Graylog stuck at "We are preparing Graylog for you..."
After i increased the size of the ubuntu Server 22.04. harddrive i cannot log into graylog anymore, its stuck at this screen:
I already restarted all services and i also rebooted the server with no luck.
Anybody know what could be the issue?
hey @Zandah
Take a look at you Graylog logs and or OpenSearch/Mongo see if you can find anything in there that can help.
Those are the graylog and MongoDB logs i can find, i can´t seem to find a log file for elasticsearch, the service is running though
hey @Zandah
I noticed in the logs your using ES 7.17.x?
I think you may have a configuration issue. If you could show your ES configuration file and make sure you hide private stuff.
Thats my config
hey @Zandah I see it default settings , have you seen this from Graylog Documentation here
Hey @Zandah,
I’m going to be a killjoy here, the last supported version of ES is 7.10.2.
Is this a single node setup and could you please post more of the Graylog log file, preferably from the point of a restart of the service.
