Https with graylog - guide
Hello
Can you help me with this isssue? It does not work in my situation :frowning: Please help me :slight_smile:
Graylog configured on CentOS 7 - 1 node all in one.
I need step by step configuration (The best soutions) if not can you give me some (5-6) milestones what should I do.
Do you hear sth about this guidlines ?
Thank you in advance :slight_smile: :slight_smile:
Hey @goozoop
did you have a look at this?:
http://docs.graylog.org/en/2.2/pages/configuration/web_interface.html
Greetings - Phil
couple of pitfalls I ran into
  • private key file PEM format (PKCS8 i think)
  • enable TLS for both web interface and API
  • put web interface on a different port
  • add CA Cert to java keystore
Once I addressed all those everything fell into place.
thx, I will do it, but I have forgotten ab. sth. :frowning: Can you more explain this 4 steps ? :slight_smile:
http://docs.graylog.org/en/2.2/pages/configuration/https.html
