Hello community, hope you’re all having a nice day.
So, I’m trying to log my apache messages on Graylog, but after everything [properly?] configured, I still can’t see any messages on my search page.
Let me show you some configurations I did.
The sidecar was configured:
Status: > Running
Last Seen: a few seconds ago
Sidecar Version: 1.0.2
The Sidecar techlab-server status shows that everything is running:
## Node details
IP Address: 162.241.47.134
Operating System: Linux
CPU Idle: 98.46%
Load: 0.04
Volumes > 75% full: None
## Collectors status
filebeat - Collector is running.
## Log Files
Show all my actual files in the apache directory, /var/log/apache2...
And it is properly linked with the configuration:
Here is the configuration (techlab-server-apache):
# Needed for Graylog
fields_under_root: true
filebeat.inputs:
- input_type: log
paths:
- /var/log/apache2/access_log
- /var/log/apache2/error_log
- /var/log/apache2/suphp_log
type: log
output.logstash:
hosts: ["192.168.1.1:5044"]
path:
data: /var/lib/graylog-sidecar/collectors/filebeat/data
logs: /var/lib/graylog-sidecar/collectors/filebeat/log
The last system log info is promissing:
|2019-10-06T15:28:00-03:00| a630e768 / vps.techlab-tecnologia.com.br|Input [Beats/5d9a2a3ebaa76b0511a53a19] is now RUNNING|
|2019-10-06T15:28:00-03:00| a630e768 / vps.techlab-tecnologia.com.br|Input [Beats/5d9a2a3ebaa76b0511a53a19] is now STARTING|
|2019-10-06T15:28:00-03:00| a630e768 / vps.techlab-tecnologia.com.br|Started up.|
So, I installed the graylog-sidecar 1.0.2 in my CentOS7 server and also the FileBeat. Here are the configuration I did for them:
/etc/graylog/sidecar/sidecar.yml
# The URL to the Graylog server API.
server_url: "http://162.241.47.134:9000/api/"
# The API token to use to authenticate against the Graylog server API.
# This field is mandatory (removed for privacy purposes)
server_api_token: "**********"
# The node ID of the sidecar. This can be a path to a file or an ID string.
# If set to a file and the file doesn't exist, the sidecar will generate an
# unique ID and writes it to the configured path.
# Example file path: "file:/etc/graylog/sidecar/node-id"
# Example ID string: "6033137e-d56b-47fc-9762-cd699c11a5a9"
# ATTENTION: Every sidecar instance needs a unique ID!
node_id: "file:/etc/graylog/sidecar/techlab-server"
# The node name of the sidecar. If this is empty, the sidecar will use the
# hostname of the host it is running on.
node_name: "techlab-server"
# The update interval in secods. This configures how often the sidecar will
# contact the Graylog server for keep-alive and configuration update requests.
update_interval: 10
# This configures if the sidecar should skip the verification of TLS connections.
# Default: false
#tls_skip_verify: false
# This enables/disables the transmission of detailed sidecar information like
# collector statues, metrics and log file lists. It can be disabled to reduce
# load on the Graylog server if needed. (disables some features in the server UI)
#send_status: true
# A list of directories to scan for log files. The sidecar will scan each
# directory for log files and submits them to the server on each update.
# Example:
# list_log_files:
# - "/var/log/nginx"
# - "/opt/app/logs"
# Default: empty list
list_log_files:
- "/var/log/apache2"
# Directory where the sidecar stores internal data.
#cache_path: "/var/cache/graylog-sidecar"
# Directory where the sidecar stores logs for collectors and the sidecar itself.
#log_path: "/var/log/graylog-sidecar"
# The maximum size of the log file before it gets rotated.
#log_rotate_max_file_size: "10MiB"
# The maximum number of old log files to retain.
#log_rotate_keep_files: 10
# Directory where the sidecar generates configurations for collectors.
#collector_configuration_directory: "/var/lib/graylog-sidecar/generated"
# A list of binaries which are allowed to be executed by the Sidecar. An empty list disables the whitelist feature.
# Wildcards can be used, for a full pattern description see https://golang.org/pkg/path/filepath/#Match
# Example:
# collector_binaries_whitelist:
# - "/usr/bin/filebeat"
# - "/opt/collectors/*"
# Example disable whitelisting:
# collector_binaries_whitelist: []
# Default:
# - "/usr/bin/packetbeat"
# - "/usr/bin/metricbeat"
# - "/usr/bin/heartbeat"
# - "/usr/bin/auditbeat"
# - "/usr/bin/journalbeat"
# - "/usr/share/filebeat/bin/filebeat"
# - "/usr/share/packetbeat/bin/packetbeat"
# - "/usr/share/metricbeat/bin/metricbeat"
# - "/usr/share/heartbeat/bin/heartbeat"
# - "/usr/share/auditbeat/bin/auditbeat"
# - "/usr/share/journalbeat/bin/journalbeat"
# - "/usr/bin/nxlog"
# - "/opt/nxlog/bin/nxlog"
/etc/filebeat/filebeat.yml
###################### Filebeat Configuration Example #########################
# This file is an example configuration file highlighting only the most common
# options. The filebeat.reference.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/filebeat/index.html
# For more available modules and options, please see the filebeat.reference.yml sample
# configuration file.
#=========================== Filebeat inputs =============================
filebeat.inputs:
# Each - is an input. Most options can be set at the input level, so
# you can use different inputs for various configurations.
# Below are the input specific configurations.
- type: log
# Change to true to enable this input configuration.
enabled: true
# Paths that should be crawled and fetched. Glob based paths.
paths:
#- c:\programdata\elasticsearch\logs\*
# Exclude lines. A list of regular expressions to match. It drops the lines that are
# matching any regular expression from the list.
#exclude_lines: ['^DBG']
# Include lines. A list of regular expressions to match. It exports the lines that are
#include_lines: ['^ERR', '^WARN']
# Exclude files. A list of regular expressions to match. Filebeat drops the files that
# are matching any regular expression from the list. By default, no files are dropped.
#exclude_files: ['.gz$']
# Optional additional fields. These fields can be freely picked
# to add additional information to the crawled log files for filtering
#fields:
# level: debug
# review: 1
### Multiline options
# Multiline can be used for log messages spanning multiple lines. This is common
# for Java Stack Traces or C-Line Continuation
# The regexp Pattern that has to be matched. The example pattern matches all lines starting with [
#multiline.pattern: ^\[
# Defines if the pattern set under pattern should be negated or not. Default is false.
#multiline.negate: false
# Match can be set to "after" or "before". It is used to define if lines should be append to a pattern
# that was (not) matched before or after or as long as a pattern is not matched based on negate.
# Note: After is the equivalent to previous and before is the equivalent to to next in Logstash
#multiline.match: after
#============================= Filebeat modules ===============================
filebeat.config.modules:
# Glob pattern for configuration loading
path: ${path.config}/modules.d/*.yml
# Set to true to enable config reloading
reload.enabled: false
# Period on which files under path should be checked for changes
#reload.period: 10s
#==================== Elasticsearch template setting ==========================
setup.template.settings:
index.number_of_shards: 3
#index.codec: best_compression
#_source.enabled: false
#================================ General =====================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
#tags: ["service-X", "web-tier"]
# Optional fields that you can specify to add additional information to the
# output.
#fields:
# env: staging
#============================== Dashboards =====================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here, or by using the `-setup` CLI flag or the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
#============================== Kibana =====================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
# Kibana Host
# Scheme and port can be left out and will be set to the default (http and 5601)
# In case you specify and additional path, the scheme is required: http://localhost:5601/path
# IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
#host: "localhost:5601"
# Kibana Space ID
# ID of the Kibana Space into which the dashboards should be loaded. By default,
# the Default Space will be used.
#space.id:
#============================= Elastic Cloud ==================================
# These settings simplify using filebeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
#================================ Outputs =====================================
# Configure what output to use when sending the data collected by the beat.
#-------------------------- Elasticsearch output ------------------------------
output.elasticsearch:
# Array of hosts to connect to.
hosts: ["localhost:9200"]
# Enabled ilm (beta) to use index lifecycle management instead daily indices.
#ilm.enabled: false
# Optional protocol and basic auth credentials.
#protocol: "https"
#username: "elastic"
#password: "changeme"
#----------------------------- Logstash output --------------------------------
#output.logstash:
# The Logstash hosts
#hosts: ["localhost:5044"]
# Optional SSL. By default is off.
# List of root certificates for HTTPS server verifications
#ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]
# Certificate for SSL client authentication
#ssl.certificate: "/etc/pki/client/cert.pem"
# Client Certificate Key
#ssl.key: "/etc/pki/client/cert.key"
#================================ Processors =====================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
- add_host_metadata: ~
- add_cloud_metadata: ~
#================================ Logging =====================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publish", "service".
#logging.selectors: ["*"]
#============================== Xpack Monitoring ===============================
# filebeat can export internal metrics to a central Elasticsearch monitoring
# cluster. This requires xpack monitoring to be enabled in Elasticsearch. The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#xpack.monitoring.enabled: false
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well. Any setting that is not set is
# automatically inherited from the Elasticsearch output configuration, so if you
# have the Elasticsearch output configured, you can simply uncomment the
# following line.
#xpack.monitoring.elasticsearch:
Even so, I’m unable to see the messages on Graylog. If I click on “Show messages” for that sidecar, nothing appears.
I’m sure I’m missing something, but I don’t know what that is. Could anyone kindly give me a hint about it?
Thank you so much
Have a nice day everyone!
