SAB
March 20, 2024, 1:52pm
1
Hey Community
i have and issue and i wanna a help please,
i already install Graylog server and MongoDB and Nginix service on the same VM
and elasticSearch/ OpenSearch on another VM, the two VM’s are on the same Vlan,
the problem is that i can’t see the port 9000
but it is okay with others port 9200 27017
and pealse note that all services are UP
son anyone can help me ? thanks
Graylog version: 5.2
ElasticSearch: 7.17
MongoDB: 6.0.14
OS: Debian 11
David_W
(David Warner)
March 21, 2024, 12:42am
2
For a start that version of ES will be a problem with Graylog. If I was you I’d redo your ES server with OS from scratch and review the supported versions carefully.
SAB
March 25, 2024, 10:49am
3
After installing 7.10.2 version, i get this message,
http://X.X.X.X:9200 port 9200 after 0 ms: Couldn’t connect to server
But when i type http://localhost :9200 it is connected
@SAB would you mind posting your Elastic config and your Graylog server.conf (/etct/graylog/server/server.conf).
Also if you are still at the setup stage it would be a good idea to use Opensearch over Elasticsearch.
SAB
March 25, 2024, 2:29pm
5
Yes i still at the setup stage, i need to install ElasticSearch then i upgrade to OpenSearch ?
If you have not yet ingested data then you can start on Opensearch 2.11 with no need to upgrade from Elastic.
David_W
(David Warner)
March 25, 2024, 9:10pm
7
I agree, ES support with Graylog is essentially EOL. IF you a building a new setup go OS.
Hey @SAB ,
Would you please post your Graylog server.conf (/etc/graylog/server/server.conf) and the Opensearch config (/etc/opensearch/opensearch.yml).
Is this message "Failed to connect to localhost port 9200 " from the opensearch log?
