Graylog does get files from filebeat
Hi!
I have configured my graylog env on Ubuntu (VM 192.168.161.25) and installed saidecar on my Windows 10 (host). I can send logs to GL via Postman and see them in GL but I can’t manage sidecar to send file to GL.
This is my sidecar settings
server_url: http://192.168.161.25:9000/api
update_interval: 10
tls_skip_verify: false
send_status: true
list_log_files:
node_id: graylog-collector-sidecar
collector_id: file:C:\Program Files\graylog\collector-sidecar\collector-id
cache_path: C:\Program Files\graylog\collector-sidecar\cache
log_path: C:\Program Files\graylog\collector-sidecar\logs
log_rotation_time: 86400
log_max_age: 604800
tags: [TEST]
backends:
    - name: nxlog
      enabled: false
      binary_path: C:\Program Files (x86)\nxlog\nxlog.exe
      configuration_path: C:\Program Files\graylog\collector-sidecar\generated\nxlog.conf
    - name: winlogbeat
      enabled: false
      binary_path: C:\Program Files\graylog\collector-sidecar\winlogbeat.exe
      configuration_path: C:\Program Files\graylog\collector-sidecar\generated\winlogbeat.yml
    - name: filebeat
      enabled: true
      binary_path: C:\Program Files\graylog\collector-sidecar\filebeat.exe
      configuration_path: C:\Program Files\graylog\collector-sidecar\generated\filebeat.yml
This is filebeat settings
filebeat:
  prospectors:
  - encoding: plain
    exclude_files: []
    fields:
      collector_node_id: graylog-collector-sidecar
      gl2_source_collector: 6d588c09-a0a7-4727-8a3e-551d1e84a607
      type: txt
    ignore_older: 0
    paths:
    - K:\Logs
    scan_frequency: 10s
    tail_files: true
    type: log
output:
  logstash:
    hosts:
    - 192.168.161.25:5044
path:
  data: C:\Program Files\graylog\collector-sidecar\cache\filebeat\data
  logs: C:\Program Files\graylog\collector-sidecar\logs
tags:
- TEST
I put logs into K:\Logs, set Beat input and made configuration via GL UI according to instruction. But no logs appeared in GL.
Also I have an error in filebeat error log like service/service_windows.go:76 Error: The service process could not connect to the service controller when I run it as service. But there is no such error in debug mode.
Please tell me what is wrong ?
please edit your posting using proper formatting rules ro make it readable:
https://community.graylog.org/faq
I did some investigation and found out in filebeat log that 0 files were posted. So I did conclusion that something was wrong with the file path. Finally, I figured out that file type also has to present in file path and replaced K:\Logs with K:\Logs*.log That was fix in my case. And make sure your log file ext match with specified log type))
