I need help with using HTTPS on clustered Graylog please.
According to manual below I created certificate and keys (cert.pem, pkcs5-plain.pem , pkcs8-encrypted.pem, pkcs8-plain.pempkcs5-plain.pem) in path /etc/graylog/server/certificates/.
http://docs.graylog.org/en/2.2/pages/configuration/https.html?highlight=https
On first node I configured required parameters:
rest_enable_tls = true
rest_tls_cert_file = /etc/graylog/server/certificates/cert.pem
rest_tls_key_file = /etc/graylog/server/certificates/pkcs8-encrypted.pem
rest_tls_key_password = {password_used_for_pkcs8-encrypted.pem}
web_enable_tls = true
web_tls_cert_file = /etc/graylog/server/certificates/cert.pem
web_tls_key_file = /etc/graylog/server/certificates/pkcs8-encrypted.pem
web_tls_key_password = {password_used_for_pkcs8-encrypted.pem}
Graylog doesn’t work after restart:
[root@xxxx certificates]# /etc/init.d/graylog-server status
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2017-05-02 14:02:48 CEST; 3s ago
Docs: http://docs.graylog.org/
Process: 7255 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=exited, status=1/FAILURE)
Main PID: 7255 (code=exited, status=1/FAILURE)
[root@xxxx certificates]# sudo tailf /var/log/graylog-server/server.log | grep -i exception
com.github.joschi.jadconfig.ValidationException: Unreadable or missing REST API private key: /etc/graylog/server/certificates/pkcs8-encrypted.pem
Can you help me with this issue please?
