenSearch.yml
[root@graylog graylog-server]# cat /etc/opensearch/opensearch.yml  | egrep -v "^\s*(#|$)"
cluster.name: graylog
path.data: /var/lib/opensearch
network.host: 192.168.128.253
http.port: 9200
discovery.type: single-node
bootstrap.memory_lock: true
plugins.security.system_indices.enabled: false
graylog config settings
[root@graylog graylog-server]# cat /etc/graylog/server/server.conf  | egrep -v "^\s*(#|$)"
is_leader = true
password_secret = Holy Secrets Batman!
root_password_sha2 = yes, robin.  Secrets.
root_email = "greg.smith@domain.com"
Next, shutdown Graylog-server service and restart Openseach. Once you see Opensearch is in green.
curl -X GET 192.168.128.253:9200/_cluster/health?pretty
should look something like this
  "cluster_name" : "graylog",
  "status" : "green", <--------GREEN
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "discovered_master" : true,
  "active_primary_shards" : 408,
  "active_shards" : 408,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
Now start up Graylog-server service.
Im not sure about your Proxy setting. but what I suggested should work without using this setting/s
trusted_proxies = 127.0.0.1/32, 192.168.128.0/24
Thank you, I appreciate the response! Unfortunately what you note is because of my own slopiness in pasting. When I had attempted 127.0.0.1, it was 127.0.0.1 across the board. When I attempted 192.168.128.253, it was 192.168.128.253; it was never mixed in matched (except in the confusing trail of evidence I left here on the site).
I did try something new that seems to be working, though:
Unless you using 127.0.0.1 bind address to logon Graylog Web UI, those other setting seem to be to many configurations that is not needed. Simple is good.
History repeats itsself, :laughing: if you have it working , awesome :+1:
For sure! Problem is, I’ve picked up a lot of “rubber-chicken” ceremony from my first go at Graylog that its hard to separate what actually fixed a problem with what coincided - quite accidentally - with a fix.
I’m hoping the 24 > 16 is not one of those rubber-chicken moments! haha
As always, thank you for your assistance!
