onkargl007
(Onkar Nath Singh)
1
Greetings Team,
i am trying to setup graylog 3.3.1 using https but having difficulties/NO-Luck,
below is my configuration, need your support to resolve this…
File: openssl-graylog.cnf
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
Details about the issuer of the certificate
[req_distinguished_name]
C = AE
ST = Abu-Dhabi
L = Abu-Dhabi
O = xxxxx
OU = Network-Security
CN = netopps.xxxxx.net
[v3_req]
keyUsage = keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
IP addresses and DNS names the certificate should include
Use IP.### for IP addresses and DNS.### for DNS names,
with “###” being a consecutive number.
[alt_names]
IP.1 = 100.xxx.xxx.xxx
DNS.1 = netopps.xxxx.net
below certificate file and key has been created…
- pkcs5-plain.pem
- cert.pem
- pkcs8-plain.pem
- pkcs8-encrypted.pem
onkargl007
(Onkar Nath Singh)
2
below is the configuration of HTTPS
HTTPS settings
Enable HTTPS support for the HTTP interface
This secures the communication with the HTTP interface with TLS to prevent request forgery and eavesdropping.
Default: false
http_enable_tls = true
The X.509 certificate chain file in PEM format to use for securing the HTTP interface.
http_tls_cert_file = /certs/cert.pem
The PKCS#8 private key file in PEM format to use for securing the HTTP interface.
http_tls_key_file = /certs/pkcs8-plain.pem
The password to unlock the private key used for securing the HTTP interface.
http_tls_key_password = xxxxxxxx
http_publish_uri = https://1xx.xxx.xxx.xxx:9000/
/etc/default/graylog-server file :-
Path to the java executable.
JAVA=/usr/bin/java
Default Java options for heap and garbage collection.
GRAYLOG_SERVER_JAVA_OPTS="-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/certs/cacerts.jks -Djavax.net.ssl.trustStorePassword=XXXXX"
Pass some extra args to graylog-server. (i.e. “-d” to enable debug mode)
GRAYLOG_SERVER_ARGS=""
Program that will be used to wrap the graylog-server command. Useful to
support programs like authbind.
GRAYLOG_COMMAND_WRAPPER=""
getting an error secure connection failed…
jan
(Jan Doberstein)
3
and what error did you get when starting Graylog in your Graylog server.conf?
btw. your post would be more readable if you make your code block correct.
