Graylog 3.2 https problem
hello dear guys,
Please help me.
i have been struggling all week to resolve https for 3.2 graylog but no result so i am writing this…
i am using graylog 3.2 ova
hostname : graylog.cup
IP:192.168.88.242
my openssl-graylog.cnf is:
[req]
distinguished_name = req_distinguished_name
x509_extensions = v3_req
prompt = no
[req_distinguished_name]
C = RO
ST = Braila
L = Braila
O = Braila
OU = CUP
CN = graylog.cup
[v3_req]
keyUsage = keyEncipherment, dataEncipherment
extendedKeyUsage = serverAuth
subjectAltName = @alt_names
[alt_names]
IP.1 = 192.168.88.242
DNS.1 = graylog.cup
i followed
3vi1john/graylog combined with
graylog3-with-https-easy-tutorial
step by step : and i have created :
-rw-r–r-- 1 root root 1415 Jan 10 10:39 cert.pem
-rw-r–r-- 1 root root 1504 Jan 10 10:41 graylog-certificate.pem
-rw-r–r-- 1 root root 1874 Jan 10 10:41 graylog-key.pem
-rw------- 1 root root 2002 Jan 10 10:41 graylog-pkcs5.pem
-rw-r–r-- 1 root root 2226 Jan 10 10:38 keystore.jks
-rw-r–r-- 1 root root 2585 Jan 10 10:40 keystore.p12
-rw------- 1 root root 1704 Jan 10 10:38 pkcs5-plain.pem
-rw------- 1 root root 1854 Jan 10 10:40 pkcs8-encrypted.pem
-rw------- 1 root root 1704 Jan 10 10:39 pkcs8-plain.pem
if i run keytool -list -v -keystore graylog_keystore.jks -alias graylog.cup
the output is :
Alias name: graylog.cup
Creation date: Jan 10, 2020
Entry type: PrivateKeyEntry
Certificate chain length: 1
Certificate[1]:
Owner: CN=graylog.cup, OU=cup, O=cup, L=braila, ST=braila, C=RO
Issuer: CN=graylog.cup, OU=cup, O=cup, L=braila, ST=braila, C=RO
Serial number: 5ee7b60b
Valid from: Fri Jan 10 10:38:10 UTC 2020 until: Sat Jan 09 10:38:10 UTC 2021
Certificate fingerprints:
MD5: 98:14:E1:59:03:A6:81:EA:E2:BF:79:C7:1D:97:3E:6D
SHA1: 60:CB:50:B0:D0:94:EA:4C:C1:D5:0D:D9:67:EF:B2:74:06:27:BC:9B
SHA256: D3:D7:B8:19:86:B1:7A:1C:06:BF:7A:86:0E:8A:86:FD:16:B0:29:A7:DF:7C:2A:3B:BC:4A:0C:D9:1E:25:90:30
Signature algorithm name: SHA256withRSA
Subject Public Key Algorithm: 2048-bit RSA key
Version: 3
Extensions:
#1: ObjectId: 2.5.29.14 Criticality=false
SubjectKeyIdentifier [
KeyIdentifier [
0000: B6 4B 2E 53 36 1E 69 66 6B 16 A8 6B 77 97 BF 7F .K.S6.ifk…kw…
0010: 8E 76 77 27 .vw’
i have added -Djavax.net.ssl.trustStorePassword=secret to /etc/default/graylog-server
my settings in /etc/graylog/server/server.conf
http_bind_address = 192.168.88.242:9000
http_publish_uri = http://192.168.88.242:9000/
http_enable_tls = true
http_tls_cert_file = /etc/graylog/graylog-certificate.pem
http_tls_key_file = /etc/graylog/graylog-key.pem
if i run
head graylog-key.pem graylog-certificate.pem
==> graylog-key.pem <==
-----BEGIN ENCRYPTED PRIVATE KEY-----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==> graylog-certificate.pem <==
Bag Attributes
friendlyName: graylog.cup
localKeyID: 54 69 6D 65 20 31 35 37 38 36 35 32 38 35 37 30 31 31
subject=C = RO, ST = braila, L = braila, O = cup, OU = cup, CN = graylog.cup
issuer=C = RO, ST = braila, L = braila, O = cup, OU = cup, CN = graylog.cup
-----BEGIN CERTIFICATE-----
MIIDYTCCAkmgAwIBAgIEXue2CzANBgkqhkiG9w0BAQsFADBhMQswCQYDVQQGEwJS
TzEPMA0GA1UECBMGYnJhaWxhMQ8wDQYDVQQHEwZicmFpbGExDDAKBgNVBAoTA2N1
and if i run
keytool -keystore /etc/ssl/certs/graylog/keystore.jks -storepass secret -list
output is
Keystore type: jks
Keystore provider: SUN
Your keystore contains 1 entry
graylog.cup, Jan 10, 2020, PrivateKeyEntry,
Certificate fingerprint (SHA1): 60:CB:50:B0:D0:94:EA:4C:C1:D5:0D:D9:67:EF:B2:74:06:27:BC:9B
i dont know what i am doing wrong, please help me
dear @brebe
Did you really use the 3.2 BETA Release?
Would you be so kind to FORMAT your posting, using the given options by the community board:
thanks
i have another in production working graylog 3.1 with http only setup (i use for this nginx as reverse proxy)
i want to try to switch to https and to continue to configure also beats with tls
but first step is to figure out https with certificates and all … and i have been trying for last couple of days but nothing
and what is the error you are facing?
this is the log
20-01-10T12:19:34.025Z INFO [CmdLineTool] Loaded plugin: Collector 3.2.0-beta.2 [org.graylog.plugins.collector.CollectorPlugin]
2020-01-10T12:19:34.026Z INFO [CmdLineTool] Loaded plugin: Graylog Enterprise 3.2.0-beta.2 [org.graylog.plugins.enterprise.EnterprisePlugin]
2020-01-10T12:19:34.027Z INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 3.2.0-beta.2 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2020-01-10T12:19:34.349Z INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/etc/ssl/certs/graylog/graylog-key.jks -Djavax.net.ssl.trustStorePassword=hwautedv -XX:+UseParNewGC -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2020-01-10T12:19:34.604Z INFO [Version] HV000001: Hibernate Validator null
2020-01-10T12:19:37.289Z INFO [InputBufferImpl] Message journal is enabled.
2020-01-10T12:19:37.308Z INFO [NodeId] Node ID: 6c8e659a-74c9-4b72-bd61-fb6c12489dd5
2020-01-10T12:19:37.525Z INFO [LogManager] Loading logs.
2020-01-10T12:19:37.563Z INFO [LogManager] Logs loading complete.
2020-01-10T12:19:37.566Z INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2020-01-10T12:19:37.589Z INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2020-01-10T12:19:37.647Z INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2020-01-10T12:19:37.680Z INFO [connection] Opened connection [connectionId{localValue:1, serverValue:64}] to localhost:27017
2020-01-10T12:19:37.692Z INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 14]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=10607593}
2020-01-10T12:19:37.717Z INFO [connection] Opened connection [connectionId{localValue:2, serverValue:65}] to localhost:27017
2020-01-10T12:19:38.026Z INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2020-01-10T12:19:38.323Z INFO [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2020-01-10T12:19:38.324Z INFO [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2020-01-10T12:19:38.407Z INFO [JestClientFactory] Using custom ObjectMapper instance
2020-01-10T12:19:38.408Z INFO [JestClientFactory] Node Discovery disabled…
2020-01-10T12:19:38.408Z INFO [JestClientFactory] Idle connection reaping disabled…
2020-01-10T12:19:39.157Z INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2020-01-10T12:19:39.306Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-01-10T12:19:39.321Z INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy .
2020-01-10T12:19:39.329Z INFO [connection] Opened connection [connectionId{localValue:3, serverValue:66}] to localhost:27017
2020-01-10T12:19:39.366Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-01-10T12:19:39.404Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-01-10T12:19:39.435Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-01-10T12:19:39.477Z WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2020-01-10T12:19:40.165Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-10T12:19:40.167Z INFO [ServerBootstrap] Graylog server 3.2.0-beta.2+18766e8 starting up
2020-01-10T12:19:40.167Z INFO [ServerBootstrap] JRE: Private Build 1.8.0_232 on Linux 4.15.0-74-generic
2020-01-10T12:19:40.168Z INFO [ServerBootstrap] Deployment: deb
2020-01-10T12:19:40.168Z INFO [ServerBootstrap] OS: Ubuntu 18.04.3 LTS (bionic)
2020-01-10T12:19:40.168Z INFO [ServerBootstrap] Arch: amd64
2020-01-10T12:19:40.227Z INFO [PeriodicalsService] Starting 35 periodicals …
2020-01-10T12:19:40.228Z INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2020-01-10T12:19:40.368Z INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2020-01-10T12:19:40.372Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2020-01-10T12:19:40.376Z INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2020-01-10T12:19:40.376Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2020-01-10T12:19:40.388Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2020-01-10T12:19:40.389Z INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2020-01-10T12:19:40.390Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2020-01-10T12:19:40.391Z INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2020-01-10T12:19:40.394Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2020-01-10T12:19:40.403Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2020-01-10T12:19:40.408Z INFO [connection] Opened connection [connectionId{localValue:4, serverValue:67}] to localhost:27017
2020-01-10T12:19:40.415Z INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2020-01-10T12:19:40.421Z INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2020-01-10T12:19:40.425Z INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2020-01-10T12:19:40.425Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2020-01-10T12:19:40.429Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2020-01-10T12:19:40.430Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2020-01-10T12:19:40.430Z INFO [connection] Opened connection [connectionId{localValue:6, serverValue:69}] to localhost:27017
2020-01-10T12:19:40.437Z INFO [connection] Opened connection [connectionId{localValue:5, serverValue:68}] to localhost:27017
2020-01-10T12:19:40.440Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2020-01-10T12:19:40.440Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2020-01-10T12:19:40.456Z INFO [connection] Opened connection [connectionId{localValue:9, serverValue:72}] to localhost:27017
2020-01-10T12:19:40.456Z INFO [connection] Opened connection [connectionId{localValue:7, serverValue:70}] to localhost:27017
2020-01-10T12:19:40.472Z INFO [connection] Opened connection [connectionId{localValue:8, serverValue:71}] to localhost:27017
2020-01-10T12:19:40.482Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2020-01-10T12:19:40.495Z INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2020-01-10T12:19:40.542Z INFO [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2020-01-10T12:19:40.554Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2020-01-10T12:19:40.565Z INFO [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2020-01-10T12:19:40.566Z INFO [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2020-01-10T12:19:40.595Z INFO [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2020-01-10T12:19:40.611Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2020-01-10T12:19:40.622Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2020-01-10T12:19:40.637Z INFO [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2020-01-10T12:19:40.638Z INFO [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2020-01-10T12:19:40.639Z INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2020-01-10T12:19:40.639Z INFO [Periodicals] Starting [org.graylog.plugins.license.LicenseManagerPeriodical] periodical in [0s], polling every [300s].
2020-01-10T12:19:40.639Z INFO [Periodicals] Starting [org.graylog.plugins.license.LicenseReportPeriodical] periodical in [300s], polling every [3600s].
2020-01-10T12:19:40.640Z INFO [Periodicals] Starting [org.graylog.plugins.auditlog.mongodb.MongoAuditLogPeriodical] periodical in [0s], polling every [3600s].
2020-01-10T12:19:40.640Z INFO [Periodicals] Starting [org.graylog.plugins.report.scheduler.ReportPeriodical] periodical in [120s], polling every [60s].
2020-01-10T12:19:40.641Z ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2020-01-10T12:19:40.645Z INFO [Periodicals] Starting [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] periodical in [60s], polling every [180s].
2020-01-10T12:19:40.941Z ERROR [MigrationHelpers] Invalid user ‘graylog-report’, fixing it.
2020-01-10T12:19:40.942Z INFO [MigrationHelpers] graylog-report user is missing or invalid, re-adding it as a built-in user.
2020-01-10T12:19:40.973Z INFO [MigrationHelpers] Views User role is missing or invalid, re-adding it as a built-in role.
2020-01-10T12:19:41.126Z ERROR [MigrationHelpers] Invalid role ‘Views Manager’, fixing it.
2020-01-10T12:19:41.126Z INFO [MigrationHelpers] Views Manager role is missing or invalid, re-adding it as a built-in role.
2020-01-10T12:19:41.164Z INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Failed [LB:DEAD]
2020-01-10T12:19:41.165Z ERROR [InputSetupService] Not starting any inputs because lifecycle is: Failed [LB:DEAD]
2020-01-10T12:19:41.186Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
2020-01-10T12:19:41.187Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.VersionCheckThread] complete, took <0ms>.
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
2020-01-10T12:19:41.189Z INFO [GracefulShutdownService] Running graceful shutdown for <2> shutdown hooks
2020-01-10T12:19:41.188Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
2020-01-10T12:19:41.195Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2020-01-10T12:19:41.195Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.TrafficCounterCalculator].
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.TrafficCounterCalculator] complete, took <0ms>.
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.196Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
2020-01-10T12:19:41.197Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] complete, took <0ms>.
2020-01-10T12:19:41.197Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
2020-01-10T12:19:41.201Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] complete, took <0ms>.
2020-01-10T12:19:41.202Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
2020-01-10T12:19:41.197Z INFO [GracefulShutdownService] Initiate shutdown for
2020-01-10T12:19:41.203Z INFO [GracefulShutdownService] Finished shutdown for , took 0 ms
2020-01-10T12:19:41.200Z INFO [GracefulShutdownService] Initiate shutdown for
2020-01-10T12:19:41.205Z INFO [GracefulShutdownService] Finished shutdown for , took 0 ms
2020-01-10T12:19:41.202Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] complete, took <0ms>.
2020-01-10T12:19:41.211Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
2020-01-10T12:19:41.211Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob] complete, took <0ms>.
2020-01-10T12:19:41.211Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
2020-01-10T12:19:41.211Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp] complete, took <0ms>.
2020-01-10T12:19:41.211Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
2020-01-10T12:19:41.212Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
2020-01-10T12:19:41.212Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseManagerPeriodical].
2020-01-10T12:19:41.212Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseManagerPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.207Z INFO [LogManager] Shutting down.
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.license.LicenseReportPeriodical].
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.license.LicenseReportPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.scheduler.ReportPeriodical].
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.scheduler.ReportPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical].
2020-01-10T12:19:41.222Z INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] complete, took <0ms>.
2020-01-10T12:19:41.233Z INFO [LookupDataAdapterRefreshService] Stopping 0 jobs
2020-01-10T12:19:41.251Z INFO [JournalReader] Stopping.
2020-01-10T12:19:41.272Z INFO [Buffers] Waiting until all buffers are empty.
2020-01-10T12:19:41.275Z INFO [LogManager] Shutdown complete.
2020-01-10T12:19:41.280Z INFO [Buffers] All buffers are empty. Continuing.
2020-01-10T12:19:41.282Z INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2020-01-10T12:20:11.187Z ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], UrlWhitelistService [TERMINATED], StreamCacheService [TERMINATED], OutputSetupService [TERMINATED], GracefulShutdownService [TERMINATED], EtagService [TERMINATED], PeriodicalsService [TERMINATED], LookupTableService [TERMINATED], ConfigurationEtagService [TERMINATED], JournalReader [TERMINATED], KafkaJournal [TERMINATED], BufferSynchronizerService [TERMINATED]], FAILED=[JerseyService [FAILED]]}
2020-01-10T12:20:11.189Z ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:148) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) [graylog.jar:?]
Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
Caused by: java.io.IOException: ObjectIdentifier() – data isn’t an object ID (tag = 48)
at sun.security.util.ObjectIdentifier.(ObjectIdentifier.java:257) ~[?:1.8.0_232]
at sun.security.util.DerInputStream.getOID(DerInputStream.java:314) ~[?:1.8.0_232]
at com.sun.crypto.provider.PBES2Parameters.engineInit(PBES2Parameters.java:267) ~[sunjce_provider.jar:1.8.0_232]
at java.security.AlgorithmParameters.init(AlgorithmParameters.java:293) ~[?:1.8.0_232]
at sun.security.x509.AlgorithmId.decodeParams(AlgorithmId.java:132) ~[?:1.8.0_232]
at sun.security.x509.AlgorithmId.(AlgorithmId.java:114) ~[?:1.8.0_232]
at sun.security.x509.AlgorithmId.parse(AlgorithmId.java:372) ~[?:1.8.0_232]
at javax.crypto.EncryptedPrivateKeyInfo.(EncryptedPrivateKeyInfo.java:95) ~[?:1.8.0_232]
at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:69) ~[graylog.jar:?]
at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:98) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:344) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:169) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:143) ~[graylog.jar:?]
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_232]
2020-01-10T12:20:11.204Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-10T12:20:11.221Z INFO [Server] SIGNAL received. Shutting down.
2020-01-10T12:20:11.229Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-10T12:20:11.230Z INFO [GracefulShutdown] Graceful shutdown initiated.
2020-01-10T12:20:11.230Z INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2020-01-10T12:20:15.239Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2020-01-10T12:20:15.240Z INFO [GracefulShutdown] Goodbye.
logs are typically same on startup http vs https setup until here in logs
why is your configuration:
when you use HTTPS - it should be:
 http_publish_uri = https://192.168.88.242:9000/
thank you , that worked!!!
