Percentage value display
I have fields where I want to see the percentage of each value. I can do this with a pie chart, but that only shows me the specific moment.
How can I display the percentages of a field through a bar chart?
On a related note, are there any good resources giving examples of how to achieve different results with each type of widget? I’ve found a few blog posts but none of them really go in depth on the different types, options, and suggestions for configurations.
On your first part, percentages are coming in 5.2 which will drop any day.
On the second part, i dont really know of a central resource of widget examples.
