I have created a stream for each department that keys off a tag. I have also created a dashboard. I would like to have a single global dashboard that only displays results that are filtered on the users stream rights. Is there a way to do this, or do I have to create individual dashboards for each departmental stream?
No, that’s not possible with Graylog 2.x. You’ll have to create an individual dashboard per departmental stream.
I would like to clone the existing dashboard and only change the stream. If I create a content pack of just the existing dashboard, is there a way to import it and change the stream reference?
Created a Content Pack, set value of streams to empty:
“streams”: []
Did a find and replace for the All Messages “stream_id” and changed it to the desired stream ID. Imported the edited Content Pack. The new dashboard works fine.
