got messages ware be messy code,when i try to collect log from /var/log/httpd/access_log (apache access log) by collector_sidecar.
i don’t know why…how can i resolve it?
Which log shipper are you using, NXLOG or Filebeat?
How did you configure the Graylog Collector Sidecar?
How did you configure the log shipper (i. e. what’s the generated configuration)?
Which locale are you using on the system with the Apache httpd access logs?
Thank you for replay…
NGLOG
the configure of Collector Sidecar as below:
server_url: http://192.168.2.9:12900
update_interval: 10
tls_skip_verify: false
send_status: true
list_log_files:
- /var/log/httpd/
node_id: IAMANODE
collector_id: file:/etc/graylog/collector-sidecar/collector-id
cache_path: /var/cache/graylog/collector-sidecar
log_path: /var/log/graylog/collector-sidecar
log_rotation_time: 86400
log_max_age: 604800
tags:
- linux
- apache
backends:
- name: nxlog
enabled: true
binary_path: /usr/bin/nxlog
configuration_path: /etc/nxlog.conf
i don’t know what’s the mean of log shipper , means INPUTS?
if INPUTS,i defined it like below:
collector-sidecar OS:CentOS7.1
[root@cmdb ~]# locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
access_log is us-ascii, as below
[root@cmdb ~]# file -i /var/log/httpd/access_log
/var/log/httpd/access_log: text/plain; charset=us-ascii
and this is my snippet config:
{{if .Linux}}
User nxlog
Group nxlog
{{if eq .LinuxPlatform "debian"}}
Moduledir /usr/lib/nxlog/modules
CacheDir /var/spool/collector-sidecar/nxlog
PidFile /var/run/graylog/collector-sidecar/nxlog.pid
{{end}}
{{if eq .LinuxPlatform "redhat"}}
Moduledir /usr/libexec/nxlog/modules
{{end}}
define LOGFILE /var/log/graylog/collector-sidecar/nxlog.log
LogFile %LOGFILE%
LogLevel INFO
<Extension logrotate>
Module xm_fileop
<Schedule>
When @daily
Exec file_cycle('%LOGFILE%', 7);
</Schedule>
</Extension>
<Extension charconv>
Module xm_charconv
AutodetectCharsets AUTO,utf-8
</Extension>
{{end}}
{{if .Windows}}
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
LogFile %ROOT%\data\nxlog.log
LogLevel INFO
Module xm_fileop
<Schedule>
When @daily
Exec file_cycle('%ROOT%\data\nxlog.log', 7);
</Schedule>
</Extension>
{{end}}
also added verbatim configuration in the end of INPUT:
Exec convert_fields("AUTO", "utf-8");
Please post the contents of /etc/nxlog.conf.
below is my nxlog.conf:
define ROOT /usr/bin
<Extension gelf>
Module xm_gelf
</Extension>
<Processor 5940a8982e88b604b73f72fb-buffer>
Module pm_buffer
MaxSize 16384
Type Mem
</Processor>
User nxlog
Group nxlog
LogFile %LOGFILE%
LogLevel INFO
Module xm_fileop
<Schedule>
When @daily
</Schedule>
</Extension>
Module xm_charconv
</Extension>
<Input 5940a8982e88b604b73f72fb>
Module im_file
File '/var/log/cmdbd.log'
PollInterval 1
SavePos True
ReadFromLast True
Recursive True
RenameCheck False
Exec $FileName = file_name(); # Send file name with each message
</Input>
<Output 593fb8bf2e88b6055d1b5de6>
Module om_udp
Host 192.168.2.9
Port 1514
OutputType GELF
Exec $short_message = $raw_event; # Avoids truncation of the short_message field.
Exec $gl2_source_collector = 'aa44b4ff-7f75-4c89-96e1-7cedd6a40945';
Exec $collector_node_id = 'IAMANODE';
</Output>
<Route route-0>
Path 5940a8982e88b604b73f72fb => 5940a8982e88b604b73f72fb-buffer => 593fb8bf2e88b6055d1b5de6
</Route>
<Extension gelf>
Module xm_gelf
</Extension>
Module pm_buffer
MaxSize 16384
Type Mem
</Processor>
User nxlog
Group nxlog
LogFile %LOGFILE%
LogLevel INFO
Module xm_fileop
<Schedule>
When @daily
</Schedule>
</Extension>
Module xm_charconv
</Extension>
Module im_file
PollInterval 1
SavePos True
ReadFromLast True
Recursive True
RenameCheck False
</Input>
Module om_udp
Host 192.168.2.9
Port 1514
OutputType GELF
</Output>
<Route route-0>
</Route>
this issue has been resolved.
reason is collector_sidecar output into the wrong INPUT format(syslog type).
create a new type INPUT(GELF) and change collector_sidecar output to the new INPUT,everything is OK!
