Graylog Server not receiving messages from sidecar
I’ve been trying to setup a Graylog Server and Sidecar in a linux vm environment for school for weeks now and no messages are getting through. I’ve followed different tutorials, the step-by-step guides, nothing is working and I’m not getting any error messages saying that something is wrong. I’ve created new VMs to try and fix the problem with different IP addresses and nothing. I’m working in CentOS 8 with sidecar version 1.1.0-1 and server version 3.2.6.
As for the configuration, nothing seems to be out of place, and if there was anything out of place I’m getting no error messages suggesting so. I just need help seeing what the problem is.
I’m using Filebeat on Linux with the configuration:
#Needed for Graylog
fields_under_root: true
filebeat.inputs:
- input_type: log
  paths:
  - /var/log/*.log
  type: log
output.logstash:
 hosts: ["greylog-server-ip:5044"]
path:
 data: /var/lib/graylog-sidecar/collectors/filebeat/data
 logs: /var/lib/graylog-sidecar/collectors/filebeat/log
Local Input Configuration:
Syslog UDP [running]
allow_override_date: true
bind_address: 0.0.0.0
expand_structured_data: false
force_rdns: false
number_worker_threads: 1
override_source: <empty>
port: 1514
recv_buffer_size: 262144
store_full_message: false
Sidecar Configuration:
server_url: "http://[ip-address]:9000/api/"
server_api_token: "[token]"
update_inverval: 10
tls_skip_verify: true
send_status: true
list_log_files: []
cache_path: "/var/cache/graylog-sidecar"
log_path: "/var/log/graylog-sidecar"
Server Configuration:
is_master = true
password_secret = [pwgen -N 1 -s 96]
root_username = [username]
root_password_sha2 = [hashed password]
root_timezone = UTC
http_bind_address = [ip address]:9000
  • Does the sidecar show up in your list of sidecars on the Graylog server?
  • If it does, did you assign the configuration to it?
  • You configuration is going to port 5044 which is a “Beats” input port but you are listing a “Syslog UDP” input and has a port of 1514… Two ships sailing in the night right there!
Check this area for logs on the machine where sidecar is installed- sidecar is usually pretty good about kicking out what is sees as an issue. One thing to not is yml files are very sensitive to spacing and indentation… the log files usually complain about that if it’s an issue so you don’t have to guess…
