Collector sidecare not getting logs
good morning everyone !
I have two question :
1.
well , i configured my collector sidecar using filebeat , but still i’m not able to get messages :
but i can’t recive logs :
the config files :
collector_sidecare.yml :
server_url: http://192.168.111.132:9000/api/
update_interval: 30
tls_skip_verify: false
send_status: true
list_log_file:
node_id: graylog-collector-sidecar
collector_id: file:/etc/graylog/collector-sidecar/collector-id
cache_path: /var/cache/graylog/collector-sidecar
log_path: /var/log/graylog/collector-sidecar
log_rotation_time: 86400
log_max_age: 604800
tags:
- linux
- apache
backends:
- name: nxlog
enabled: false
binary_path: /usr/bin/nxlog
configuration_path: /etc/graylog/collector-sidecar/generated/nxlog.conf
- name: filebeat
enabled: true
binary_path: /usr/bin/filebeat
configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
the filebeat.yml
filebeat:
prospectors:
  • encoding: utf-8
    exclude_files:
    fields:
    collector_node_id: graylog-collector-sidecar
    gl2_source_collector: 31cc46a3-d77f-4566-a0d7-64f4e075b82b
    type: log
    ignore_older: 0
    paths:
    • /var/log/*.log
      scan_frequency: 10s
      tail_files: true
      type: log
      output:
      logstash:
      hosts:
    • 192.168.111.132:5044
      path:
      data: /var/cache/graylog/collector-sidecar/filebeat/data
      logs: /var/log/graylog/collector-sidecar
      tags:
  • linux
  • apache
    my imput conf
2.question
Is it possible to use UDP with collector ?
and can we crypt the traffic using only udp ?
Thank you everyone for your help
the content of the log file of raylog server :
2018-04-04T09:37:59.350+01:00 WARN [Messages] Failed to index message: index=<graylog_0> id=<7a78a170-37e3-11e8-8085-000c290eb38e> error=<{“type”:“mapper_parsing_exception”,“reason”:“failed to parse”,“caused_by”:{“type”:“illegal_argument_exception”,“reason”:“Can’t parse [index] value [not_analyzed] for field [sourcipadd], expected [true] or [false]”}}>
2018-04-04T09:37:59.350+01:00 WARN [Messages] Failed to index message: index=<graylog_0> id=<7a78a172-37e3-11e8-8085-000c290eb38e> error=<{“type”:“mapper_parsing_exception”,“reason”:“failed to parse”,“caused_by”:{“type”:“illegal_argument_exception”,“reason”:“Can’t parse [index] value [not_analyzed] for field [sourcipadd], expected [true] or [false]”}}>
2018-04-04T09:37:59.350+01:00 ERROR [Messages] Failed to index [8] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-04-04T09:38:01.190+01:00 WARN [Messages] Failed to index message: index=<graylog_0> id=<7b606960-37e3-11e8-8085-000c290eb38e> error=<{“type”:“mapper_parsing_exception”,“reason”:“failed to parse”,“caused_by”:{“type”:“illegal_argument_exception”,“reason”:“Can’t parse [index] value [not_analyzed] for field [sourcipadd], expected [true] or [false]”}}>
2018-04-04T09:38:01.190+01:00 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-04-04T09:38:02.913+01:00 WARN [Messages] Failed to index message: index=<graylog_0> id=<7cb7e312-37e3-11e8-8085-000c290eb38e> error=<{“type”:“mapper_parsing_exception”,“reason”:“failed to parse”,“caused_by”:{“type”:“illegal_argument_exception”,“reason”:“Can’t parse [index] value [not_analyzed] for field [test1], expected [true] or [false]”}}>
2018-04-04T09:38:02.956+01:00 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
Try rotating the write-active index (via System / Indices / Index Set / Maintenance).
i think the probleme had to do with maping
but i can’t figure it out :confused:
i’m always using syslog in my graylog , so the maping form should be as syslog format ? now i’m trying to get filebeat format to the index and it’s not working ?
shall i creat a new index ? :confused:
i m trying your solution and i ll came back with result thank you very much Jochen !
maaaaaaaaaaaaaagiiiiiiiiic :smiley: thank you it’s working if you can just eplain to me what was the probléme and what write-active index does to my solution !
thank you Jochen you make graylog sound easy :smiley:
