Ok I finally figured out why GL wasn’t able to communicate with OS, in the installation doc it says under “Graylog Configuration for OpenSearch” to set “network.host:” to “${HOSTNAME}”, only now I figured out to write the actual localhost IP instead of a system variable, however, GL is still not able to start fully with the following log
2022-12-10T10:24:56.554Z ERROR [ServerBootstrap] Exception while running migrations
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: Couldn't read cluster state for reopened indices [graylog_*]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:155) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:112) ~[?:?]
at org.graylog.storage.elasticsearch7.PlainJsonApi.perform(PlainJsonApi.java:38) ~[?:?]
at org.graylog.storage.elasticsearch7.migrations.V20170607164210_MigrateReopenedIndicesToAliasesClusterStateES7.getForIndices(V20170607164210_MigrateReopenedIndicesToAliasesClusterStateES7.java:37) ~[?:?]
at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:89) ~[graylog.jar:?]
at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:137) ~[graylog.jar:?]
at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.lambda$upgrade$0(V20170607164210_MigrateReopenedIndicesToAliases.java:81) ~[graylog.jar:?]
at java.util.stream.ReferencePipeline$7$1.accept(Unknown Source) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source) ~[?:?]
at java.util.Collections$2.tryAdvance(Unknown Source) ~[?:?]
at java.util.Collections$2.forEachRemaining(Unknown Source) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(Unknown Source) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(Unknown Source) ~[?:?]
at java.util.stream.ReferencePipeline.forEach(Unknown Source) ~[?:?]
at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.upgrade(V20170607164210_MigrateReopenedIndicesToAliases.java:83) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.lambda$runMigrations$0(ServerBootstrap.java:308) ~[graylog.jar:?]
at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422) ~[graylog.jar:?]
at com.google.common.collect.RegularImmutableSortedSet.forEach(RegularImmutableSortedSet.java:88) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.runMigrations(ServerBootstrap.java:305) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:231) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:324) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:260) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
Caused by: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [GET], host [http://127.0.0.1:9200], URI [/_cluster/state/metadata/graylog_*], status line [HTTP/1.1 503 Service Unavailable]
{"error":{"root_cause":[{"type":"master_not_discovered_exception","reason":null}],"type":"master_not_discovered_exception","reason":null},"status":503}
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.convertResponse(RestClient.java:302) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:272) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
at org.graylog.storage.elasticsearch7.PlainJsonApi.lambda$perform$0(PlainJsonApi.java:40) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:110) ~[?:?]
... 24 more
2022-12-10T10:25:08.128Z INFO [ImmutableFeatureFlagsCollector] Following feature flags are used: {default properties file=[scripting_api_preview=off, search_filter=on]}
2022-12-10T10:25:08.711Z INFO [CmdLineTool] Loaded plugin: AWS plugins 5.0.0 [org.graylog.aws.AWSPlugin]
2022-12-10T10:25:08.713Z INFO [CmdLineTool] Loaded plugin: Integrations 5.0.0 [org.graylog.integrations.IntegrationsPlugin]
2022-12-10T10:25:08.713Z INFO [CmdLineTool] Loaded plugin: Collector 5.0.0 [org.graylog.plugins.collector.CollectorPlugin]
2022-12-10T10:25:08.714Z INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 5.0.0 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-12-10T10:25:08.714Z INFO [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 5.0.0+37301e5 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-12-10T10:25:08.715Z INFO [CmdLineTool] Loaded plugin: OpenSearch 2 Support 5.0.0+37301e5 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
2022-12-10T10:25:08.735Z INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2022-12-10T10:25:08.892Z INFO [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.4.0-135-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@1cec219f]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-10T10:25:08.895Z INFO [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.4.0-135-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@1cec219f]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-10T10:25:08.905Z INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-10T10:25:08.913Z INFO [connection] Opened connection [connectionId{localValue:2, serverValue:31}] to localhost:27017
2022-12-10T10:25:08.916Z INFO [connection] Opened connection [connectionId{localValue:1, serverValue:32}] to localhost:27017
2022-12-10T10:25:08.917Z INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=13, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=20981674}
2022-12-10T10:25:08.940Z INFO [connection] Opened connection [connectionId{localValue:3, serverValue:33}] to localhost:27017
2022-12-10T10:25:08.973Z INFO [MongoDBPreflightCheck] Connected to MongoDB version 5.0.14
2022-12-10T10:25:09.575Z INFO [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <OpenSearch:2.0.1>
2022-12-10T10:25:09.692Z INFO [Version] HV000001: Hibernate Validator null
2022-12-10T10:25:11.699Z INFO [InputBufferImpl] Message journal is enabled.
2022-12-10T10:25:11.711Z INFO [NodeId] Node ID: c9911438-4881-44c8-b003-9ad4ea1c9cda
2022-12-10T10:25:11.835Z INFO [LogManager] Loading logs.
2022-12-10T10:25:11.850Z WARN [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index...
2022-12-10T10:25:11.868Z INFO [LogManager] Logs loading complete.
2022-12-10T10:25:11.870Z INFO [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-12-10T10:25:11.876Z INFO [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.4.0-135-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@1cec219f]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-10T10:25:11.877Z INFO [connection] Opened connection [connectionId{localValue:4, serverValue:34}] to localhost:27017
2022-12-10T10:25:11.877Z INFO [connection] Opened connection [connectionId{localValue:5, serverValue:35}] to localhost:27017
2022-12-10T10:25:11.877Z INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=13, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1429933}
2022-12-10T10:25:11.878Z INFO [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.4.0-135-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@1cec219f]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-10T10:25:11.886Z INFO [connection] Opened connection [connectionId{localValue:6, serverValue:36}] to localhost:27017
2022-12-10T10:25:11.987Z INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-12-10T10:25:12.232Z INFO [ElasticsearchVersionProvider] Elasticsearch version set to Elasticsearch:7.0.0 - disabling version probe.
2022-12-10T10:25:12.779Z INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-12-10T10:25:12.863Z INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-12-10T10:25:12.869Z INFO [connection] Opened connection [connectionId{localValue:8, serverValue:37}] to localhost:27017
2022-12-10T10:25:12.890Z INFO [connection] Opened connection [connectionId{localValue:10, serverValue:38}] to localhost:27017
2022-12-10T10:25:12.912Z INFO [connection] Opened connection [connectionId{localValue:11, serverValue:39}] to localhost:27017
2022-12-10T10:25:12.929Z INFO [connection] Opened connection [connectionId{localValue:12, serverValue:40}] to localhost:27017
2022-12-10T10:25:13.003Z INFO [connection] Opened connection [connectionId{localValue:14, serverValue:41}] to localhost:27017
2022-12-10T10:25:13.761Z INFO [ServerBootstrap] Graylog server 5.0.0+37301e5 starting up
2022-12-10T10:25:13.762Z INFO [ServerBootstrap] JRE: Eclipse Adoptium 17.0.5 on Linux 5.4.0-135-generic
2022-12-10T10:25:13.762Z INFO [ServerBootstrap] Deployment: deb
2022-12-10T10:25:13.762Z INFO [ServerBootstrap] OS: Ubuntu 20.04.4 LTS (focal)
2022-12-10T10:25:13.765Z INFO [ServerBootstrap] Arch: amd64
2022-12-10T10:25:13.961Z INFO [ServerBootstrap] Running 49 migrations...
2022-12-10T10:25:44.483Z ERROR [ServerBootstrap] Exception while running migrations
