Migrate from collector (v2) to sidecar (v3)
How have people dealt with transitioning from the collector-sidecar (particularly using tags to gather other logs) and rolling out the new sidecar?
It doesn’t look like there’s any local configuration you can make with the sidecar for it to start collecting when it starts the first time. Can I pre-create the sidecars in the Graylog API? or have I just over-looked a depressingly obvious solution here?
if you run the old sidecar in version 0.1.8 you are able to collect the written configuration for migration to version 1.0 - the documenation covered that.
