Hello, I have a problem with running graylog open. I’m reaching a moment like in the screenshot. If I omit the node configuration, after waiting several minutes the graylog login window does not appear. What could be the reason…
Good afternoon @Kacper123
Are you using the Graylog Data Node or Opensearch, to me this appears as though you are using Data Node but are yet to actually install it.
