Sidecar not showing any messages in the graylog web_interface
My graylog server is running within container so is my sidecar service . I am able to see the sidecar instance on the graylog web interface but not able to see any messages in sidecar
please suggest what changes to be made to see the logs on UI.
Looks like your path is off a little. If you want all the files in that directory you need to use the * as in /home/logs/*
Here is a generic one that grabs all files ending in log
# Needed for Graylog
fields_under_root: true
filebeat.inputs:
- input_type: log
  paths:
    - /var/log/*.log
  type: log
output.logstash:
   hosts:
   - ${user.BeatsInput}
path:
  data: /var/cache/graylog-sidecar/filebeat/data
  logs: /var/log/graylog-sidecar
Adding on to @tmacgbay statement.
Did you insure that port “5044” is opened?
Also I noticed you using port 8007 for Graylog’s URL API ?
graylog2-sidecar-docker
In this section
Found here
If I run my sidecar container with the above suggestion I get followign erros in my container logs
These is how i set the path
Any idea why am I getting this issue because when i working on host with these services it was working fine but with containers i am facing this issue
I have open the port 5044 on both services of mine sidecar and graylog as well below screen shots are Dockefile for sidecar and docker-compose.yml file for graylog service
Sidecar docker image
graylog docker-compose.yml file
