Hi all,
I find there are two same search result in the graph, only difference between them is the timestamp field. But I find only one message in log file.
In this graph,in fact it’s just two logs, but search four result.I am very confused.
Please help me, thank you!
jochen
(Jochen)
May 22, 2018, 9:39am
2
How exactly are you sending these logs to Graylog?
What’s the complete configuration of all involved components?
I use collector sidecar filebeat to send logs to graylog.
collector sidecar configuration is
server_url: http://XXXXXXXXX/api/
update_interval: 10
tls_skip_verify: false
send_status: true
list_log_files:
node_id: collector-sidecar
collector_id: file:/etc/graylog/collector-sidecar/collector-id
cache_path: /var/cache/graylog/collector-sidecar
log_path: /var/log/graylog/collector-sidecar
log_rotation_time: 86400
log_max_age: 604800
tags:
- hybris-debug
- hybris-error
- hybris-info
- hybris-tomcat-access
- hybris-tomcat-console
- inv-full
backends:
- name: nxlog
enabled: false
binary_path: /usr/bin/nxlog
configuration_path: /etc/graylog/collector-sidecar/generated/nxlog.conf
- name: filebeat
enabled: true
binary_path: /usr/bin/filebeat
configuration_path: /etc/graylog/collector-sidecar/generated/filebeat.yml
filebeat configuraiton is:
filebeat:
prospectors:
- encoding: utf-8
exclude_files: []
fields:
collector_node_id: collector-sidecar-job04-p
flag: hybris-tomcat-console
gl2_source_collector: cc6b9ac5-a9c1-4a59-abaa-923893da8229
type: log
ignore_older: 0
paths:
- /home/prodlog/hybrislog/tomcat/console-*.log
scan_frequency: 10s
tail_files: true
type: log
- encoding: utf-8
exclude_files: []
fields:
flag: hybris-debug
type: log
ignore_older: 0
paths:
- /home/prodlog/hybrislog/frpf/debug/hybris-debug.log
scan_frequency: 10s
tail_files: true
type: log
- encoding: utf-8
exclude_files: []
fields:
flag: hybris-info
type: log
ignore_older: 0
multiline:
match: after
negate: true
pattern: ^.*[0-9]{2}m[0-9]{2}:[0-9]{2}:[0-9]{2},[0-9]{3}
paths:
- /home/prodlog/hybrislog/frpf/info/hybris-info.log
scan_frequency: 10s
tail_files: true
type: log
- encoding: utf-8
exclude_files: []
fields:
flag: hybris-error
type: log
ignore_older: 0
multiline:
match: after
negate: true
paths:
- /home/prodlog/hybrislog/frpf/error/hybris-error.log
scan_frequency: 10s
tail_files: true
type: log
- encoding: utf-8
exclude_files: []
fields:
flag: hybris-tomcat-access
type: log
ignore_older: 0
paths:
- /home/prodlog/hybrislog/tomcat/access.*.log
scan_frequency: 10s
tail_files: true
type: log
- encoding: utf-8
exclude_files: []
fields:
flag: inv-full
type: log
ignore_older: 0
paths:
- /u01/prod/app/hybris6200/hybris/log/frpf/inv/full/1.log
scan_frequency: 10s
tail_files: true
type: log
output:
logstash:
hosts:
- xxxxxxxxx5:5044
- xxxxxxxxx6:5044
- xxxxxxxxx1:5044
- xxxxxxxxx2:5044
- xxxxxxxxx3:5044
- xxxxxxxxx4:5044
loadbalance: true
path:
data: /var/cache/graylog/collector-sidecar/filebeat/data
logs: /var/log/graylog/collector-sidecar
tags:
- hybris-debug
- hybris-error
- hybris-info
- inv-full
And I find this two message ID are same.
jochen
(Jochen)
May 22, 2018, 10:02am
4
Are you using any 3rd party plugins in Graylog?
If the message ID is identical, then it’s the same message and is “only” displayed twice.
Shelin
May 22, 2018, 10:07am
5
I don’t use any 3rd party plugin in graylog.I install graylog with default plugin.
Shelin
May 22, 2018, 10:18am
6
By the way, If I click stream same message in search result display once, but click search button in home page,it display twice:confused:Then two same message appeared in alert notification.Is this problem because the same message is in two streams?
jochen
(Jochen)
May 22, 2018, 10:19am
7
It depends. If these two streams have different backing index sets, then the message is being stored twice in Elasticsearch. If all streams are using the same backing index set, then the message is being stored only once.
See http://docs.graylog.org/en/2.4/pages/configuration/index_model.html for details.
Shelin
May 22, 2018, 10:28am
8
En…but I configure alert with only one stream , it appeared twice in notification.
Do I need to ensure that only one log of all messages in elasticsearch appear once?
jochen
(Jochen)
May 22, 2018, 10:31am
9
As I wrote before, that depends on your use case and how you’ve configured your system.
Shelin
May 22, 2018, 10:41am
10
Sorry,I not very clear about it. The current situation is two streams have different backing index sets. One stream(named stream1) include another stream(named stream2) message, stream1 has more message than stream2. Then I configured alert on stream2,but in notification appear two same message.So I need to change stream2 backing index to stream1 backing index set and problem will be solved? I do not know whether this understanding is correct.
Thank you so much for responding to my questions so quickly.
