TLS Connection not working
Hello All,
I want to enable TLS log collection at Graylog since my devices would be sending only TLS wrapped logs. My enterprise has a CA and I have already generated files, But I am struggling to configure them in /etc/graylog/server/server.conf
Can someone help me what parameters do I have to make changes ?
graylog-CA.pem
graylogCert.pem
graylog-Key.pem
graylog.pem
Config:
# Default: false
http_enable_tls = true
http_tls_cert_file = /root/graylog/graylog.pem
http_tls_key_file = /root/graylog/graylog-Key.pem
# The password to unlock the private key used for securing the HTTP interface.
http_tls_key_password = /root/graylog/graylog-CA.pem
what is the error you have?
Hi Jan,
When I make this config (I am not sure if these are correct or now)
From the logs after restarting the server
2020-04-07T14:56:18.320Z ERROR [CmdLineTool] Invalid configuration
com.github.joschi.jadconfig.ValidationException: Unreadable or missing HTTP private key: /root/graylog/graylog-Key.pem
	at org.graylog2.configuration.HttpConfiguration.validateTlsConfig(HttpConfiguration.java:252) ~[graylog.jar:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_242]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_242]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_242]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_242]
	at com.github.joschi.jadconfig.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:53) ~[graylog.jar:?]
	at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:221) ~[graylog.jar:?]
	at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:100) ~[graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:351) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.readConfiguration(CmdLineTool.java:344) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:178) [graylog.jar:?]
Don’t put cert, key files in /root, because graylog service run as graylog user, so it couldn’t read that file. Put it in /etc/graylog/server directory or better recommended directories of your linux distribution, for example:
Debian/Ubuntu: /etc/ssl/certs/, /etc/ssl/private/
RHEL/Centos: /etc/pki/tls/certs/, /etc/pki/tls/private/
Graylog can’t read the certificate.
I tried changing to other directory like home and subdirectory with all permission, but still it didnt work
Finally it worked, Since all my nodes send only syslog over TLS, I had to finally use input as “TCP” and check the box “TLS” and use those relative address of certs local to the server. It started collecting the info.
Thanks all.
