Setting up HTTPS Web Interface using a Trusted thirdparty cert
I am new to Graylog and I am trying to:
  1. Setup HTTPS access to the webconsole
  2. Encrypt incoming beats logs
Im currently stuck at #1. My deployment is on Azure. I have not change much on the server.conf file.
The server is current up and is reachable via HTTP only.
Here’s a snippet of my HTTPS settings server.conf (let me know if I need to include more info)
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
right now I have:
  • the CA buntdle file
  • Security certificate (.crt file)
  • pkcs #7 file (.p7b)
If I understand this correctly, I should convert the pkcs #7 file to a pkcs#8? Is this possible?
After that, to apply the certificates, do I just copy them on the server and update the server.conf HTTPS setting to point to them?
he @v4rys
exactly your wanted use-case is described in the docs: https://docs.graylog.org/en/3.2/pages/secure/sec_graylog_beats.html
