Hi team
I have installed graylog-server in one of my linux machine and have configured successfully according to the configuration doc shared in http://docs.graylog.org/en/2.2/pages/installation/os/centos.html. Now i am trying to fetch custom log from application server which is deployed in linux. I have used nxlog(2.9.1716) and collector-sidecar(0.1.1) for fetching and to store it on graylog2 server. I can able to see my application server in graylog2 dashboard, but getting error like
**level=info msg="[RequestConfiguration] No configuration found for configured tags!" **
I have configured my application machine details graylog2 in collector tags.
Can anyone suggest for proceeding further, expecting your valuable, below is my nxlog and collector-sidecar configurations and the tag i have provided in graylog web is apache, tried with linux too…!
## This is a sample configuration file. See the nxlog reference manual about the
## configuration options. It should be installed locally under
## /usr/share/doc/nxlog-ce/ and is also available online at
## http://nxlog.org/docs
# Global directives #
User nxlog
Group nxlog
LogFile /var/log/nxlog/nxlog.log
LogLevel INFO
# Modules #
<Extension _syslog>
Module xm_syslog
</Extension>
<Input in1>
Module im_udp
Port 514
Exec parse_syslog_bsd();
</Input>
<Input in2>
Module im_tcp
Port 514
</Input>
<Output fileout1>
Module om_file
File "/var/log/logmsg.txt"
Exec if $Message =~ /error/ $SeverityValue = syslog_severity_value("error");
Exec to_syslog_bsd();
</Output>
<Output fileout2>
Module om_file
File "/var/log/logmsg2.txt"
</Output>
# Routes #
<Route 1>
Path in1 => fileout1
</Route>
<Route tcproute>
Path in2 => fileout2
</Route>
server_url: http://{GCP IP}:12900/api/
update_interval: 10
tls_skip_verify: false
send_status: true
list_log_files:
- /var/log/e2liveengine/
node_id: graylog-collector-sidecar
collector_id: file:/etc/graylog/collector-sidecar/collector-id
cache_path: /var/cache/graylog/collector-sidecar
log_path: /var/log/graylog/collector-sidecar/
log_rotation_time: 86400
log_max_age: 604800
tags:
- linux
- apache
backends:
- name: nxlog
enabled: true
binary_path: /usr/bin/nxlog
configuration_path: /etc/nxlog.conf
- name: filebeat
enabled: false
binary_path: /usr/bin/filebeat
configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
