Do dashboard filters/variables exist?
Hi folks,
Forgive me if I’ve missed docs, I believe this just isn’t supported but would like to be sure.
I am trying to create dashboards that will be used across multiple clients (all logs aggregate to our server) but can’t see a way to filter a dashboard.
I was hoping for something like Grafana where you can add a dropdown (or just a free entry textbox) where you select a specific value, ie “Client1” and it filters the data.
I would also be happy with just being able to add something to the query being used in the individual widget/panels.
Ie I would add enter “AND client = 1” into a field and this would be appended to the query on all the widgets.
This seems a pretty basic thing to me to help you drill down on issues etc but is this just not a use case other people have?
Thanks!
You may be looking for something like Search Parameters? It requires an Enterprise License but as long as you keep your logs < 2GB you can have one for free…
Hello @samf
Just chiming in on this statement.
Depending on how the Widget is configure, Here are some examples in my lab querying by “source”.
Example:
Dashboard “Central Command Unit Section” with Aggregating count by source.
Let’s say I want to add a quick filter on device called veam. Click the down arrow next to the name and select " add to query"
Next example:
Dashboard “Central Command Unit Section” with Aggregating count by source called “veam”
and I want to add a different device call keycloak.
Next example :
Widget made for trending data on veeam device only, so I configured this widget like so…
Dashboard looks like this…
adding new device Keycloak to widget.
Only other way I know how to add info is what @tmacgbay suggested above.
Thanks this is the behaviour I’ve already seen, unfortunately we are bringing in a lot of logs from disparate sources and in different formats so I’m not sure this is appropriate! I think the enterprise Search Parameter feature is probably what we need.
I really appreciate the suggestion though!
That is 100% what I’m looking for, thank you!
I’m hesitant to tie into something that requires staying too low though, we are (slowly but surely) building this out as a scalable solution to address a lot of clients. <2GB might be practical now but it hopefully won’t be long term. I’ll drop sales a line when I have time and see whether the lowest tier might be manageable.
Thanks for your help and suggestion!
