Thanks Ponet,
I tried to migrate but that’s no work…
i follow document here you can find what i’ve done on graylog server
add this line in /etc/profile
export JAVA_HOME=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.252.b09-2.el8_1.x86_64/
export PATH=$JAVA_HOME/bin:$PATH
cp java
cp -a “${JAVA_HOME}/jre/lib/security/cacerts” /certs/cacerts.jks
generate certificate and import in keystore
openssl req -x509 -days 365 -nodes -newkey rsa:2048 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out cert.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -out pkcs8-encrypted.pem -passout pass:XXXXX
keytool -importcert -keystore /certs/cacerts.jks -storepass XXXXX -alias graylog-https -file cert.pem
modify /etc/sysconfig/graylog
GRAYLOG_SERVER_JAVA_OPTS=“-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/certs/cacerts.jks -Djavax.net.ssl.trustStorePassword=XXXXX”
modify the rights of /certs
chown graylog:graylog /certs/*
change server.conf
http_publish_uri = https://10.10.10.11:9000/
http_enable_tls = true
http_tls_cert_file = /certs/cert.pem
http_tls_key_file = /certs/pkcs8-encrypted.pem
http_tls_key_password = XXXXX
restart mongod elactic and graylog and that’s no work
When i look mongod.log it’s seem good
2020-05-19T17:15:56.093+0200 I ACCESS [conn5] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39204
2020-05-19T17:15:56.097+0200 I ACCESS [conn8] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39210
2020-05-19T17:15:56.100+0200 I ACCESS [conn6] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39206
2020-05-19T17:15:56.107+0200 I ACCESS [conn4] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39202
2020-05-19T17:15:56.116+0200 I ACCESS [conn7] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39208
2020-05-19T17:15:56.128+0200 I ACCESS [conn9] Successfully authenticated as principal mongo_graylog on graylog from client 127.0.0.1:39212
2020-05-19T17:15:56.188+0200 I SHARDING [conn4] Marking collection graylog.ldap_settings as collection version:
2020-05-19T17:15:56.296+0200 I SHARDING [conn2] Marking collection graylog.collector_uploads as collection version:
elastic logs that the same it seem good
[2020-05-19T17:15:51,660][INFO ][o.e.d.DiscoveryModule ] [L9YFaga] using discovery type [zen] and host providers [settings]
[2020-05-19T17:15:52,444][INFO ][o.e.n.Node ] [L9YFaga] initialized
[2020-05-19T17:15:52,444][INFO ][o.e.n.Node ] [L9YFaga] starting …
[2020-05-19T17:15:52,798][INFO ][o.e.t.TransportService ] [L9YFaga] publish_address {127.0.0.1:9300}, bound_addresses {127.0.0.1:9300}
[2020-05-19T17:15:52,834][WARN ][o.e.b.BootstrapChecks ] [L9YFaga] system call filters failed to install; check the logs and fix your configuration or disable system call filters at your own risk
[2020-05-19T17:15:55,970][INFO ][o.e.c.s.MasterService ] [L9YFaga] zen-disco-elected-as-master ([0] nodes joined), reason: new_master {L9YFaga}{L9YFagaARtSsIkr_czIRSA}{y3PEbgAeQTeNBlxdtosd-g}{127.0.0.1}{127.0.0.1:9300}
[2020-05-19T17:15:55,978][INFO ][o.e.c.s.ClusterApplierService] [L9YFaga] new_master {L9YFaga}{L9YFagaARtSsIkr_czIRSA}{y3PEbgAeQTeNBlxdtosd-g}{127.0.0.1}{127.0.0.1:9300}, reason: apply cluster state (from master [master {L9YFaga}{L9YFagaARtSsIkr_czIRSA}{y3PEbgAeQTeNBlxdtosd-g}{127.0.0.1}{127.0.0.1:9300} committed version [1] source [zen-disco-elected-as-master ([0] nodes joined)]])
[2020-05-19T17:15:56,151][INFO ][o.e.h.n.Netty4HttpServerTransport] [L9YFaga] publish_address {127.0.0.1:9200}, bound_addresses {127.0.0.1:9200}
[2020-05-19T17:15:56,151][INFO ][o.e.n.Node ] [L9YFaga] started
[2020-05-19T17:15:56,800][INFO ][o.e.g.GatewayService ] [L9YFaga] recovered [3] indices into cluster_state
[2020-05-19T17:15:58,234][INFO ][o.e.c.r.a.AllocationService] [L9YFaga] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_0][1]] …]).
But in graylog.log…
2020-05-19T17:42:01.569+02:00 INFO [GracefulShutdownService] Initiate shutdown for
2020-05-19T17:42:01.569+02:00 INFO [GracefulShutdownService] Finished shutdown for , took 0 ms
2020-05-19T17:42:01.572+02:00 INFO [LogManager] Shutting down.
2020-05-19T17:42:01.576+02:00 INFO [JournalReader] Stopping.
2020-05-19T17:42:01.577+02:00 INFO [LookupDataAdapterRefreshService] Stopping 0 jobs
2020-05-19T17:42:01.609+02:00 INFO [Buffers] Waiting until all buffers are empty.
2020-05-19T17:42:01.610+02:00 INFO [Buffers] All buffers are empty. Continuing.
2020-05-19T17:42:01.616+02:00 INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2020-05-19T17:42:01.629+02:00 INFO [LogManager] Shutdown complete.
2020-05-19T17:42:31.566+02:00 ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], PeriodicalsService [TERMINATED], UrlWhitelistService [TERMINATED], StreamCacheService [TERMINATED], OutputSetupService [TERMINATED], EtagService [TERMINATED], GracefulShutdownService [TERMINATED], LookupTableService [TERMINATED], ConfigurationEtagService [TERMINATED], JournalReader [TERMINATED], BufferSynchronizerService [TERMINATED], KafkaJournal [TERMINATED]], FAILED=[JerseyService [FAILED]]}
2020-05-19T17:42:31.567+02:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:161) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) [graylog.jar:?]
Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
Caused by: java.io.IOException: ObjectIdentifier() – data isn’t an object ID (tag = 48)
at sun.security.util.ObjectIdentifier.(ObjectIdentifier.java:257) ~[?:1.8.0_252]
at sun.security.util.DerInputStream.getOID(DerInputStream.java:314) ~[?:1.8.0_252]
at com.sun.crypto.provider.PBES2Parameters.engineInit(PBES2Parameters.java:267) ~[sunjce_provider.jar:1.8.0_252]
at java.security.AlgorithmParameters.init(AlgorithmParameters.java:293) ~[?:1.8.0_252]
at sun.security.x509.AlgorithmId.decodeParams(AlgorithmId.java:137) ~[?:1.8.0_252]
at sun.security.x509.AlgorithmId.(AlgorithmId.java:119) ~[?:1.8.0_252]
at sun.security.x509.AlgorithmId.parse(AlgorithmId.java:393) ~[?:1.8.0_252]
at javax.crypto.EncryptedPrivateKeyInfo.(EncryptedPrivateKeyInfo.java:95) ~[?:1.8.0_252]
at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:69) ~[graylog.jar:?]
at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:98) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:347) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:172) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:146) ~[graylog.jar:?]
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_252]
2020-05-19T17:42:31.576+02:00 INFO [Server] SIGNAL received. Shutting down.
2020-05-19T17:42:31.592+02:00 INFO [GracefulShutdown] Graceful shutdown initiated.
2020-05-19T17:42:31.593+02:00 INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2020-05-19T17:42:35.596+02:00 INFO [GracefulShutdown] Goodbye.
For the first time, I thought I had a password error, but that’s not it … do you have an idea?
Thanks in advance
