Filebeat json formatted messages being indexed with 'null' message body
Graylog seems to be eating incoming messages from filebeat agents when the messages are formatted as json.
Here’s an example message that I extracted from the Graylog journal, so I know that filebeat is sending something sane:
  "@timestamp":"2018-03-14T15:27:15.620Z",
  "@metadata":
  {"beat":"filebeat",
   "type":"doc",
   "version":"6.2.0"
  "source":"/var/log/containers/nginx-ingress-controller-4t8tj_default_nginx-ingress-lb-55e1711059a4e25263dc776efa6e6b196bfe48b36358ee03c2b42d0bee9d3f0c.log",
  "offset":4544121886,
  "message":"{\"log\":\"<snip> - [<snip>] - - [14/Mar/2018:15:27:15 +0000] \\\"GET <snip> HTTP/1.1\\\" 301 194 \\\"-\\\" \\\"-\\\" 205 0.002 [<snip>] 10.86.103.88:80 194 0.002 301\\n\",\"stream\":\"stdout\",\"time\":\"2018-03-14T15:27:15.578592705Z\"}",
  "type":"kube-logs",
  "beat":
  {"version":"6.2.0",
   "name":"kubernetes-worker/0",
   "hostname":"kubernetes-worker-0"
When I look at the message in Graylog, the message field is ‘null’. All other fields look normal.
My filebeat.yml prospectors & overall config looks like this:
filebeat:
  prospectors:
      paths:
        - /var/log/*.log
        - /var/log/syslog
        - /var/log/*/*.log
      input_type: log
      exclude_files: [".gz$"]
      exclude_lines: []
      scan_frequency: 10s
      harvester_buffer_size: 16384
      max_bytes: 10485760
      paths:
        - /var/log/containers/*.log
      exclude_files: ["filebeat.*log", "kube.*log"]
      scan_frequency: 10s
      max_bytes: 10485760
      fields_under_root: true
      symlinks: true
      json.message_key: log
      json.keys_under_root: true
      json.add_error_key: true
      multiline.pattern: '^\s'
      multiline.match: after
      fields:
        type: kube-logs
 registry_file: /var/lib/filebeat/registry
logging:
  to_syslog: true
  metrics.enabled: false
output:
  logstash:
    hosts:
      - "<snip>:5044"
    worker: 1
    compression_level: 3
    loadbalance: true
If I turn off all the json.* options in the prospector, then I see the json message, formatted as a quoted string.
Graylog version is 2.3.1+9f2c6ef on Ubuntu 16.04. I’m happy to share any more details that might be relevant.
What’s in the logs of your Graylog nodes?
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
Not much, though I don’t have debug logging on:
2018-03-14T11:32:10.454Z INFO  [MongoIndexSet] Cycling from <graylog_49> to <graylog_50>.
2018-03-14T11:32:10.454Z INFO  [MongoIndexSet] Creating target index <graylog_50>.
2018-03-14T11:32:10.509Z INFO  [Indices] Successfully created index template graylog-internal
2018-03-14T11:32:10.653Z INFO  [MongoIndexSet] Waiting for allocation of index <graylog_50>.
2018-03-14T11:32:10.753Z INFO  [MongoIndexSet] Index <graylog_50> has been successfully allocated.
2018-03-14T11:32:10.754Z INFO  [MongoIndexSet] Pointing index alias <graylog_deflector> to new index <graylog_50>.
2018-03-14T11:32:10.777Z INFO  [SystemJobManager] Submitted SystemJob <55bdc180-277b-11e8-b3f6-42fa67b8e8eb> [org.graylog2.indexer.indices.jobs.SetIndexReadOnlyAndCalculateRangeJob]
2018-03-14T11:32:10.777Z INFO  [MongoIndexSet] Successfully pointed index alias <graylog_deflector> to index <graylog_50>.
2018-03-14T11:32:30.459Z INFO  [AbstractIndexCountBasedRetentionStrategy] Number of indices (8) higher than limit (7). Running retention for 1 indices.
2018-03-14T11:32:30.493Z INFO  [AbstractIndexCountBasedRetentionStrategy] Running retention strategy [org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy] for index <graylog_43>
2018-03-14T11:32:30.721Z INFO  [DeletionRetentionStrategy] Finished index retention strategy [delete] for index <graylog_43> in 227ms.
2018-03-14T11:32:40.807Z INFO  [SetIndexReadOnlyJob] Flushing old index <graylog_49>.
2018-03-14T11:32:41.300Z INFO  [SetIndexReadOnlyJob] Setting old index <graylog_49> to read-only.
2018-03-14T11:32:41.327Z INFO  [SystemJobManager] Submitted SystemJob <67f377f0-277b-11e8-b3f6-42fa67b8e8eb> [org.graylog2.indexer.indices.jobs.OptimizeIndexJob]
2018-03-14T11:32:41.333Z INFO  [CreateNewSingleIndexRangeJob] Calculating ranges for index graylog_49.
2018-03-14T11:32:41.334Z INFO  [OptimizeIndexJob] Optimizing index <graylog_49>.
2018-03-14T11:32:42.747Z INFO  [MongoIndexRangeService] Calculated range of [graylog_49] in [1411ms].
2018-03-14T11:32:42.749Z INFO  [CreateNewSingleIndexRangeJob] Created ranges for index graylog_49.
2018-03-14T11:32:42.749Z INFO  [SystemJobManager] SystemJob <55bdc180-277b-11e8-b3f6-42fa67b8e8eb> [org.graylog2.indexer.indices.jobs.SetIndexReadOnlyAndCalculateRangeJob] finished in 1972ms.
2018-03-14T11:36:47.331Z INFO  [SystemJobManager] SystemJob <67f377f0-277b-11e8-b3f6-42fa67b8e8eb> [org.graylog2.indexer.indices.jobs.OptimizeIndexJob] finished in 246003ms.
I tried an upgrade to the latest 2.4.3 and the same issue happens there.
I’ll file a bug on github to track this.
I filed a bug over in https://github.com/Graylog2/graylog2-server/issues/4667 to track this.
The issue I filed is in https://github.com/Graylog2/graylog2-server/issues/4667 - but as @jochen pointed out, it isn’t a Graylog issue.
