Hi All
Apologies if I should have been able to google this with a simple query, but I am not sure about some of the information I found.
I am running various flavours of Linux which I would like to be able to send the logs via TLS, installed version of Graylog is 2.2.3+7adc951 on a Centos 7.3 box.
On the Graylog box can I use a standard signed SSL cert for Apache or do I need to convert it? the same for the clients? I am trying to avoid having to setup my own CA.
I am using rsyslog from each client, is there any specific configuration that needs to be done for the . @@graylog.example.org:514;RSYSLOG_SyslogProtocol23Format which I add in to the /etc/rsyslog.d/ configuration file?
If anyone got any ideas or suggestions to share then I would really appreciate it.
Regards
