Status: No configuration found for configured tags!
anyone have any idea about this error??
Status : No configuration found for configured tags!
you missed a step in the step-by-step guide: http://docs.graylog.org/en/2.4/pages/collector_sidecar.html#step-by-step-guide
I did the same more then 10 times. But still no Luck
this is content of collector_sidecar.yml
server_url: http://172.30.1.27:9000/api/
update_interval: 30
tls_skip_verify: true
send_status: true
list_log_files:
  • /var/log
    node_id: graylog-collector-sidecar
    collector_id: file:/etc/graylog/collector-sidecar/collector-id
    cache_path: /var/cache/graylog/collector-sidecar
    log_path: /var/log/graylog/collector-sidecar
    log_rotation_time: 86400
    log_max_age: 604800
    tags:
  • linux
  • apache
    backends:
    • name: filebeat
      enabled: true
      binary_path: /usr/bin/filebeat
      configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
and did you configure in Graylog for your collector something?
Yes first I configured beats input
and then connector
This is the error I am getting on client machine.
Guess what? Its working now. :slight_smile: and i really appropriate for your help. Thank you so much.
But I still can’t see the logs :frowning:
