I have recently upgrade my server to 3.0.2 version.
I want to migrate collector side configuration. I have already a collector with 0.1.8.
But i don’t have the option on the GUI !
Can you help me ?
Thanks !
How did you install Graylog? Did you removed any default plugins?
I have already in 2.5 with elasticsearch 6.X before upgrade.
I have update my repository source for update graylog. I have also replace the settings in server.conf
http://docs.graylog.org/en/3.0/pages/upgrade/graylog-3.0.html
For the plugins, i have move directory /usr/share/graylog-server/plugin to /usr/share/graylog-server/plugin-old.
After the upgrade entreprise plugin, the directory plugin is created.
You have any idea ?
Thanks you!
