Graylog 3.2 HTTPS private key issue
I referred this resource url https://docs.graylog.org/en/3.2/pages/configuration/https.html#ssl-setup for setting up Graylog web browsing into https mode.
did the following steps in order to generate the self-signed-certificate & private key
openssl req -x509 -days 365 -nodes -newkey rsa:2048 -config openssl-graylog.cnf -keyout pkcs5-plain.pem -out graylog-cert.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -nocrypt -out pkcs8-plain.pem
openssl pkcs8 -in pkcs5-plain.pem -topk8 -out graylog-key.pem -passout pass:secret
cp -a /usr/lib/jvm/jre-1.8.0-openjdk-1.8.0.242.b08-0.el8_1.x86_64/lib/security/cacerts /etc/ssl/certs/cacerts.jks
keytool -importcert -keystore /etc/ssl/certs/cacerts.jks -storepass changeit -alias graylog-self-signed -file graylog-cert.pem
Finally did the config change into the server.conf and /etc/sysconfig/graylog-server
reloaded the deamon and startign the graylog-server.service its throwing error as below
ERROR [CmdLineTool] Invalid configuration
com.github.joschi.jadconfig.ValidationException: Unreadable or missing HTTP private key: /etc/ssl/certs/graylog-key.pem
I’m not sure why I’m getting the error on the graylog-key.pem
Can you help me? If this gets fixed my cluster will be up with https mode.
And
And many more if you search here.
Maybe all the same, and this is a old problem, but still no comment from graylog.
I tried to use the HAProxy and configure the https for the web interface.
I tried to browse after the configuration but unable to access the site via https.
My HAproxy Config code. Am i missing anything.
frontend graylog_https
    bind 192.168.1.50:443 ssl crt /etc/ssl/certs/collector.pem ciphers !aNULL:!MD5:AES128+EECDH:AES128+EDH:!RC4  no-sslv3
    reqadd X-Forwarded-Proto:\ https if { ssl_fc }
    acl is_graylog hdr_dom(host) -i -m str graylogcollector.example.corp
    use_backend graylog if is_graylog
    # Distinguish between secure and insecure requests
    acl secure dst_port eq 443
    # Mark all cookies as secure if sent over SSL
    rsprep ^Set-Cookie:\ (.*) Set-Cookie:\ \1;\ Secure if secure
    # Add the HSTS header with a 1 year max-age
    rspadd Strict-Transport-Security:\ max-age=0
backend graylog
    description     The Graylog Secure Web backend.
    redirect scheme https if !{ ssl_fc }
    mode http
    balance roundrobin
    option httpchk HEAD /api/system/lbstatus
    http-request set-header X-Graylog-Server-URL https://graylogcollector.example.corp
    server graylog1 192.168.1.101:9000 maxconn 20 check
    server graylog2 192.168.1.102:9000 maxconn 20 check
