Graylog https Setup
Does any have a step-by-step guide for setting up graylog with https? I’ve followed the guide on docs.graylog.org without luck.
I have NginX, Graylog 2.4 and Mongo on one server and ElasticSearch on another server. It’s running real smooth with http now.
/Carsten
Which step didn’t work for you?
I guess it must have been the certificates vbut i’ve reset my virtuel server and am starting all over, from http working. Do you have a guide for setting it up with https?
If you have any problems getting HTTPS to work with these documentation chapters, please describe exactly what you did and where you are struggling.
ok, that’s cool, thanks.
I’ve created the selfsigned certifcates and NginX is working with https, with .crt and .key extentions.
Now I have to configure Graylog to run with https.
Is this server config correct? (single server in cluster with graylog+mongo) elasticsearch on other server),
should I use pem or .crt extentions?
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = xxxxxx it been set
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = xxxxx it's been set
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = +01:00
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = https://192.168.37.81:12900/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
# rest_transport_uri = http://127.0.0.1:12900/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
# overall round trip times. This is disabled by default. Uncomment the next line to enable it.
#rest_enable_gzip = true
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
rest_tls_cert_file = /etc/ssl/certs/graylog-alipes-local-cert.pem
# The PKCS#8 private key file in PEM format to use for securing the REST API.
rest_tls_key_file = /etc/ssl/private/graylog-alipes-local-pkcs8-encrypted.pem
# The password to unlock the private key used for securing the REST API.
rest_tls_key_password = secret
rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
web_enable = true
# Web interface listen URI. It must not contain a path other than "/".
web_listen_uri = https://192.168.37.81:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
web_tls_cert_file = /etc/ssl/certs/graylog-alipes-local-cert.pem
# The PKCS#8 private key file in PEM format to use for securing the web interface.
web_tls_key_file = /etc/ssl/private/graylog-alipes-local-pkcs8-encrypted.pem
# The password to unlock the private key used for securing the web interface.
web_tls_key_password = secret
web_max_header_size = 8192
web_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
web_thread_pool_size = 16
# Configuration file for the embedded Elasticsearch instance in Graylog.
# Pay attention to the working directory of the server, maybe use an absolute path here.
# Default: empty
#elasticsearch_config_file = /etc/graylog/server/elasticsearch.yml
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
# # Default: graylog-internal
# be enabled with care. See also: https://www.graylog.org/documentation/general/queries/
allow_highlighting = false
# settings to be passed to elasticsearch's client (overriding those in the provided elasticsearch_config_file)
# all these
# this must be the same as for your Elasticsearch cluster
elasticsearch_cluster_name = graylog
# The prefix being used to generate the Elasticsearch node name which makes it easier to identify the specific Graylog
# server running the embedded Elasticsearch instance. The node name will be constructed by concatenating this prefix
# and the Graylog node ID (see node_id_file), for example "graylog-17052010-1234-5678-abcd-1337cafebabe".
# Default: graylog-
#elasticsearch_node_name_prefix = graylog-
# A comma-separated list of Elasticsearch nodes which Graylog is using to connect to the Elasticsearch cluster,
# see https://www.elastic.co/guide/en/elasticsearch/reference/2.3/modules-discovery-zen.html for details.
# Default: 127.0.0.1
elasticsearch_discovery_zen_ping_unicast_hosts = 192.168.1.80:9300
# we don't want the Graylog server to store any data, or be master node
#elasticsearch_node_master = false
#elasticsearch_node_data = false
# use a different port if you run multiple Elasticsearch nodes on one machine
#elasticsearch_transport_tcp_port = 9350
# we don't need to run the embedded HTTP server here
#elasticsearch_http_enabled = false
# Enable Elasticsearch multicast discovery. This requires the installation of an Elasticsearch plugin,
# see https://www.elastic.co/guide/en/elasticsearch/plugins/2.3/discovery-multicast.html for details.
# Default: false
elasticsearch_discovery_zen_ping_multicast_enabled = false
# Change the following setting if you are running into problems with timeouts during Elasticsearch cluster discovery.
# The setting is specified in milliseconds, the default is 5000ms (5 seconds).
#elasticsearch_cluster_discovery_timeout = 5000
# the following settings allow to change the bind addresses for the Elasticsearch client in Graylog
# these settings are empty by default, letting Elasticsearch choose automatically,
# override them here or in the 'elasticsearch_config_file' if you need to bind to a special address
# refer to http://www.elasticsearch.org/guide/en/elasticsearch/reference/0.90/modules-network.html
# for special values here
elasticsearch_network_host = 192.168.37.80
elasticsearch_network_bind_host = "0.0.0.0"
elasticsearch_network_publish_host = _non_loopback:ipv4
elasticsearch_hosts = http://192.168.37.80:9200
# The total amount of time discovery will look for other Elasticsearch nodes in the cluster
# before giving up and declaring the current node master.
#elasticsearch_discovery_initial_state_timeout = 3s
# Elasticsearch documentation: http://www.elasticsearch.org/guide/reference/index-modules/analysis/
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# See http://docs.mongodb.org/manual/reference/connection-string/ for details
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.org/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: https://www.graylog.org/documentation/general/rewriting/
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Enable collection of Graylog-related metrics into MongoDB
# WARNING: This will add *a lot* of data into your MongoDB database on a regular interval (1 second)!
# DEPRECATED: This setting and the respective feature will be removed in a future version of Graylog.
#enable_metrics_collection = false
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
Thanks Carsten
Superficially it seems okay. Do you have any problems with it?
You can also use .foobar if you want to. It’s important that the contents of the files are correct. :wink:
https is not responding in graylog, only in nginx. the log reports this error:
com.github.joschi.jadconfig.ValidationException: Unreadable or missing REST API private key: /etc/ssl/private/graylog-alipes-local.key
at org.graylog2.plugin.BaseConfiguration.validateRestTlsConfig(BaseConfiguration.java:442) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_151]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_151]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_151]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_151]
at com.github.joschi.jadconfig.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:53) ~[graylog.jar:?]
at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:221) ~[graylog.jar:?]
at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:100) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:351) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.readConfiguration(CmdLineTool.java:344) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:177) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:44) [graylog.jar:?]
same error even if the certs are .pem or.key
am I supposed to import a cert into keystore cacerts?
Does the file exist and is it readable for the system user running Graylog?
What’s the output of the following command on the machine running Graylog?
namei -l /etc/ssl/private/graylog-alipes-local.key
Then why are you wondering that Graylog is saying exactly that? :thinking:
Nope.
graylog@graylog:~$ namei -l /etc/ssl/private/graylog-alipes-local.key
f: /etc/ssl/private/graylog-alipes-local.key
drwxr-xr-x root root     /
drwxr-xr-x root root     etc
drwxr-xr-x root root     ssl
drwx--x--- root ssl-cert private
                         graylog-alipes-local.key - No such file or directory
graylog@graylog:~$ sudo namei -l /etc/ssl/private/graylog-alipes-local.key
[sudo] password for graylog:
-rw-r--r-- root root     graylog-alipes-local.key
let me know if you want to help out on this. thanks.
If the Graylog system user isn’t member of the ssl-cert group, it doesn’t have access to anything in that directory.
Excuse me? You might want to think about that reply…
I’ll try to set the permissions. Thanks.
Did you install graylog manually or via one of the predefined images like docker, AMI, OVA?
I tried getting https to work but was unsuccessful. I think I know what I did wrong though.
I did it manually, no luck so far.
The instructions and documentation are very inconsistent and confusing for setting up HTTPS. I gave up for now.
I’ve read that to enable HTTPS you only have to use graylog-ctl enforse-ssl but then the documentation states that you need to modify like 7 fields in the configuration file.
If you installed manually, that means you also manually installed nginx. I guess the workflow should be:
  1. install nginx
  2. make sure the ssl cert and private key are in the format stated in the docs
  3. modify all the fields in the configuration file
  4. run the graylog-ctl reconfigure command to apply those changes
  5. Make sure the nginx configuration file “works” for graylog
  6. Check nginx log file for errors.
I was getting bind errors because I manually installed nginx and had the nginx from the OVA running.
You’re mixing up two things: graylog-ctl is the preferred and only supported way of configuring the virtual appliance (OVA, AMI), while the chapter on configuring HTTPS in the documentation targets every other installation type.
All manual changes to configuration files in the OVA (or AMI) will be overwritten when running graylog-ctl reconfigure or any other command triggering a reconfiguration.
