Hello, I have a problem with graylog collector sidecar.
I try to send logs from collector-sidecar with filebeat to Graylog but nothing is displayed on the web interface.
My URL of Graylog is : http://172.27.7.34:9000
Graylog version : 2.4.6
ElasticSearch version : 2.4.0
Collector-sidecar version : 0.1.6
My file /etc/graylog/collector-sidecar/collector_sidecar.yml :
server_url: http://172.27.7.34:9000/api/ update_interval: 10 tls_skip_verify: false send_status: true list_log_files: collector_id: file:/etc/graylog/collector-sidecar/collector-id cache_path: /var/cache/graylog/collector-sidecar log_path: /var/log/graylog/collector-sidecar log_rotation_time: 86400 log_max_age: 604800 tags: - linux - apache backends: - name: nxlog enabled: false binary_path: /usr/bin/nxlog configuration_path: /etc/graylog/collector-sidecar/generated/nxlog.conf - name: filebeat enabled: true binary_path: /usr/bin/filebeat configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
The log file of collector-sidecar :
time="2018-10-30T11:41:39+01:00" level=info msg="[filebeat] Configuration change detected, rewriting configuration file." time="2018-10-30T11:41:39+01:00" level=info msg="[filebeat] Stopping" time="2018-10-30T11:41:41+01:00" level=info msg="[filebeat] Starting (exec driver)"
The log of filebeat:
> 2018-10-30T11:41:41+01:00 INFO Home path: [/usr/bin] Config path: [/usr/bin] Data path: [/var/cache/graylog/collector-sidecar/filebeat/data] Logs path: [/var/log/graylog/collector-sidecar] > 2018-10-30T11:41:41+01:00 INFO Metrics logging every 30s > 2018-10-30T11:41:41+01:00 INFO Beat UUID: 523e47ed-ab73-4020-9ccc-3e3983d9472a > 2018-10-30T11:41:41+01:00 INFO Setup Beat: filebeat; Version: 6.1.2 > 2018-10-30T11:41:41+01:00 INFO Beat name: vl-d-0307 > 2018-10-30T11:41:41+01:00 ERR Not loading modules. Module directory not found: /usr/bin/module > 2018-10-30T11:41:41+01:00 INFO filebeat start running. > 2018-10-30T11:41:41+01:00 INFO No registry file found under: /var/cache/graylog/collector-sidecar/filebeat/data/registry. Creating a new registry file. > 2018-10-30T11:41:41+01:00 INFO Loading registrar data from /var/cache/graylog/collector-sidecar/filebeat/data/registry > 2018-10-30T11:41:41+01:00 INFO States Loaded from registrar: 0 > 2018-10-30T11:41:41+01:00 WARN Filebeat is unable to load the Ingest Node pipelines for the configured modules because the Elasticsearch output is not configured/enabled. If you have already loaded the Ingest Node pipelines or are using Logstash pipelines, you can ignore this warning. > 2018-10-30T11:41:41+01:00 INFO Loading Prospectors: 1 > 2018-10-30T11:41:41+01:00 INFO Starting Registrar > 2018-10-30T11:41:41+01:00 INFO Starting prospector of type: log; ID: 13896357823230510981 > 2018-10-30T11:41:41+01:00 INFO Loading and starting Prospectors completed. Enabled prospectors: 1 > 2018-10-30T11:42:11+01:00 INFO Non-zero metrics in the last 30s: beat.info.uptime.ms=30003 beat.memstats.gc_next=4194304 beat.memstats.memory_alloc=1355728 beat.memstats.memory_total=3175384 filebeat.events.added=1 filebeat.events.done=1 filebeat.harvester.open_files=0 filebeat.harvester.running=0 libbeat.config.module.running=0 libbeat.output.type=logstash libbeat.pipeline.clients=1 libbeat.pipeline.events.active=0 libbeat.pipeline.events.filtered=1 libbeat.pipeline.events.total=1 registrar.states.current=1 registrar.states.update=1 registrar.writes=2
And the file generated :
filebeat:
prospectors:
- encoding: plain
exclude_files:
fields:
collector_node_id: vl-d-0307
gl2_source_collector: c6ad1974-fdff-4044-8010-a13ff058dae4
type: log
ignore_older: 0
paths:
- /var/log/test.log
scan_frequency: 10s
tail_files: true
type: log
output:
logstash:
hosts:- localhost:5044
path:
data: /var/cache/graylog/collector-sidecar/filebeat/data
logs: /var/log/graylog/collector-sidecar
tags:- linux
- apache
If some one have an idea…
