Is It Possible To Choose A Stream For A Dashboard?
Hi, I noticed that when you go to the Streams menu and open one of the streams, you could see a drop-down menu to choose a stream from. I couldn’t find a way to add this to a dashboard with a message table. Is there any way to add that “stream override” to dashboards?
Note: I am aware that you could filter streams with the search/query box.
Currently the stream selection box is only available when configuring a widget, but not globally for the dashboad.
However, you can use the search query to query for specific streams:
streams:(63068dc98a735a37e8d535f9 OR 62aba9dc82e7a17341a60c81)
Hope that helps.
Hi Drew, thanks for the response. I can’t see the stream selection box even when I’m configuring a widget. What am I missing? I’m on Graylog 5.1.2.
Do you see this box here on the widget edit screen?
Ah yes! I can see it when I edit every widget individually. This is exactly what I needed, thanks!
