Having issues enabling HTTPS on 3.2
Been having some issues getting HTTPS working for the web interface. Using the following commands from the guide I do the following.
openssl req -x509 -days 730 -nodes -newkey rsa:2048 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out graylog.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -nocrypt -out pkcs8-plain.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -out pkcs8-encrypted.pem -passout pass:test
cp pkcs8-encrypted.pem /etc/graylog/server/graylog-key.pem
cp graylog.pem /etc/graylog/server/graylog-certificate.pem
Here is the pertitent section of my config.
# HTTPS settings
# Default: false
http_enable_tls = true
http_tls_cert_file = /etc/graylog/server/graylog-certificate.pem
http_tls_key_file = /etc/graylog/server/graylog-key.pem
# The password to unlock the private key used for securing the HTTP interface.
http_tls_key_password = test
And yet when I start the server I get the following error
2020-02-20T17:44:49.213Z INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Failed [LB:DEAD] 2020-02-20T17:44:49.215Z ERROR [InputSetupService] Not starting any inputs because lifecycle is: Failed [LB:DEAD] 2020-02-20T17:44:49.223Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread]. 2020-02-20T17:44:49.226Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>. 2020-02-20T17:44:49.227Z INFO [GracefulShutdownService] Running graceful shutdown for <1> shutdown hooks 2020-02-20T17:58:43.408Z INFO [GracefulShutdownService] Running graceful shutdown for <1> shutdown hooks 2020-02-20T17:58:43.413Z INFO [LogManager] Shutting down. 2020-02-20T17:58:43.414Z INFO [GracefulShutdownService] Initiate shutdown for <JobWorkerPool> 2020-02-20T17:58:43.414Z INFO [GracefulShutdownService] Finished shutdown for <JobWorkerPool>, took 0 ms 2020-02-20T17:58:43.425Z INFO [LookupDataAdapterRefreshService] Stopping 0 jobs 2020-02-20T17:58:43.428Z WARN [BufferSynchronizerService] Elasticsearch is unavailable. Not waiting to clear buffers and caches, as we have no healthy cluster. 2020-02-20T17:58:43.428Z INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput 2020-02-20T17:58:43.449Z INFO [JournalReader] Stopping. 2020-02-20T17:58:43.474Z INFO [LogManager] Shutdown complete.
I’m not sure why I am getting this. I am sure I am being dumb though.
I also spent several hours without getting https for webinterface working just getting errors.
Can someone please confirm , https is working in 3.2.1 ?
yes - without any problems in my setup.
Hi, I have also spent several hours trying to get HTTPS working. I am on version 3.1.4. I just got it working by not using a secured pk8 key. This link provided the information I needed to get it working. Here are 4 lines from my log file that seemed relevant.
ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
Caused by: java.io.IOException: ObjectIdentifier() – data isn’t an object ID (tag = 48)
According to a link Jan posted in the following thread, the last message above indicates a problem with the key. Mine was 2048 bit, not 4096 as the error indicates. Exporting the key without the encryption was the solution for me.
