I have two servers, a production server and a monitoring server. On the monitoring server I have Graylog2 installed (version 2.3.2). Before I passed the logs between the two servers in UDP. With this config:
Production server side
/etc/rsyslog.d/60-graylog.conf:
*.* @monitoring.logMonitoringdomainName:514;RSYSLOG_SyslogProtocol23Format
Monitoring server side:
ufw allow 514/udp
systemctl restart rsyslog
And Graylog was running well. But now I would like to pass the logs between the two servers using TLS. My certificates are generated with letsencrypt. With this config:
apt-get -y install rsyslog-gnutls
$ModLoad imuxsock # local messages
$ModLoad imtcp # TCP listener
# make gtls driver the default
$DefaultNetstreamDriver gtls
# certificate files
$DefaultNetstreamDriverCAFile /etc/letsencrypt/live/domainName/fullchain.pem
$DefaultNetstreamDriverCertFile /etc/letsencrypt/live/domainName/cert.pem
$DefaultNetstreamDriverKeyFile /etc/letsencrypt/live/domainName/privkey.pem
$InputTCPServerStreamDriverAuthMode x509/name
$InputTCPServerStreamDriverPermittedPeer *.$logMonitoring
$InputTCPServerStreamDriverMode 1 # run driver in TLS-only mode
$InputTCPServerRun 10514 # start up listener at port 10514
*.* @@monitoring.logMonitoringdomainName:514;RSYSLOG_SyslogProtocol23Format
ufw allow 514/tcp
ufw allow 514/tcp
Graylog TCP input :
allow_override_date:
true
bind_address:
0.0.0.0
expand_structured_data:
false
force_rdns:
false
max_message_size:
2097152
override_source:
<empty>
port:
514
recv_buffer_size:
1048576
store_full_message:
false
tcp_keepalive:
false
tls_cert_file:
/home/gspohu/TLS_LOG/cert.pem
tls_client_auth:
disabled
tls_client_auth_cert_file:
<empty>
tls_enable:
true
tls_key_file:
/home/gspohu/TLS_LOG/privkey.pem
tls_key_password:
use_null_delimiter:
false
But I don’t understand how to set the graylog input, watever I try in input config, graylog can’t read the logs, besides I’m not sure of my TLS configuration. Could you guide me through the configuration ?
Thank you to take time to read me,
