Hi
I am having a little trouble understanding how the parsing of JSON format works, when using filebeat as a collector. I have gone through a few forum posts and docs and can’t seem to get things looking right.
Currently the format of the string more or less looks like this:
{"timestamp":"2024-11-13T07:32:51.065840Z","level":"DEBUG","fields":{"message":"🔚 Dropping engine manager"},"filename":"modules/machine_vision/crates/machine_learning/src/engines/yolo.rs"}
There are also a logs where there are a few more keys within fields, but this is the most basic format.
I have done a lot of playing around with the filebeat config, and it currently looks like this:
# Needed for Graylog
fields_under_root: true
output.logstash:
hosts: ["${user.graylog_host}:5044"]
path:
data: ${sidecar.spoolDir!"/var/lib/graylog-sidecar/collectors/filebeat"}/data
logs: ${sidecar.spoolDir!"/var/lib/graylog-sidecar/collectors/filebeat"}/log
filebeat.inputs:
- type: filestream
paths:
- /home/**/logs/**/
parsers:
- ndjson:
target: ""
add_error_key: true
overwrite_keys: true
json.keys_under_root: true
json.add_error_key: true
json.message_key: fields.message
json.overwrite_keys: true
processors:
- decode_json_fields:
fields: ["timestamp", "fields", "filename", "level"]
process_array: false
max_depth: 2
target: ""
add_error_key: true
close_inactive: 5m
scan_frequency: 10s
The files are saved as system files and not with the .json extension.
And the outputted fields I get looks like this:
The things I am trying to fix:
- The timestamp is coming from the time in which the log is being read, and not coming from the log itself, and I want to be able to replace it
- I am trying to replace the ‘message’ field with the ‘field_message’ field.
- When there are more fields within the “fields” key, then I want them to be disectted as there key only, not having field as a prefix. Eg: plugin field lives within “fields” and is displayed as “fields_plugin” not just plugin (This one I have to fix with pipelines, so the first two are the most important)
- I am trying to have this constantly import new logs as new lines are added to the file, to avoid repeated information
Any help in the right direction would be amazing
