I’m new user on graylog and i try to put the HTTPS in place but is not successful.
I am not comfortable with https certificates
I use a single nœd
I did this on file openssl-graylog.cnf :
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
[req_distinguished_name]
C = FR
ST = t
L = t
O = i
OU = myn
CN = graylog
[v3_req]
keyUsage = keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
[alt_names]
IP.1 = my_ip_graylog_machine
#DNS.1 = graylog.example.com (I comment this line because I will not use DNS resolution)
after that i do this:
openssl req -x509 -days 365 -nodes -newkey rsa:2048 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out cert.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -nocrypt -out pkcs8-plain.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -out pkcs8-encrypted.pem -passout pass:secret
after this commande i got : cert.pem pkcs5-plain.pem pkcs8-encrypted.pem pkcs8-plain.pem
and on the file /etc/graylog/server.conf i do this :
web_listen_uri = https://my_ipgraylog_machine:9000/
web_enable_tls = true
web_tls_cert_file = /etc/graylog/server/certfiles/cert.pem
web_tls_key_file = /etc/graylog/server/certfiles/pcks8-plain.pem
web_tls_key_password = secret
rest_transport_uri = https://my_ipgraylog_machine:9000/api/
rest_listen_uri = https://my_ipgraylog_machine:9000/api/
rest_tls_cert_file = /etc/graylog/server/certfiles/cert.pem
rest_tls_key_file = /etc/graylog/server/certfiles/pcks8-plain.pem
rest_tls_key_password = secret
this is all I did
Thanks in advance.
jochen
(Jochen)
April 5, 2018, 9:48am
2
Corentin:
this is all I did
Please elaborate on what doesn’t work and include all necessary information, such as error messages and the complete output of the commands you’ve been executing.
Hello
I cant access https://my_ip_graylog_machine:9000/ , my web browser tell me this:
" Sorry, we can not reach this page
Error Code : INET_E_RESOURCE_NOT_FOUND "
I don’t know where i can get a better error message.
I have test https://my_ip_graylog_machine this work.
Output of the commands executed
jochen
(Jochen)
April 5, 2018, 1:23pm
5
What is “my_ip_graylog_machine” specifically?
it’s the server ip (192.168.1.1)
I got this error message now
We can not safely access this page
This site uses outdated or insecure TLS security settings. If the problem persists, try contacting the owner.
jan
(Jan Doberstein)
April 9, 2018, 11:43am
8
your certificate might not match your requested hostname
When you said hostname you speak about what I put in the URL link? (i try to access by the ip 192.168.1.1:9000)
jan
(Jan Doberstein)
April 9, 2018, 1:15pm
10
in term of http protocol you request a hostname - that might be an ip or a name - that used named need to be part of the certificate the web server provide that the browser can verify that.
Ok, but I do not understand why when, I test with the ip without the port graylog 9000 the https work.
request (https://192.168.1.1 )
Result :
And for the request (https://192.168.1.1:9000 )
Result :
jan
(Jan Doberstein)
April 10, 2018, 8:53am
12
I think on port 443 you have some kind of web server running (nginx or apache) and on port 9000 you have graylog handling the web traffic itself.
You might need to adjust the ciphers for your environment ( http://docs.graylog.org/en/2.4/pages/securing.html#configuring-tls-ciphers )
Https now work on 192.168.1.1:9000 but I see the default httpd page.
Maybe a need to put a DocumentRoot option but put what path
jan
(Jan Doberstein)
April 10, 2018, 11:01am
14
if you see the default document root you should need to configure your webserver in the right way:
http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#nginx
I using Apache HTTP
My config actualy is
ssl.conf:
Listen 9000 https
Listen 443 https
SSLPassPhraseDialog exec:/usr/libexec/httpd-ssl-pass-dialog
SSLSessionCache shmcb:/run/httpd/sslcache(512000)
SSLSessionCacheTimeout 300
SSLRandomSeed startup file:/dev/urandom 256
SSLRandomSeed connect builtin
SSLCryptoDevice builtin
<VirtualHost *:443>
ServerName 192.168.1.1
ErrorLog logs/ssl_error_log
TransferLog logs/ssl_access_log
LogLevel warn
SSLEngine on
SSLProtocol all -SSLv2
SSLCipherSuite HIGH:MEDIUM:!aNULL:!MD5:!SEED:!IDEA
SSLCertificateFile /etc/certfiles/graylog.cert.pem
SSLCertificateKeyFile /etc/certfiles/graylog.pkcs8-plain.key.pem
<Files ~ "\.(cgi|shtml|phtml|php3?)$">
SSLOptions +StdEnvVars
</Files>
<Directory "/var/www/cgi-bin">
</Directory>
CustomLog logs/ssl_request_log \
"%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
</VirtualHost>
<VirtualHost *:9000>
LogLevel warn
SSLEngine on
SSLProtocol all -SSLv3
SSLHonorCipherOrder on
# HSTS (mod_headers is required) (15768000 seconds = 6 months)
Header always set Strict-Transport-Security "max-age=15768000"
# <Proxy *>
# Order deny,allow
# Allow from all
# </Proxy>
# <Location />
# RequestHeader set X-Graylog-Server-URL "https://192.168.1.1/api/"
# ProxyPass http:///192.168.1.1:9000/
# ProxyPassReverse http://192.168.1.1:9000/
# </Location>
(I have commented on these lines because I'm not sure to need that)
</VirtualHost>
And Server.conf :
web_listen_uri = https://192.168.1.1:9000/api/
web_endpoint_uri = https://192.168.1.1:9000/api/
web_tls_cert_file = /etc/certfiles/graylog.cert.pem
web_tls_key_file = /etc/certfiles/graylog.pkcs8-plain.key.pem
rest_listen_uri = https://192.168.1.1:9000/api/
rest_transport_uri = https://192.168.1.1:9000/api/
rest_enable_tls = true
rest_tls_cert_file = /etc/certfiles/graylog.cert.pem
rest_tls_key_file = /etc/certfiles/graylog.pkcs8-plain.key.pem
it doesn’t work, but I don’t see what is wrong.
jan
(Jan Doberstein)
April 10, 2018, 1:42pm
16
please read: http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#making-the-web-interface-work-with-load-balancers-proxies
adjust it to your environment and use the configuration example provided ( http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#apache-httpd-2-x ) - currently you have Apache AND Graylog listening on port 9000 - which isn’t possible in a common linux setup (on the same interface/ip).
I read that, I tried but it does not work I leave the https aside for the moment.
For graylog httpd is useless i can remove this package no ?
jochen
(Jochen)
April 12, 2018, 2:57pm
18
If you don’t want to use Apache httpd as a reverse proxy for Graylog, it’s not required and you could remove it from your machine.
